Pinecil
Pinecil is a portable soldering iron with computer controlled temperature, sleep modes, motion detection, and allows many options for power from AC supplies (USB-C, DC Barrel) to external tool/lipo batteries. You may already have a power supply that works. It also has the intended use of being a RISC-V development device using a breakout board. The Pinecil has evolved over the years from a 60W device into the latest rendition, the V2, which supports 24V/88W and includes the new Pine64 designed shorter tip.
Note: Other irons only care if they can solder. The Pinecil is held to an additional standard; how well can it meet the needs of the open source community as a RISC-V development tool. It includes hardware features not found on other soldering irons in order to support FOSS community feature requests for both fun and science.
Pinecil V2, side view
Main features
  • Soldering tips:
  1. Replaceable and low cost
  2. Many styles: Currently sold as 2 separate sets of 4, one fine set, the other larger.
  • Multiple power sources will work for more flexibility:
  • V2 model allows BLE bluetooth control because of the switch to the Bouffalo BL706 MCU.
Authenticity
There are no PINE64 Pinecils sold on AliExpress. They are not made by PINE64. There are no authorized resellers on AliExpress. Some manufacturer has copied the PINE64 company name, trademark and Pinecone logo and is selling a product made to look like Pinecil through many store fronts, but it is not an authentic. They use a different type of box, i.e., a blue or red box. They are fake copies and do not go through the same quality control as Pine64. It is unclear what type of chips or poor quality cloned chips are used in them. They are not recommended. Genuine Pine64 Pinecil only comes in a black handle color with a silicone thumb grip. The original V1 always came in a black box. This model was discontinued and has not been made or sold by PINE64 or authorized resellers since July 2022.
Pinecil V2 comes with a unique internal ID/Serial number. This allows people to check if the Pinecil V2 is Authentic. To be more sure, update to the newest stable Ralim's IronOS and check again, see Firmware.
Where to buy a Pinecil
PINE64 Official Stores
PINE64 EU
Affiliates
In July 2022, all final stock sold out of PINE64 Pinecil V1 (with GD32VF103 MCU) at the Pine Store & all resellers. There are zero new authentic Pinecil V1 sold in the world after July 2022. Pinecil V1 was made in a black color with a light blue finger grip. PINE64 never made an all-blue Pinecil, and never used blue or red color boxes (those are fake copies with fake PINE64 logos and Pinecone).
Starting Aug. 2, 2022, only the new Pinecil V2 model with the new BL706 BLE bluetooth MCU are made by PINE64 and sold at all authentic resellers. They are black with a green finger grip (see photos in the Picture section). The new model has anti-counterfeiting features. Authentic Pinecil using the newest official Github IronOS firmware, will successfully pass the Authenticiy Checker website. If a new Pinecil (post Aug. 2022) does not have a BL706 chip, then it is a fake counterfeit. If the AliExpress seller tries to show "CE certification" documents as some type of proof, those are all copied public info from this Wiki page in the Certifications section. PINE64 publishes those as they are the CE/FCC certifications for the stamps on the Pinecil. They are not proof of purchase from the Pine Store Ltd.
Shipping & Tracking
See the Pinecil Shipping and Tracking article, which includes:
  1. How does it work?
  2. Courier options
  3. Tracking
Usage
Overview
1. Install the tip: The Pinecil comes with a separate heating element, the tip.
  2. Gently tighten or loosen this screw to install or swap the tip. (careful, tiny screws break easy, if tip does not fall out, it's tight enough)
  3. The bottom front screw should not touch the tip, it only holds the handle together (see Fasteners).
2. Supply power: the USB-C port, connected to any supply, is enough power to show the display screen, but not necessarily enough to heat the tip.
3. Heat the tip: plug Pinecil into an appropriate power supply.
  2. The detailed display option shows power draw, current temperature, supply voltage, and time until sleep mode starts.
4. Using the Settings Menu:
  1. To check the firmware version, hold down the [-] button. It will display something like "v2.19.A3BBABC 13-07-22". This is the firmware number and release date, the date is July 13, 2022 in the example.
  2. Clicking [-] when heat is off steps through main categories menus to control a variety of settings, see Getting started with menus section.
  4. Click [-] to scroll to the the main menu section desired (i.e., User Interface). Then Click [+] button to change various internal settings. Then click [-] again to go to the next item in the sub-menu.
