PinePhone Press
Jump to navigation
Jump to search
Vector images and pictures of the PinePhone and PinePhone Pro you can freely use for projects and press inquiries. Attribute the author if attribution is required via the license (such as CC BY).
PinePhone Pro
PinePhone
3D model
The 3D model can be used for a wide variety of purposes, for example for product renderings:
Example rendering:
New template:
Old template:
Lockscreen template
For renderings you can use and modify this template:
Version with black background. Author: Funeral, License: CC0. SVG file under File:Phosh_lockscreen.svg
Version with no background. Author: Funeral, License: CC0. SVG file under File:Phosh_lockscreen_blank.svg
