Quartz64
The Quartz64 Model B
The Quartz64 is the most recent Single Board Computer offering from PINE64, initially released in June of 2021. It is powered by a Rockchip RK3566 Quad-Core ARM Cortex A55 64-Bit Processor with a MALI G-52 GPU.
Key features include a PCIe x4 open ended slot (model A) or m.2 (model B) using one Gen2 lane electrically, and the use of LPDDR4 RAM.
The Quartz64 has three LPDDR4 system memory options: 2GB, 4GB or 8GB. For booting, there is an eMMC module socket (supporting up to 128GB) and microSD slot, as well as a footprint to solder on an SPI flash chip. The board is equipped with HDMI, 1x USB 3.0 type A Host, 3x USB 2.0 Host, Gigabit Ethernet, SATA (model A), GPIO Bus, MiPi DSI interface, e-ink interface (model A), eDP interface (model A), touch Panel interface (model A), MiPi CSI interface, as well as many other device interfaces such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals. Many different Operating Systems (OS) are freely available from the open source community, such as Linux (Ubuntu, Debian, Arch), BSD, and Android.
Software releases
Warning: Software for the Quartz64 is still early in development, and therefore currently lacks features such as the ability to produce video output. You are strongly encouraged to procure a 3.3V UART serial adapter capable of running at 1.5 mbauds, such as the woodpecker if you want to use a Quartz64 at this stage.
Manjaro ARM
Manjaro ARM is a user friendly rolling release distribution, based on Arch Linux ARM.
Manjaro ARM with no desktop
Manjaro ARM with desktop environment
Since Dev 20211117 with hdmi output (linux-rc)
  • Gnome
  • KDE Plasma
  • Mate
  • Sway
  • XFCE
Note: Video out only working on 4 GB boards with 1080p monitors right now as the VOP2 patches are very early.
pgwipeout's Quartz64 CI
pgwipeout provides continuously rebuilt set of images for Quartz64 devices which includes a Debian installer and a buildroot rescue environment. It is aimed at advanced users who generally know their way around a Linux system, and as a baseline for whether something is working or not. Works on both SD cards and eMMC, uses pgwipeout's patched kernel. Kernels aren't auto-updated on the installed system, so the user manually has to do this by mounting the actual correct boot partition.
Download: https://gitlab.com/pgwipeout/quartz64_ci/-/pipelines (Click the three dots on the right, download the merge-job archive.)
For Quartz64 Model A, flash rk3566-quartz64-a.dtb.img.xz. On Linux, you can for example do this as follows, assuming your target device is /dev/sdb:
sudo -i; xzcat /path/to/rk3566-quartz64-a.dtb.img.xz > /dev/sdb
Arch Linux ARM (Unofficial, Highly Experimental)
See Installing Arch Linux ARM On The Quartz64 for detailed instructions. Users who are not feeling adventurous are advised to hold off until kernel 5.16 is released and packaged.
Tianocore EDK II port by jmcneill
This (as of 2021-12-30) is a work in progress to enable UEFI enabled systems, and is able to bring up USB, PCIe with SATA and NVMe, HDMI, thermal sensors, TRNG, as well as general Cortex A-55 features. Known to work with NetBSD -current, and the ESXi Arm fling version 1.8.
SoC and Memory Specifications
  • 22nm process, believed to be FD-SOI
  • Supports Vulkan 1.0 and 1.1
NPU (Neural Processing Unit) Capabilities
  • RAM Memory Variants: 2GB (SOQuartz only), 4GB, 8GB LPDDR4.
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0 (optional on model A, built in on model B)
Storage
  • microSD - bootable, supports SDHC and SDXC, storage up to 2TB
  • USB
    • Model A: 2 USB 2.0 host ports, 1 USB 2.0 OTG port, 1 USB 3.0 host port
    • Model B: 1 USB 2.0 host port, 1 USB 2.0 OTG port, 1 USB 3.0 host port
  • one native SATA 3.0 6Gb/s Port (only on model A, shared with USB 3.0 host port)
  • optional eMMC module from 16GB up to 128GB
eMMC Speeds
On a 64 GB eMMC module:
 $ sudo hdparm -tT /dev/mmcblk1
 /dev/mmcblk1:
  Timing cached reads:   2368 MB in  2.00 seconds = 1184.46 MB/sec
  Timing buffered disk reads: 452 MB in  3.01 seconds = 149.98 MB/sec
Expansion Ports
  • HDMI
  • eDP - 4 lanes of 2.7Gbps, up to 2560x1600@60Hz (only on model A)
  • DSI - Display Serial Interface, 4 lanes MiPi, up to 1440P on model A, 2 lanes MiPi, up to 1080p on model B
  • CSI - CMOS Camera Interface, 4 lanes MiPi up to 8 mega pixel on model A, 2 lanes MiPi up to 5 mega pixel on model B
  • TP - Touch Panel Port, SPI with interrupt on model A
  • VBAT - Lithium Battery Connector with temperature sensor input on model A
  • Wifi/BT Module Header - SDIO 3.0 and UART on model A, build in Wifi/BT Module on model B
  • 2x20 pins "Pi2" GPIO Header on model B, 2x10 pins GPO header on model A
  • PCIe x4 open ended slot on model A, m.2 slot on model B, one Gen2 lane due to SoC constraints
    • On Model A, the slot provides 10W of power for the 3.3V supply and however much power your 12V input power supply provides on the 12V supply
The PCIe implementation on the RK3566 is much more compatible with a wide range of devices compared to the one on the RK3399 used on the ROCKPro64. This means a lot more devices should work (excluding dGPUs due to a lack of cache snooping ability). As an example, PCIe-to-PCI bridges work, whereas they didn't on the ROCKPro64.
