SOEDGE Baseboard
Jump to navigation
Jump to search
The SOEDGE Baseboard is a baseboard that hosts the SOEDGE compute module and turns it into a full single board computer. Makers can use this baseboard as reference to develop their own PCBs and for software development during early stages for custom hardware or PCB development.
Specifications
- Gigabit Ethernet
- HD Digital Video Out
- 2x USB 3.0 Host
- Euler Bus
- Expansion Bus
- PI-2 Bus
- PCIe 4X open-ended header
- Touch Panel Port (TP)
- Display Serial Interface (DSI) Port
- IR R/X Port
- Real Time Clock Port (RTC)
- Lithium Battery Port
- SMOS Sensor Interface Port
- Optional AC WiFi + BT 5.0 module expansion module
- Headphone Jack
- 5.5″ Barrel Power (12V 3A/5A) Port
Features
Network
- 10/100/1000Mbps Ethernet
- WiFi 802.11 b/g/n with Bluetooth 4.0 (optional)
Storage
- microSD - bootable, support SDHC and SDXC, storage up to 256GB
- USB - 2 USB2.0 Host port
Expansion Ports
- DSI - Display Serial Interface, 4 lanes MiPi, up to 1080P
- TP - Touch Panel Port, SPI with interrupt
- RTC - Real Time Clock Battery Connector
- VBAT - Lithium Battery Connector with temperature sensor input
- Wifi/BT Module Header - SDIO 3.0 and UART
- 2x20 pins "Pi2" GPIO Header
- PCIe 2x open ended slot
Schematics and certifications
- Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
- Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
SOEDGE Model "A" Baseboard schematics and PCB board resources:
- SOEDGE Model "A" Baseboard Schematic 20210223 PDF file
- SOEDGE Model "A" Baseboard 20210223 PCB Component Placement Top PDF file
- SOEDGE Model "A" Baseboard 20210223 PCB Component Placement Bottom PDF file
SOEDGE module together with the baseboard certification:
- Disclaimer: Please note that SOEDGE module is not a "final" product and in general certification is not necessary. However, SOEDGE module still submits the mpdel A baseboard for FCC, CE, and ROHS certifications and obtain the certificates to prove that can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
- Not yet available
Ethernet PHY information:
