PinePhone
Revision as of 19:56, 11 August 2023 by Fxc (talk | contribs) (→‎The battery is drained: +templ)
Introduction
State of the software
First things first, the PinePhone is aimed solely at early adopters - more specifically, the units are solely intended to find their way into the hands of users with extensive operating system experience.
Bear in mind that the software for these smartphones is very early, with most of the software being in alpha or beta state. That's especially also the case for scalability of applications, their availability and practicability, any hardware function implementations and the firmware. The software is provided as is. There is no warranty for the software, not even for merchantability or fitness for a particular purpose.
Help and support
Still have any questions regarding software, shipping, or ordering after reading this wiki? Please don't hesitate to contact the community in the bridged community channels for detailed answers or simply to chat with friendly people in the community! See Main Page#Community and Support.
Please keep in mind that PINE64 is not like a regular company (see the PINE64 philosophy) and that support resources are limited - the best way to get support quickly is to ask in the community chat! Please only contact the PINE64 support directly if questions couldn't be solved via the community chat or this wiki.
First time installation
A protection foil isolates the battery for the shipping.
When shipped the battery is isolated from the device using a protective plastic tab, which is required to be removed before using the phone. The battery will not charge or boot until it is removed and the battery is connected again.
Note: To remove the sticker after unboxing the phone: Carefully remove the back panel using the notch in the corner of the back cover without overbending it. Then remove the battery. Peel off the clear plastic sticker below it, which isolates the charging contacts and reinsert the battery.
The PinePhone's SIM slot only accepts a micro-SIM, please do not insert a nano-SIM without an adapter and make sure that the nano-SIM does not get released from its adapter. The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot.
Note: Do not insert an empty micro-SIM adapter into the phone and do not release the nano-SIM inside the adapter, as it will get stuck on the contact pins. If the nano-SIM got released inside the adapter inside the phone, carefully reinsert the nano-SIM card without moving the adapter. In that case do not pull on the empty adapter as it will get stuck on the contact pins and damage them!
The microSD belongs in the upper slot, the micro-SIM in the lower slot.
An adapter from a nano to a micro-SIM might be included under tape in the camera notch of the phone's packaging. Some nano-SIMs will not fit firmly into that adapter that comes with the PinePhone and if the included adapter is used without a well-fitting nano-SIM, the contact pins might get damaged. In that case it is highly recommended to acquire a better fitting adapter.
Operating systems
Software releases
The PinePhone Software Releases page has a complete list of currently supported phone-optimized Operating System images that work with the PinePhone as well as other related software information. As soon as more patches get mainlined and distributions ship with the updated kernel, they will also be able to run unmodified on the device. To update any installed operating system please see PinePhone Updating Instructions.
Installation instructions
Relevant subsections of the article for installing operating systems to the PinePhone are:
Troubleshooting
If the PinePhone is not booting from eMMC and/or microSD card anymore it can have two causes:
If the battery is fully drained, most operating systems and distributions won't boot anymore. One of the exceptions which still boots is the utility Jumpdrive, which can usually be used to expose the eMMC and microSD card as drives to a USB-connected computer. Mind that JumpDrive won't expose the eMMC and microSD card with a drained battery but it still can be flashed and booted from microSD card to confirm that the phone still functions and boots up fine.
JumpDrive can be downloaded from here (not compatible with the PinePhone Pro!).
Note: If JumpDrive boots and other releases do not boot, the battery is likely drained. In that case let it charge while running JumpDrive with a compatible charger for multiple hours and make sure to not fully drain the battery in the future anymore, as that significantly reduces the battery lifetime.
Alternatively to testing JumpDrive, the issue can also be diagnosed by checking the battery charge. Simply remove the battery from the device and measure the voltage on the (+) and (-) contacts on the battery. Make sure to not shorten the contacts as shorting battery pins is a severe life and safety danger.
The installation is corrupted or incorrect
If the installation of the prioritized boot medium is corrupted or incorrect, the PinePhone will not boot anymore. The following problems are common:
  • The microSD card is in the wrong slot (see first time installation)
  • The image file was flashed to partition 1 (example: sdx1, nvme0x1p1) instead of the whole device (example: sdx, nvme0x1)
  • An image without bootloader was flashed (mind the Tow-Boot bootloader requirements of Mobian and postmarketOS)
  • The operating systems got corrupted, for example after running updates (reflash the device, see PinePhone Installation Instructions)
  • An incompatible image was flashed (make sure that the images are compatible. Images for the PinePhone Pro won't boot on the PinePhone and vice versa. Check your invoice to see if you ordered a PinePhone or a PinePhone Pro).