Combo PHYs
Several of the I/O options on the RK3566 used in the Quartz64 are using the same I/O lines, meaning that they cannot be used at the same time. The above diagram illustrates how they are connected.
In particular, USB 3.0 and the SATA connector on the board are mutually exclusive, and the PCI-e 2.0 lane can be reconfigured into a second SATA port, though an adapter cable needs to be fashioned for this to be useful.
GPIO Pins (Quartz64 Model A)
Attention! GPIOs are 3.3V!
Assigned To Pin Nr. Pin Nr. Assigned To
3.3 V 1 2 5 V
I2C3_SDA_M0 a,b 3 4 5 V
I2C3_SCL_M0 a,b 5 6 GND
CPU_REFCLK_OUT 7 8 UART2_TX_M0_DEBUG
GND 9 10 UART2_RX_M0_DEBUG
SPI1_MOSI_M1 11 12 UART0_TX a
SPI1_MISO_M1 13 14 UART0_RX a
SPI1_CLK_M1 15 16 GND
SPI1_CS0_M1 17 18 SPDIF_OUT c
GND 19 20 3.3V
Notes
  1. can be a PWM pin
  2. pulled high to 3.3V through 2.2kOhm resistor
  3. low-pass filtered with cutoff of 220 MHz
Source: Page 28 of the board schematics.
Quartz64 Board Information, Schematics, and Certifications
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5mmOD/2.1mmID center-positive Barrel DC Jack connector
  • Model "B" Baseboard Dimensions: 85mm x 56mm x 18.8mm
  • Input Power: DC 5V @ 3A 3.5mmOD/1.35mmID Barrel DC Jack connector
  • Certifications:
    • Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary. However, PINE64 still submit the SBC for FCC and CE certification and obtain the certificates to proof that SBC board is capable on passing the testing. Please note a final commercial product needs to performs its owns testing and obtains its owns certificates.
    • Quartz64 model-A CE Certificate
    • Quartz64 model-A FCC Certificate
Development efforts
Information and resources of the ongoing development effort for the Quartz64 can be found on the Quartz64 Development page, where the current status of various board functions can be found, and whether they have landed in upstream.
BSP Linux SDK
BSP Linux SDK ver 4.19 for Quartz64 model A SBC
Android SDK
Android 11 SDK for Quartz64 model A SBC
Android 11 Production Test Build for Quartz64 model A SBC
Android 11 Stock Image [eMMC Boot] using DD method [20210604]
  • DD image to eMMC module using USB adapter for eMMC module and boot. Highly recommend using Etcher
  • This is test build that used during product testing
  • DD image for 8GB eMMC module
  • DD image for 16GB eMMC module
  • DD image for 32GB eMMC module
  • DD image for 64GB eMMC module
Android 11 Production Test Build for Quartz64 model A SBC [eMMC Boot] using ROCKChip tools method [20210604]
  • Please unzip first and then using Rockchip Android tool ver 2.84 to flash in
  • For Windows OS environment, please install the DriverAssistant v5.11 driver first
  • The OTG port located at top USB 2.0 port on top of USB 3.0 port, needs USB type A to type A cable.
Android 11 eink SDK for Quartz64 model A SBC
Enclosures
All enclosures that fit the ROCKPro64 should fit the Quartz64, as the I/O has been laid out the same on purpose.
(Please expand this section with more cases known to work.)
Troubleshooting
Stability/Boot Issues With Missing Battery Shunt
If there is no battery plugged into the board, the jumper labelled "ON/OFF_BATT" must be in place. If this is set wrong, stability issues such as failures to boot will occur.
No Ethernet Connectivity
Make sure the kernel is built with CONFIG_MOTORCOMM_PHY set to y. Building it as a module (m) and then relying on module auto-loading is unlikely to work as the PHY chip lacks its manufacturer ID.
"Model A" Acrylic Case Doesn't Fit
The Quartz64 does not really fit onto the bottom plate of the "Model A" Acrylic Open Enclosure. This is because the "Mic" connector at the bottom of the board interferes with one of the posts. A workaround is to find out which post that is (you have a 50% chance of guessing it right, accounting for rotating the board) and then filing away the corner of the post pointing inwards by a few millimetres.
An alternate solution may be to place plastic spacers with a smaller outer diameter in between the acrylic bottom plate posts and the SBC board.
No GPU Acceleration with Debian "Bullseye" Userland
Debian Bullseye ships a Mesa version that is too old to contain the required patches for the RK356x SoC's GPU. You can (at your own risk) use the current Debian Testing version , called "Bookworm".
