User contributions for Diederik
Jump to navigation
Jump to search
- 12:45, 28 November 2023 diff hist 0 m ROCKPro64 Software Releases Debian: Recommend Bookworm as that's the current Stable current
- 15:02, 22 August 2023 diff hist +152 m Quartz64 Development →Upstreaming Status: RGA is mainlined in 6.5, but there are some 'issues'
- 23:04, 17 August 2023 diff hist +13 m Quartz64 Development →Upstreaming Status: TRNG patch is now archived
- 22:46, 17 August 2023 diff hist +131 m Quartz64 Development →Upstreaming Status: 4k@30 and other improvements since 6.4-rc1
- 22:43, 17 August 2023 diff hist −115 m Quartz64 Development →Partially Working: No longer consider Video Output buggy or Partially working
- 14:34, 1 August 2023 diff hist +24 m PineTab2 Fix USB tether with Android and Selecting a USB WiFi adapter link
- 21:58, 3 March 2023 diff hist −108 m PineNote Development/Building Kernel →Available Kernel Repositories
- 23:40, 25 February 2023 diff hist 0 m QuartzPro64 Development Update link to v4 of "AV1 stateless decoder for RK3588" patch series
- 14:34, 19 February 2023 diff hist −4 m ROCKPro64 Software Releases Fix LibreELEC download link (and fix LE capitalization)
- 16:17, 15 February 2023 diff hist +46 m Quartz64 Mention that bluetooth fix is included in 6.1-rc7
- 14:06, 5 February 2023 diff hist +61 m PineNote Development Mention non-free-firmware archive area for firmware in Bookworm and later releases
- 00:37, 5 February 2023 diff hist +33 m PineNote Development/TODOs Fix link to possible audio fix
- 14:07, 14 January 2023 diff hist −49 m PineNote Development point st-accel-i2c upstream link to actual commit of the driver
- 11:48, 14 January 2023 diff hist +7 PineNote Development Add reason why 'gpu' node in dts(i) hasn't been enabled upstream yet.
- 22:17, 13 January 2023 diff hist +5 m PineNote Development add missing 'when' word
- 15:09, 13 January 2023 diff hist +80 PineNote Development Copy link to upstreaming status for TF-A from Q64 dev page into rockchip-set notes
- 14:56, 13 January 2023 diff hist +131 PineNote Development Add more context on non-mainlineable status of rockchip-sip driver
- 19:58, 12 January 2023 diff hist −127 PineNote Development Moved items from 'Development work' into the table
- 19:49, 12 January 2023 diff hist −13 m Quartz64 Development Update link to v2 of TRNG patch submission
- 19:42, 12 January 2023 diff hist +154 PineNote Development Add link to rockchip-ebc's RFC [PATCH 00/16] drm/rockchip: Rockchip EBC ("E-Book Controller") display driver
- 19:36, 12 January 2023 diff hist +161 PineNote Development add links to rockchip-sip and ws8100-pen drivers commits
- 15:41, 12 January 2023 diff hist 0 m PineNote Development Fix rockchip-ebc.patch link ('_' -> '-')
- 18:19, 11 January 2023 diff hist −381 Quartz64 Link to Plebian images as that uses the Debian kernel and that works. No need to compile one yourself.
- 17:59, 11 January 2023 diff hist −361 Quartz64 Development Apart from u-boot, Plebian (https://wiki.pine64.org/wiki/Quartz64#Plebian) is built entirely from Debian, so remove the OS_Images section from the TODO
- 08:22, 11 January 2023 diff hist +146 PineNote Add link to PineNote development page
- 08:09, 11 January 2023 diff hist +181 PineNote Development Updated status for panfrost wrt PineNote as I think it's not yet enabled *for* PineNote
- 15:54, 10 January 2023 diff hist −1,176 m Quartz64 Development Shorten URLs to commits in Linus Torvalds repo
- 15:44, 10 January 2023 diff hist +14 m PineNote Development minor formatting fixes, mostly 'code' tag around component name
- 15:41, 10 January 2023 diff hist +457 PineNote Development Make formatting in line with Quartz development table
- 09:53, 18 November 2022 diff hist +709 m Quartz64 Ethernet works OOTB on Model-A with Debian's kernel using 'm'
- 22:20, 22 May 2022 diff hist 0 m ROCK64 Software Releases capitalize the 'l' in LibreELEC
- 01:54, 5 May 2022 diff hist 0 m QuartzPro64 Development Update 'Basic RK3588 Support' links on patchwork to v2 (from v1)
- 21:16, 2 May 2022 diff hist +9 m ROCK64 Software Releases Convert URL into clickable link; change 'as' -> 'and'
- 22:11, 28 April 2022 diff hist +205 N Talk:ROCK64 Software Releases Start discussion on the sequence of OS images, which seems random and inconsistent with the Rock64 page
- 22:05, 28 April 2022 diff hist −105 m ROCK64 →Quick Links to the Source of OS Images Build: Replace outdated LibreELEC links with the official one
- 22:02, 28 April 2022 diff hist +315 m ROCK64 Software Releases →LibreELEC(KODI): Fix DL link and minor spelling/spacing issues. Also add daily build info/link
- 21:53, 28 April 2022 diff hist +79 m ROCK64 Add source for Debian Installer
- 21:47, 28 April 2022 diff hist +86 m ROCK64 Fix 'debian by ayufan' link and add link to official Debian Installer images
- 21:38, 28 April 2022 diff hist +2 m ROCK64 Software Releases spelling
- 21:36, 28 April 2022 diff hist +1,761 ROCK64 Software Releases Add info and links to the official Debian Installer images
- 12:44, 22 April 2022 diff hist 0 m Quartz64 Development Upstreaming Status: update VOP2 to version 11
- 19:11, 28 March 2022 diff hist 0 m Quartz64 Development Update VOP2 patch series link to v9
- 10:30, 9 December 2021 diff hist −34 m Quartz64 Installing Arch Linux ARM Using 'unit X' is only needed when you don't specify a unit, so add a unit to the only one which hadn't and remove 'unit X'
