PinePhone
Revision as of 00:14, 12 March 2021 by Fxc (talk | contribs) (Ordered the sections)
The PinePhone is a smartphone created by Pine64. The PinePhone is capable of running mainline Linux and is supported by many partner projects. The Braveheart Edition of the PinePhone was the first publicly available version of the phone; it shipped without a fully functional OS and was geared specifically toward early adopters. The Braveheart Edition's successor is the Community Edition. The Community Edition became available in June 2020. The Community Edition will be available for at least five years after its initial release.
First time installation
Rendering of the PinePhone.
The default PIN for the KDE Community Edition is 123456.
  1. Remove the back panel using the notch in the corner of the back cover
  2. Remove the battery
  4. Reinsert the battery
See Battery for more information.
The PinePhone's SIM slot requires a micro SIM, please do not insert a nano SIM without an adapter. An adapter from a nano to a micro SIM might be included under orange tape in the camera notch of the phone's packaging. The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot, as pictured here:
Specifications
Weight: Between 180-200 grams
SIM Card: Micro-SIM
Display:
System on Chip: Allwinner A64
RAM: 2GB or 3GB LPDDR3 SDRAM
Internal Storage: 16GB or 32GB eMMC, extendable up to 2TB via microSD, supports SDHC and SDXC
Communication: G25-G
Bluetooth: 4.0, A2DP
Components
Component Model
Touchscreen Goodix GT917S
Rear camera OmniVision OV5640
Camera flash SGMICRO SGM3140
LCD Xingbangda XBD599
WiFi Realtek RTL8723CS
Bluetooth Realtek RTL8723CS
Modem Quectel EG25-G
GNSS/GPS Quectel EG25-G
Magnetometer ST LIS3MDL
Vibration motor Unknown model
Notification LED LED0603RGB
Power button X-Powers AXP803
Hardware revisions
  1. Project Anakin
  5. PinePhone v1.2‎ - Ubports Community Edition
  6. PinePhone v1.2a - postmarketOS Community Edition
  7. PinePhone v1.2b - Manjaro Community Edition, KDE Community Edition, Mobian Community Edition
Hardware accessory
USB-C connector
The USB-C can be used to power the device, and offers USB2 host and OTG possibilities, and also can make use of the USB-C capability to integrate HDMI signals. Some USB-C hubs are available that offer power throughput, USB connection, HDMI port and Ethernet connection.
Pogo pins
The pogo pins, as visible under the back cover, with an additional grid view in the table below.
Interrupt SDA SCL
DCIN USB-5V GND
DCIN and USB-5V are the names used in the schematics. The actual behavior of these pogo pins is not obvious based on their names, so please do not make any assumptions.
DCIN is connected both to the VBUS line of the USB Type-C connector, and to the ACIN/VBUS inputs on the PMIC. This means that, depending on a number of factors, DCIN may be at 0 V or 5 V.
USB-5V is connected at the output of an LP6226 DC/DC boost converter (5 V), which in turn is fed by the PS output of the PMIC. The boost converter is enabled or disabled by a GPIO output from the A64 SoC, controlled by software (e.g., Linux kernel). Depending on inputs and decision made by the PMIC, PS may be at the battery voltage (fed "directly" by the battery through a transistor controlled by the PMIC), or at the "USB" voltage (fed by the PMIC's ACIN/VBUS inputs). This means that depending on a number of factors, USB-5V may be at battery voltage (between 3.0 V and 4.3 V), or at 5 V.
Because the Pinephone may act as a USB host (providing 5 V at the USB Type-C connector's VBUS to a connected device) or as a USB device (drawing from a 5 V source on the USB Type-C connector's VBUS), DCIN is actually not strictly an input nor an output. Some community analysis of the Pinephone schematic (and some testing) indicates that you can connect a 5 V power supply to DCIN in order to power the phone at the PMIC's ACIN/VBUS inputs (and, as a side effect, charge the battery). This may not be safe to do in all conditions, e.g., when the phone is acting as a USB host to a connected USB device. It should also be safe to use DCIN as a power output from the Pinephone, e.g., when a USB Type-C charger is connected, you can draw current directly from the USB Type-C port's VBUS, which is provided by the charger. Please note that, when using DCIN as an output from the Pinephone, DCIN isn't "always on"; it may be 0 V. The community doesn't know how much current can be safely drawn.