5. Important notes:
  2. Calibration of the Tip temperature is usually not necessary and should only be done if the tip is off by +/- 5 °C or temperature is behaving oddly. See instructions to calibrate the tip in the firmware on Github IronOS.
  4. To heat up the tip, we need a power supply that can provide at least 12V 3A to run. This is the bare minimum. Pinecil will heat slowly at only 12V/3A. To maximize performance, higher Volts/Amps/Watts is recommended (see Pinecil Power Supplies).
    1. Option 1: a USB-C supply that can negotiate up to such a voltage. For good performance and soldering experience, a USB-C PD65W, 20V, 3+ A charger is recommended (suitable for most users).
    3. Option 3: use a battery, i.e., an 18V-21V tool Battery with a Power Wheels adapter, and a cable to plug into the Pinecil DC5525 barrel jack.
    4. You may have a suitable supply already that could be used, (see Pinecil Power Supplies).
    5. While 12V-3A will work, it will not heat the tip as quickly and efficiently as a PD65W-20V Usb-C charger or a higher rated DC barrel charger.
Getting Started with the Menu
  1. Getting Started Guide in Github/IronOS
  2. Main Settings Menu: updated list is found in the firmware repository Settings Menu
  3. Hidden Debug Menus: also available, see GitHub/IronOS
Optional Advanced Modifications
Live Community Chat
  • Need troubleshooting advice for the PINE64 Pinecil soldering iron? Join through one of the Community Chat links below.
  • Note: the live chat is bridged to Discord, Telegram, Matrix and IRC. Those bridges will not have all the features available within all platforms, but the chat is relayed between all four.
  • Live chat has volunteer members that are not paid PINE64 employees, but occasionally get official information.
  • The pinecil channel is the most popular for questions and troubleshooting such as help installing firmware or use of Tips (and where most people discuss pinecil/soldering). The pinecil-dev channel is a more limited chat for developers working on software/firmware such as IronOS or the new BLE bluetooth apps.
  1. Discord
  2. Telegram
  3. Matrix
Firmware & Updates
See the Pinecil_Firmware article for instructions on how to update Pinecil, this includes:
  1. Overview
  2. Flash Mode
  3. Update V2: Windows
  4. Update V2: Linux and Mac
  5. Troubleshoot V2 Flashing
  6. Build the Blisp Flasher from Code
  7. Update V1
  8. General Firmware Details
  9. Problems with IronOS firmware? Read documents here. If the answer is not found, open a ticket here or join the live pinecil community chat.
Development Projects
Author Project Homepage Description Supported
Ben Brown (ralimtek) Ralim's IronOS Official Pinecil firmware BL706, GD32VF103TB, Stm32f103
Marek Kraus (gamiee) Pinecil V2 Flasher CLI Updater for Pinecil V2, BL70x MCU Windows, Linux, Mac
Marek Kraus (gamiee) Pinecil V1 Flasher Pinecil V1 GUI Updater Windows, Mac
Arkaitz Goni Hedger (spagett) PineFlash V1 Flasher Pinecil V1 GUI Updater Linux, Mac
Joric (iamjoric) BLE API for V2 Github dev page Windows, Linux, Android
Robert (builder555) PineSAM BLE script for Pinecil V2 settings Windows, Linux, Mac
Bouffalo Lab B-Lab Dev Cube MCU vendor GUI for Dev/flashing BL70x, BL60x, others
Alvin Wong gd32vf103-pinecil-demo-rs Rust code demos for Pinecil GD32VF103TB
Checklist
Pre-notes:
  • 1. Clean new tips with isopropyl alcohol to remove factory residue before installing (avoid strange behavior from poor contact). If you have none, try to wipe it down with dry clean towel especially the 2 contacts at the back (do not use water, it could get into the small white seam line).
  • 2. Don't bend the tiny internal contacts, they are thin spring metal and may break.
  • 3. Only use one port, USB-C or the DC barrel, but Never both at the same time. Damage will occur to PC/ Laptop/ Pinecil !
    • Caution: do not plug in both USB-C and DC5525 at the same time. This will destroy devices, posibly your laptop/pc.