Specifications
  • SIM Card: Micro-SIM
  • Display:
  • Sound: Loudspeaker, 3.5mm jack & mic (jack doubles as hardware UART if hardware switch 6 is deactivated)
  • Communication:
    • Modem: Quectel EG25-G
    • LTE-TDD: B38, B39, B40, B41
    • Bluetooth: 4.0, A2DP
  • Privacy switches: Modem, WiFi & Bluetooth, Microphone, Cameras
Components
Component Model
Touchscreen Goodix GT917S
Rear camera OmniVision OV5640
Camera flash SGMICRO SGM3140
LCD Xingbangda XBD599
WiFi Realtek RTL8723CS
Bluetooth Realtek RTL8723CS
Modem Quectel EG25-G
GNSS/GPS Quectel EG25-G
Magnetometer ST LIS3MDL
Vibration motor Unknown model
Notification LED LED0603RGB
Power button X-Powers AXP803
Hardware revisions
The history of the PinePhone CEs
Hardware accessory
Add-ons
The PinePhone (and PinePhone Pro) is compatible with the official add-on cases, such as the keyboard, the LoRa add-on, the Qi wireless charging add-on and the fingerprint reader add-on. Details can be found under:
PinePhone Accessories
The USB-C can be used to power the device, and offers USB2 host and OTG capabilities, and also can make use of the USB-C capability to integrate HDMI signals. Some USB-C hubs are available that offer power throughput, USB connection, an HDMI port and Ethernet connection.
Pogo pins
Interrupt SDA SCL
DCIN USB-5V GND
DCIN and USB-5V are the names used in the schematics. The actual behavior of these pogo pins is not obvious based on their names. DCIN is connected both to the VBUS line of the USB Type-C connector and to the ACIN/VBUS inputs on the PMIC. This means that, depending on a number of factors, DCIN may be at 0 V or 5 V. USB-5V is connected at the output of an LP6226 DC/DC boost converter (5 V), which in turn is fed by the PS output of the PMIC. The boost converter is enabled or disabled by a GPIO output from the A64 SoC, controlled by software (e.g. the Linux kernel). Depending on inputs and decision made by the PMIC, PS may be at the battery voltage (fed "directly" by the battery through a transistor controlled by the PMIC), or at the "USB" voltage (fed by the PMIC's ACIN/VBUS inputs). This means that depending on a number of factors, USB-5V may be at battery voltage (between 3.0 V and 4.3 V), or at 5 V.
Because the PinePhone may act as a USB host (providing 5 V at the USB Type-C connector's VBUS to a connected device) or as a USB device (drawing from a 5 V source on the USB Type-C connector's VBUS), DCIN is actually not strictly an input nor an output. Some community analysis of the PinePhone schematic (and some testing) indicates that you can connect a 5 V power supply to DCIN in order to power the phone at the PMIC's ACIN/VBUS inputs (and, as a side effect, charge the battery). This may not be safe to do in all conditions, e.g., when the phone is acting as a USB host to a connected USB device. It should also be safe to use DCIN as a power output from the PinePhone, e.g., when a USB Type-C charger is connected, you can draw current directly from the USB Type-C port's VBUS, which is provided by the charger. Please note that, when using DCIN as an output from the PinePhone, DCIN isn't "always on"; it may be 0 V. It is currently not documented on how much current can be safely drawn.
USB-5V should be safe to use as an "always on" power output from the PinePhone. Depending on a number of factors, voltage may be from 3 V to 5 V; thus, if you are using USB-5V to power your pogo-pins expansion board, you will probably need to use DC/DC converters/regulators as appropriate. USB-5V is on even while the A64 SoC is powered down.
The I2C and interrupt lines have pull-ups on the phone side. The I2C lines are pulled up to 3v3 by the phone.
PINE64 store currently sells the PinePhone Flex Breakout Board. With the pitch being 2.54 mm, this Flex Breakout Board may have leads soldered directly to the contacts for use in a solderless board. A non-soldered solution would be to use a TE AMP Connector that will accept a Flat Flexible Cable 2.54 mm pitch.
Back cover
Serial console
Pinout of the serial adapter.
The UART is 115200n8.
  • Tip: RX
  • Ring: TX
  • Sleeve: GND
You can buy a serial debug cable from the PINE64 Store. The store cable uses a 4 ring plug, as seen in the here, but a 3 ring plug works just as well. The cable uses a CH340 chipset based serial to USB converter, but any 3.3v serial connection can be used. Because it is a "host"/DTE it means that you need a cross modem cable (Null Modem) with TX on Tip to be connected to RX. A cable like e.g. FTDI TTL-232R-3V3-AJ which has TX on Tip and RX on Ring fits perfectly.
