PinePhone
Revision as of 16:06, 20 August 2021 by MikeBanon (talk | contribs) (My dmesg didn't have a modem firmware info. Replaced with a more reliable way of modem firmware version checking)
Introduction
State of the software
First things first, the PinePhone is aimed solely at early adopters - more specifically, the units are solely intended to find their way into the hands of users with extensive Linux experience.
Bear in mind that the software for Linux on phones is very early, with most of the software being in alpha or beta state. That's especially also the case for scalability of applications, their availability and practicability, any hardware function implementations and the firmware. The software is provided as is. There is no warranty for the software, not even for merchantability or fitness for a particular purpose.
Help and support
Still have any questions regarding software, shipping, or ordering after reading this wiki? Please don't hesitate to contact the community in the bridged community channels for detailed answers or simply to chat with friendly people in the community! See Main Page#Community and Support.
Please keep in mind that PINE64 is not like a regular company (see PINE64 philosophy), and currently that support resources are sparse - the best way to get support quickly is to ask in the community chat! Please only contact PINE64 directly if questions couldn't be solved via the community chat or this wiki.
First time installation
Do not insert an empty micro SIM adapter into the phone, as it will get stuck on the contact pins.
When shipped the battery is isolated from the device using a protective plastic tab, which is required to be removed before using the phone. The battery will not charge until this is removed and the modem, WiFi and Bluetooth will not work until the battery is connected.
The PinePhone's SIM slot only accepts a micro SIM, please do not insert a nano SIM without an adapter. An adapter from a nano to a micro SIM might be included under tape in the camera notch of the phone's packaging. The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot. Notice: Do not insert an empty micro SIM adapter into the phone, as it will get stuck on the contact pins.
  1. Carefully remove the back panel using the notch in the corner of the back cover without overbending it
  2. Remove the battery (if the battery is stuck in the device please check this paragraph for a fix)
  4. Reinsert the battery
Operating Systems
Software releases
The PinePhone Software Releases page has a complete list of currently supported phone-optimized Operating System images that work with the PinePhone as well as other related software information. As soon as more patches get mainlined and distributions ship with the updated kernel, they will also be able to run unmodified on the device. To update any installed operating system please see PinePhone Updating Instructions.
Installation instructions
Relevant subsections of the article for installing OSes to the PinePhone are:
Specifications
  • SIM Card: Micro-SIM
  • Display:
  • Sound: Loudspeaker, 3.5mm jack & mic (jack doubles as hardware UART if killswitch 6 is deactivated)
  • Communication:
    • Modem: Quectel EG25-G
    • LTE-TDD: B38, B39, B40, B41
    • Bluetooth: 4.0, A2DP
  • Killswitches: Modem, WiFi & Bluetooth, Microphone, Cameras
Components
Component Model
Touchscreen Goodix GT917S
Rear camera OmniVision OV5640
Camera flash SGMICRO SGM3140
LCD Xingbangda XBD599
WiFi Realtek RTL8723CS
Bluetooth Realtek RTL8723CS
Modem Quectel EG25-G
GNSS/GPS Quectel EG25-G
Magnetometer ST LIS3MDL
Vibration motor Unknown model
Notification LED LED0603RGB
Power button X-Powers AXP803
Hardware revisions
Hardware accessory
USB-C connector
The USB-C can be used to power the device, and offers USB2 host and OTG possibilities, and also can make use of the USB-C capability to integrate HDMI signals. Some USB-C hubs are available that offer power throughput, USB connection, HDMI port and Ethernet connection.
Pogo pins
Interrupt SDA SCL
DCIN USB-5V GND
DCIN and USB-5V are the names used in the schematics. The actual behavior of these pogo pins is not obvious based on their names. DCIN is connected both to the VBUS line of the USB Type-C connector and to the ACIN/VBUS inputs on the PMIC. This means that, depending on a number of factors, DCIN may be at 0 V or 5 V. USB-5V is connected at the output of an LP6226 DC/DC boost converter (5 V), which in turn is fed by the PS output of the PMIC. The boost converter is enabled or disabled by a GPIO output from the A64 SoC, controlled by software (e.g. the Linux kernel). Depending on inputs and decision made by the PMIC, PS may be at the battery voltage (fed "directly" by the battery through a transistor controlled by the PMIC), or at the "USB" voltage (fed by the PMIC's ACIN/VBUS inputs). This means that depending on a number of factors, USB-5V may be at battery voltage (between 3.0 V and 4.3 V), or at 5 V.