  2. It gets full power.
    • Check both orientations of the type C cable (try to flip it if one way doesn't work)
  3. Check Update mode (see Ralim/IronOS for details on flashing updates)
    • Note: do not connect the DC barrel at the same time as a USB-C cable. Pinecil was designed to only have one cable plugged in a a time. You could damage devices doing this.
    • V2 needs a different type of Updater/flasher which will be announced on Github/Ironos when a new release is available.
      • V2 owners with EPR 28V chargers are advised to join the Community chat linked in the wiki & use Beta 2.20 firmware until stable is released.
      • If you have issues with V2 firmware, create a new Github Issues ticket
    • V1 can use Pine64 Easy Updater here (Windows/MAC)
    • Requires a data capable USB cable connected to a laptop or some appropriate device.
    • To enter update mode, hold down [-] (button near back/ground screw) while plugging in USB cable.
    • Screen is black/blank if you are correctly in update mode. This can be tested even if you are not updating the firmware.
  4. Both buttons work
    • - to enter menu or decrease temperature, long press to get software version info or to turn off heating
    • + to turn on heating or select a menu item
  6. All 3 external screws are present
    1. One near the back near the screen (ground screw)
    3. One at the front on the bottom (to hold the case together)
  7. The tip is clean (uniformly silver at the front, with no pitting or texture)
    • most tips come with pre-dipped in solder for protection. heat them up, clean with brass or solder sponge and inspect.
    • See #Pinecil Tips and #Guides to Soldering & Maintenance for maintenance and soldering hints
  8. It heats up an installed tip, and stops increasing when it reaches the set point
    • This may draw up to ~3A, make sure the power supply can provide that
    • Minor overshoot may occur, but, disconnect power if the temperature keeps going up
  9. The reported temperature is correct
    • If no direct measurement is possible, set it to ~230°C and see if it just about melts SAC (lead-free) solder (~190°C for leaded)
  10. If there are multiple tips, clean all of them with IPA and check all of them.
  11. If the tip moves a little while using it, try to hold Pinecil with the screen sideways or screen downwards. Members found that if the screen is up and the screw loosens during use, then the tip wobbles a little. Changing holding angles helps the tip press against the solid barrel.
Power Supplies and Watts
Generally, higher watts is better, up to how much you can afford.
Power Chart
Power Notes
* PINE64 officially states the Pinecil V2 will support up to 24V-88W. Tentatively, the V2 also unofficially supports 28V-140W EPR/PD3.1 chargers with certified EPR 240W USB-C cables.
  • Ralim's IronOS firmware works with the PD3.1 protocol (EPR 28V-140W chargers) on Pinecil V2.
  • EPR USB-C is new to the market in 2022. The chargers are more expensive and require EPR PD 3.1, 240W cables to maximize the power to V2.
  • EPR is backwards compatible for all USB-C devices. EPR chargers/cables can be used for everything else USB-C as well.
  • Pinecil is not a USB-C tester: when the detailed screen is enabled on Pinecil, note that these are estimates and are at best +-10%. The watts shown on detailed mode is a big picture number for convenience and debugging various chargers used. It is not going to be as accurate as an external tester. Use external metering for comparisons or testing (external also testers cause a small reduction in Watts).
QC Chargers
Many Quick Charge or QC3 phone chargers are not recommended as Pinecil V2 requires a minimum of 3 Amps or more to work properly (see Pine Store Official rating on power ports). Most QC 12V phone chargers are only 1.5 Amps, this will lead to Thermal Runaway or Undervoltage messages because of weak power (older QC2 type is not supported in the IronOS firmware at all).
Compatible Power Supplies
Go to the Pinecil Power Supplies article for a list of compatible power supplies and cables and instructions on how to set up a variety of choices.
Specifications
Pinecil V2
  • Chipset: Bouffalo BL-706
  • Memory:
    • 192KB Internal Flash
    • 132KB SRAM System
Pinecil V1
  • Memory:
    • 128KB Flash
    • 32KB SRAM
Fasteners/Screws
  • Originals screws are Phillips (source): two M2x3mm at the front, and one M2x4mm is the ground screw near the [-] minus button.
Thumb Screws
  • Thumb screws are popular upgrades: an M2 x 4mm thumb screw could replace both, the screen-side Tip holder screw, and the rear end ground screw.
Manuals
Disassembly steps
Easy trick to open the Pinecil, see Video here.