Privacy switch configuration
Picture of the privacy switches
Camera
Battery
The phone ships with a protective plastic sticker between the battery and the phone to protect the device from turning on during shipping. You need to gently open the back cover, then remove the battery and finally remove the sticker and check that the pins aren't bent. Note: If the battery is stuck inside the phone, the mid screw in the lower part of the midframe needs to be slightly loosened, see here.
Note: The EG25-G modem and the RTL8723CS WiFi and Bluetooth do not work without a battery and with a drained battery, even when enough power is supplied to the PinePhone via the USB Type-C port. Most operating systems won't boot without a battery or with a drained battery.
Warning: Using an aftermarket battery with a higher capacity is done at own risk. Batteries with a higher capacity especially in combination with an external charger can lead to overvoltage, which fries the modem and/or the Bluetooth and WiFi chip.
Modem
The PinePhone uses Quectel EG25-G as modem. AT commands are used to communicate with the modem.
AT commands
A list of documented AT commands can be found for example in this AT commands documentation from Quectel. Further undocumented AT commands found by the developer megi, who reverse-engineered parts of the modem and its firmware, can be found on megi's website here.
To send AT commands to the modem under Linux, minicom or the often-preinstalled atinout utility can be used.
atinout example:
echo "AT+<command here>" | sudo atinout - /dev/ttyUSB2 -
minicom example:
minicom -D /dev/ttyUSB2
VoLTE
The PinePhone's modem supports VoLTE and comes with a few VoLTE profiles preloaded. Most operating systems try to set the correct profile automatically.
AT+QMBNCFG="list"
AT+QCFG="ims",1
AT+CFUN=1,1
AT+CLCC
+CLCC: 1,1,0,1,0,"",128
+CLCC: 2,1,0,1,0,"",128
In the fourth item of the list, "0" means voice and and "1" means data. If both rows have "1" then the voice call is being carried over VoLTE.
APN settings
Carrier support
Documents
Detailed information about the modem can be found on the page of the developer megi, including reverse-engineered parts of the firmware and its functions. There is also a document about using the modem from January 18th 2020 by megi here. A script at the end of the document showcases a way to poweroff the modem before powering off the phone, which is integrated into most of the available operating systems.
Firmware update
There is a (nearly) free custom firmware and the stock firmware available for the PinePhone. Both can be updated to a newer version with new features and bug fixes.
Custom firmware
There is a (nearly) free custom firmware for the PinePhone modem by the developer biktorgj, which can be found here.
The custom firmware has various advantages (and zero disadvantages) over the stock firmware, including:
  • Signal tracking support with checks against the OpenCelliD database
  • Persistent storage is optional and unexpected shutdowns don't mess up the modem
  • A lower energy consumption due to the lower minimum clock frequency
  • And many more, see Features not available on stock firmware
The custom firmware can be flashed using fwupd or a flashing script.
Stock firmware
The stock modem firmware can be updated to a newer version if it is outdated. The firmware version can be checked using the following AT command (at the example of atinout, alternatively minicom can be used to communicate with the modem too):
echo 'AT+QGMR' | sudo atinout - /dev/ttyUSB2 -
Pre-update checklist:
cd quectel_eg25_recovery
sudo ./qfirehose -f ./
Firmware modifications
GPS / GNSS
The GPS engine in the modem supports mutli-GNSS reception from GPS, GLONASS, BeiDou, Galileo and QZSS independent of a cellular connection. The operation of the GNSS subsystem can be controlled via a separate set of AT commands, or via qmi. The A-GPS data upload uses the file management AT commands, which also have their own manual. These are linked in the documentation section below.
As with most smartphones, the PinePhone has a small antenna and has difficulty getting a first fix without assistance data, a cold start can take 15 minutes under good conditions. The eg25-mananger is configured to upload A-GPS data by default (see here).
Basic testing of GNSS reception can be done by using the AT command interface (/dev/ttyUSB2) from a terminal program like minicom and the data output interface (/dev/ttyUSB1) to feed NMEA data into gpsmon or some other program that can parse standard NMEA sentences.
cat /dev/ttyUSB1
$GPVTG,,T,,M,,N,,K,N*2C
$GPGSA,A,1,,,,,,,,,,,,,,,,*32
$GPGGA,,,,,,0,,,,,,,,*66
Further details can be found under PinePhone Sensors and Navigation.