Because the PinePhone may act as a USB host (providing 5 V at the USB Type-C connector's VBUS to a connected device) or as a USB device (drawing from a 5 V source on the USB Type-C connector's VBUS), DCIN is actually not strictly an input nor an output. Some community analysis of the PinePhone schematic (and some testing) indicates that you can connect a 5 V power supply to DCIN in order to power the phone at the PMIC's ACIN/VBUS inputs (and, as a side effect, charge the battery). This may not be safe to do in all conditions, e.g., when the phone is acting as a USB host to a connected USB device. It should also be safe to use DCIN as a power output from the PinePhone, e.g., when a USB Type-C charger is connected, you can draw current directly from the USB Type-C port's VBUS, which is provided by the charger. Please note that, when using DCIN as an output from the PinePhone, DCIN isn't "always on"; it may be 0 V. It is currently not documented on how much current can be safely drawn.
USB-5V should be safe to use as an "always on" power output from the PinePhone. Depending on a number of factors, voltage may be from 3 V to 5 V; thus, if you are using USB-5V to power your pogo-pins expansion board, you will probably need to use DC/DC converters/regulators as appropriate. USB-5V is on even while the A64 SoC is powered down.
The I2C and interrupt lines have pull-ups on the phone side. The I2C lines are pulled up to 3v3 by the phone.
PINE64 store currently sells the PinePhone Flex Breakout Board. With the pitch being 2.54 mm, this Flex Breakout Board may have leads soldered directly to the contacts for use in a solderless board. A non-soldered solution would be to use a TE AMP Connector that will accept a Flat Flexible Cable 2.54 mm pitch.
Back cover
Community-built accessories
Serial console
Pinout of the serial adapter.
The UART is 115200n8.
  • Tip: RX
  • Ring: TX
  • Sleeve: GND
You can buy a serial debug cable from the PINE64 Store. The store cable uses a 4 ring plug, as seen in the here, but a 3 ring plug works just as well. The cable uses a CH340 chipset based serial to USB converter, but any 3.3v serial connection can be used. Because it is a "host"/DTE it means that you need a cross modem cable (Null Modem) with TX on Tip to be connected to RX. A cable like e.g. FTDI TTL-232R-3V3-AJ which has TX on Tip and RX on Ring fits perfectly.
Killswitch configuration
Detail of DIP switch
Camera
Battery
The EG25-G modem and the RTL8723CS WiFi and Bluetooth combo do not work without battery power, even when enough power is supplied to the PinePhone via the USB Type-C port.
The phone ships with a protective plastic sticker between the battery and the phone to protect the device from turning on during shipping. You need to gently open the back cover, then remove the battery and finally remove the sticker and check that the pins aren't bent. Note: If the battery is stuck inside the phone, the mid screw in the lower part of the midframe needs to be slightly loosened, see here.
Modem
The PinePhone uses Quectel EG25-G as modem. AT commands are used to communicate with the modem. To send them under Linux, you can use either minicom - sudo minicom -D /dev/EG25.AT - or the often-preinstalled atinout utility:
sudo su
atinout - /dev/EG25.AT out.txt << EOF
> AT+... command here
> EOF
cat ./out.txt # to see the result of a command execution
AT commands
A list of documented AT commands can be found in the File:Quectel EC2x&EG9x&EG2x-G&EM05 Series AT Commands Manual V2.0.pdf from Quectel. In example, to show the current IMEI number:
sudo su
> AT+EGMR=0,7
> EOF
cat ./out.txt # to see the IMEI
Also, there are certain undocumented AT commands. In example, to change the PinePhone IMEI number to a valid newIMEI one:
sudo su
> AT+EGMR=1,7,"newIMEI"
> EOF
cat ./out.txt # should output OK
Such a command has to be approached with caution: although in the majority of countries changing IMEI by itself is not illegal (or at least not prosecuted unless you are doing something malicious using this capability), still a cellphone service provider may ban your IMEI and/or phone number if it sees two cellphones with the same IMEI being used simultaneously. So it should be done with common sense: in example, if you don't want your cellphone service provider (or the governmental/commercial entities it could be supplying with information) to know that you have replaced your old phone, you could change the IMEI of your PinePhone to be identical to your old phone's, just avoid using them simultaneously or at least don't connect them to the same provider.
Further undocumented AT commands found by the developer megi, who reverse-engineered parts of the modem and its firmware, can be found on megi's website here.
VoLTE
AT+QMBNCFG="list"
AT+QCFG="ims",1
AT+CFUN=1,1
AT+CLCC
+CLCC: 1,1,0,1,0,"",128
+CLCC: 2,1,0,1,0,"",128
In the fourth item of the list, "0" means voice and and "1" means data. If both rows have "1" then the voice call is being carried over VoLTE.