  13. Remove the round copper ring contact from under the PCB, near the tip end of the handle (this is installed first before the PCB because it provides ground contact from the front of the pinecil to the rear ground screw).
  14. Remove the two small round buttons so they do not get lost.
Assembly steps
  1. Place the two round buttons into the two holes in the top half of the case.
  2. Install the round copper ground contact at the tip end before installing the PCB.
  3. Place the PCB board into handle at an angle, DC barrel end goes in first.
  10. Gently insert tip.
Pictures
Pre-release:
Production:
Tips:
PCB:
Accessories:
Pinecil Tips
Details on the Pinecil Tips can be found in the Pinecil Tips article.
  1. What kind of tips work?
  2. How to increase tip life?
  3. How does the tip work?
  4. Pine64 Short tips
  5. Pine64 Normal tips
Note: Pay attention to the length! Pine Store sells two different lengths.
The guides regarding soldering and maintenance can be found in the Pinecil Guides to Soldering article. The article includes the following topics:
  1. General soldering guides
  2. Does solder type and flux matter?
  3. How to keep the tip clean?
  4. What temperature should I use?
Cases, Stands, 3D models, Supplies
The main article about cases, stands, 3D-models and supplies can be found under Pinecil Cases, Stands, Supplies.
  1. Cases and bags
  2. Holders and stands
  3. 3D models
  4. Soldering supplies
Batch changes
V2
  • On Aug. 2, 2022, Pinecil V2 was released with improved hardware & accessories. It retains the same ergonomics and design as the original Pinecil, and will work with any accessories you already have including existing cases and tips. It comes with a green color silicone grip versus the light blue finger grip from Pinecil V1. It also includes one of Pine64's newly designed shorter 6.2 ohm tips. By reducing the tip resistance from 8 to 6.2 ohms, it allows greater performance and and faster heating (64W @ 20V compared to 8ohm tips which allowed a max of 50W to Pinecil). Pinecil V2 is rated for 12V-24V.
  • Key changes in V2: new processor (BL706), higher maximum input voltage (24V), tentative support for USB-PD3.1 EPR (28V), support for measuring tip resistance, allows automatic detection of 6.2 vs 8 ohm tips. A notable improvement is the new BL706 RISC-V processor from Bouffalo. It is similar to the BL602 in the Pinenut. The BL706 features Bluetooth Low Energy (BLE / Zigbee); future IronOS firmware releases will work to expose features over BLE. This is not trivial work, but as people contribute to the opensource code of Github/IronOS, the BLE will be expanded.
V1
  • For the first manufacture batch (October 2020, order number 158xxx) of the Pinecil, the copper ring connecting the earth screw to the tip was omitted as the engineering team found the TS100 design lacking. For the second round onward, an improved design copper ring has been included as standard, and is also included with the replacement clear and black handles. For normal operation of the iron, omission of the ring does not impact it's operation. If you are working with ESD components, you will need it in order to ground the iron tip via the earth screw at the back of the iron.
  • The first batch of Pinecils were rated 12-24v @ 65W. After some heated discussion on the discussion group, it was decided that it would be downgraded to 12-21V @ 60W, due to concern over the connection of the DC jack to the USB-PD chip, which has a recommended maximum of 21v, and absolute maximum of 28v.
Schematics, Board Data, Certifications
Pinecil V2 mainboard schematic
Pinecil V2 Certifications:
Pinecil V1 mainboard schematic
V1 was only sold until July 2022, and then discontinued for newer V2 model.
Pinecil V1 Certifications:
Pinecil Breakout board
Get the Breakout Board here
Photos:
Datasheets for Components
Pinecil V2
USB-C PD Controller data:
Power Regulators:
Sensor data:
Power MOSFET Switch:
Operational Amplifier:
Display Screen OLED:
MCU: Bouffalo Labs, BL-706_QFN48, RISC-V + 2.4 GHz RF SoC Information:
USB-C port:
Pinecil V1
GigaDevice RISC-V SoC data:
Sensor data:
Display Module data:
USB Type-C PD Controller data:
Power Regulator data:
Power MOSFET Switch data:
OP Amp information:
Capacitors:
LowPowerSemi LP6498B6F 1.2A Switching Power Regulator Datasheet - on breakout board
USB-C port:
Pinecil in the Media
Humor
Video Reviews
Pinecil V2 Reviews
Pinecil V1 Reviews