Voice mail
The operating systems of the PinePhone may not have support for accessing your voicemail by holding down the 1-key. Carriers might support accessing the voice mail via an external number however.
Safety
General recommendations
Due to the greater control the user is having over the device and its software comes also greater responsibility. It is necessary to verify the configuration of the device to make sure that responsible settings are used. The different operating systems may come with non-sane default settings, including SSH with weak password authentication being enabled by default and exposed to the public Internet, the absence of a firewall, default passwords, unencrypted files, too high temperature zones and emergency shutoff values or an enabled root account. The usage of public resources to verify such settings (such as the in case of GNU/Linux, the Arch Linux security wiki page, or the general recommendations) as well as the corresponding operating system's or distribution's resources are strongly recommended.
Charging safety
The PinePhone supports up to 5V 3A (15W) Quick Charge, it follows the USB Power Delivery specification. Only compatible phone chargers may be used, charging the phone with incompatible chargers (for example laptop chargers with a higher voltage) is prohibited. Charging the phone releases heat, general safety recommendations must be followed, see the section Thermal safety.
Thermal safety
With the Allwinner A64 being an older generation SoC with a large 40nm chip, the phone produces quite some heat with medium or higher use and especially also during charging or when using USB accessories, like a docking station. Measurements to prevent damage to the phone and to its surroundings need to be taken by the user. This includes especially a proper handling of the phone: do not charge the phone in a way where heat builds up around the phone without being able to escape. Especially don't charge your phone under a pillow, blankets, in pockets or bags. Charging the phone produces heat and charging the phone in a way, where the excessive heat can't dispose around the phone poses an immediate fire risk.
The user might notice that the phone gets warm under usage, compared to phones with more up-to-date hardware. Under normal circumstances these temperatures don't pose a risk while being in the levels within the safe operating temperatures (which lay far beyond the point where components can be too hot to touch). Higher temperatures might especially be experienced on the top side of the screen and on the inside of the phone at the RF shield of the modem. The higher temperature of the RF shield of the modem is commonly caused by the SoC on the opposite side of the mainboard, the RF shield of the modem is used to disperse heat of the SoC. In newer mainboard revisions starting from 1.2a there are also thermal pads on the back cover and between the SoC's RF shield and the screen, dispersing heat on the screen and on the back cover. In the past there has been safety issues regarding thermal safety functions, causing temperature reads to not properly work over an extended period of time, which was causing heat damage in some cases (see the documentation of that issue by the developer Megous here and here). While the developers are working hard to prevent such issues, they can't be excluded under all circumstances (see state of the software). The users are expected to monitor their phones' thermal safety at every point at this state of the software.
It is highly recommend to update the phone on a regular basis to always get the latest improvements. The default settings to throttle the performance and to shut down the phone when reaching critical temperatures might be set to a too high point depending on the specific usage and usage length. Under GNU/Linux the phone's thermal management behavior can be modified via the Thermal Sysfs driver to achieve lower temperatures and preventing the screen and other components to potentially take damage, see PinePhone Thermal Tweaks for the details.
Frequently asked questions
Modifications and repairs
Replacing the mainboard
Replacement boards come with an empty eMMC, which means that trying to boot from them looks like the board is faulty (no LEDs, no screen, no reaction of the phone). Please boot an OS from SD card.
  1. You’ll need a small Phillips screwdriver and a prying tool to swap out the PinePhone’s mainboard.
  4. Unscrew all 15 Phillips head screws around the midframe of the phone.
A video tutorial by Martijn Braam can be found here (or alternatively a video tutorial by user brigadan with additional notes about the camera swap and proximity sensor isolator here):
Flashing the ANX firmware
Method 1
Under GNU/Linux this can be done by downloading the latest ANX7688 firmware image on the phone:
and executing as root ("sudo su") on the phone:
Method 2
Booting a factory test image will automatically flash the ANX7688 chip. See Factory Test OS for such an image.
Replacing the screen
Spare parts not available in the PINE64 store
Other hardware issues
See also PinePhone Hardware Issues for more issues and how-to's.
Press
PinePhone mainboard schematic:
PinePhone USB-C small board schematic:
PinePhone certifications:
Allwinner A64 SoC information:
X-Powers AXP803 PMIC (Power Management IC) information:
LPDDR3 (178 Balls) SDRAM:
eMMC information:
CMOS camera module information:
LCD touch screen panel information:
Lithium battery information:
WiFi/BT module information:
LTE module information:
Sensors:
Digital video to USB-C bridge:
Case information:
Other components:
Resources
The following articles contain more specific information:
The following resources have been made available by Ondřej Jirman, a developer for the Pinephone:
External links
