SOEDGE
Revision as of 08:41, 12 April 2023 by Fxc (talk | contribs) (→‎SoC and Memory Specification)
The SOEDGE
The SOEDGE is a 3TOPS compute module that can be paired with the SOEDGE Baseboard, the Clusterboard or USB 3.0 and PCIe adapters for development. It can connect to a SBC, such as the ROCKPro64 or a regular PC.
Software releases
The SOEDGE software releases can be found in the article SOEDGE Software Releases.
Based on the Rockchip RK1808.
  • Dual-core ARM Cortex-A35 Processor@1600-2000Mhz
  • A power-efficient ARM 64-Bit Armv8-A architecture
  • AArch32 for full backward compatibility with Armv7
  • VFPv4 Floating Point Unit
  • TrustZone security technology
  • Neon Advanced SIMD
  • DSP and SIMD extensions
  • VFPv4 Floating point
  • 128KB L2 cache
Neural Process Unit NPU Capability
  • RAM Memory Variants: 2GB DDR4.
  • Storage Memory: 128Mb SPI Flash and optional eMMC module from 16GB up to 128GB
Schematics and certifications
SOEDGE module schematics:
SOEDGE Neural AI Stick schematic:
SOEDGE/SOPINE/PINE A64 WiFi/BT module schematics:
SOEDGE module together with the baseboard certification:
  • Disclaimer: Please note that SOEDGE module is not a "final" product and in general certification is not necessary. However, SOEDGE module still submits the mpdel A baseboard for FCC, CE, and ROHS certifications and obtain the certificates to prove that can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
  • Not yet available
Rockchip RK1808 SoC information:
Rockchip RK809 PMU (Power Management Unit) information:
DDR4 information:
eMMC information:
SPI NOR Flash information:
SOEDGE Related:
Debugging
Serial Console
System Serial is located on PI-5 bus (11x2 GPIO header).
  • TXD: Pin 6 (Yellow cable) (Connect to RXD on Serial adapter)
  • RXD: Pin 8 (Orange cable) (Connect to TXD on Serial adapter)
  • GND: Pin 10 (Black cable) (Connect to GND on Serial adapter)
The default baudrate is 1500000, note that not all serial adapters support this high baudrate.