APN settings
Carrier support
Documents
Firmware update
You can check the modem firmware version with a following AT command:
sudo su
> AT+QGMR
> EOF
If it is 01.001.01.001 (EG25GGBR07A08M2G_01.001.01.001), then it's recommended to update it to 01.002.01.002 (EG25GGBR07A08M2G_01.002.01.002) - because "002" has a better performance than "001", and according to Biktorgj it is more stable than the latest "003". However,
Pre-update checklist:
cd quectel_eg25_recovery
sudo ./qfirehose -f ./
Firmware modifications
GPS / GNSS
The GPS engine in the modem supports mutli-GNSS reception from GPS, GLONASS, BeiDou, Galileo and QZSS independent of a cellular connection. The operation of the GNSS subsystem is controlled via a separate set of AT commands. The AGPS data upload uses the file management AT commands, which also have their own manual. These are linked in the documentation section below.
As with most smartphones, the PinePhone has a small antenna and has difficulty getting a first fix without assistance data, a cold start can take 15 minutes under good conditions. While the hardware supports AGPS data upload, it isn't yet implemented in current distributions. There is a proof of concept script which can be made to work, but support needs to be added to ModemManager, oFono etc. before it will be easy to use.
Basic testing of GNSS reception can be done by using the AT command interface (/dev/ttyUSB2) from a terminal progam like minicom and the data output interface (/dev/ttyUSB1) to feed NMEA data into gpsmon or some other progam that can parse standard NMEA sentences.
cat /dev/ttyUSB1
$GPVTG,,T,,M,,N,,K,N*2C
$GPGSA,A,1,,,,,,,,,,,,,,,,*32
$GPGGA,,,,,,0,,,,,,,,*66
Voice mail
In Canada, Rogers voicemail can be called by dialing *98
Safety
Thermal Safety
With the Allwinner A64 being an older generation SoC with a large 40nm chip, the phone produces quite some heat with medium or higher use and especially also during charging or when using USB accessories, like a docking station. Measurements to prevent damage to the phone and to its surroundings need to be taken by the user. This includes especially a proper handling of the phone: do not charge the phone in a way where heat builds up around the phone without being able to escape. Especially don't charge your phone under a pillow, blankets, in pockets or bags. Charging the phone produces heat and charging the phone in a way, where the excessive heat can't dispose around the phone poses an immediate fire risk.
The user might notice that the phone gets warm under usage, compared to phones with more up-to-date hardware. Under normal circumstances these temperatures don't pose a risk while being in the levels within the safe operating temperatures (which lay far beyond the point where components can be too hot to touch). Higher temperatures might especially be experienced on the top side of the screen and on the inside of the phone at the RF shield of the modem. The higher temperature of the RF shield of the modem is commonly caused by the SoC on the opposite side of the mainboard, the RF shield of the modem is used to disperse heat of the SoC. In newer mainboard revisions starting from 1.2a there are also thermal pads on the back cover and between the SoC's RF shield and the screen, dispersing heat on the screen and on the back cover. In the past there has been safety issues regarding thermal safety functions, causing temperature reads to not properly work over an extended period of time, which was causing heat damage in some cases (see the documentation of that issue by the developer Megous here and here). While the developers are working hard to prevent such issues, they can't be excluded under all circumstances (see state of the software). The users are expected to monitor their phones' thermal safety at every point at this state of the software.
It is highly recommend to update the phone on a regular basis to always get the latest improvements. The default settings to throttle the performance and to shut down the phone when reaching critical temperatures might be set to a too high point depending on the specific usage and usage length. Under GNU/Linux the phone's thermal management behavior can be modified via the Thermal Sysfs driver to achieve lower temperatures and preventing the screen and other components to potentially take damage, see PinePhone Thermal Tweaks for the details.
Frequently asked questions
Modifications and repairs
Replacing the mainboard
Replacement boards come with an empty eMMC, which means that trying to boot from them looks like the board is faulty (no LEDs, no screen, no reaction of the phone). Please boot an OS from SD card.
A video tutorial by Martijn Braam can be found here (or alternatively a video tutorial by user brigadan with additional notes about the camera swap and proximity sensor isolator here):
Flashing the ANX firmware
Method 1
Download the latest ANX7688 firmware image on the phone:
Method 2
Booting a factory test image will automatically flash the ANX7688 chip. See Factory Test OS for such an image.
Replacing the screen
Spare parts not available in the PINE64 store
  • Earpiece dimensions: 12x6x2 mm. Compatible with Xiaomi Mi2 / Mi3 / Mi4, Lenovo A536 and others, see here
  • Loudspeaker dimensions: 15x11x3 mm. Compatible with Nokia N91, Lenovo A536 and others, see here
Press
Developer works
The following resources have been made available by Ondřej Jirman, a developer for the Pinephone:
External links