USB-5V should be safe to use as an "always on" power output from the Pinephone, though the community doesn't know how much current can be safely drawn. Depending on a number of factors, voltage may be anywhere from 3 V to 5 V; thus, if you are using USB-5V to power your pogo-pins expansion board, you will probably need to use DC/DC converters/regulators as appropriate. USB-5V is on even while the A64 SoC is powered down. It may also actually be possible to connect a 5 V power source to USB-5V as an input to the Pinephone under particular conditions, and at a safety risk, but as of now this is unconfirmed.
There is ongoing discussion/analysis of the pogo pins by the community; see this forum thread for further information. Much is now understood, but not everything is clear. It would be best for the Pine64 organization to officially comment on (and document) the hardware design intent for each pogo pin. In the meantime, use the DCIN and USB-5V pogo pins at your own risk. (We don't know how much current can be safely drawn. We don't know when it's safe to provide power to the phone. We don't know if a pogo-pins expansion board could drain the battery too far while the phone is "off", etc.)
The I2C and interrupt lines have pull-ups on the phone side. The I2C lines are pulled up to 3V3 by the phone.
Back cover
Community-built accessories
Serial console
The UART is 115200n8.
  • Tip: RX
  • Ring: TX
  • Sleeve: GND
Killswitch configuration
Detail of DIP switch
Camera
Battery
The EG25 modem and RTL8723CS WiFi and bluetooth do not work without battery power, even if you are supplying enough power to the PinePhone with USB-C.
The supplied battery is meant to be compatible with Samsung part number EB-BJ700BBC / BBE / CBE from the 2015 J7 phone.
  • The extended life aftermarket BBU does fit, although it is a tight fit.
  • There is a report that the EB-BJ700CBE isn't quite the same size, causing the back not to fit the Braveheart Edition properly.
  1. +ve
  2. thermistor
  3. -ve
  4. not connected
If your battery is hard to remove from the phone, try loosening the screws in the midframe around it, which is pressing against the battery. Possibly cutting up a piece of plastic and sliding it under the battery as a pull tab can work too.
Photo of Braveheart Edition battery sticker from OSAKANA TARO on Twitter
Modem
The PinePhone uses Quectel EG25-G as modem. AT commands are used to communicate with the modem. The software minicom can be used to send the commands.
To connect with the modem:
minicom -D /dev/ttyUSB2
AT commands
A list of documented AT commands can be found in the EC25&EC21 AT Commands Manual from Quectel. Further undocumented AT commands found by the developer megi, who reverse-engineered parts of the modem and its firmware, can be found on megi's website here.
VoLTE
AT+QMBNCFG="list"
AT+QCFG="ims",1
AT+CFUN=1,1
AT+CLCC
+CLCC: 1,1,0,1,0,"",128
+CLCC: 2,1,0,1,0,"",128
APN settings
Carrier support
Documents
Firmware update
The modem firmware can be updated to the latest version if it is outdated and dmesg returns the following message:
modem-power serial1-0: Your modem has an outdated firmware. Latest know version is EG25GGBR07A08M2G_01.002.07. Consider updating.
Pre-update checklist:
cd quectel_eg25_recovery
sudo ./qfirehose -f ./
Firmware modifications
Voice mail
In Canada, Rogers voicemail can be called by dialing *98
GPS / GNSS
The AT commands for the GNSS are in a separate manual from the more general AT command documentation. The AGPS data upload uses the file management AT commands, which also have their own manual. All are linked in the documentation section below.
As with most smartphones, the PinePhone has a small antenna and has difficulty getting a first fix without assistance data. While the hardware supports this, it isn't yet used by the software in the distros. There is a proof of concept script which can be made to work, but support needs to be added to ModemManager, oFono etc. before it will be easy to use.
Operating Systems
Software releases
Installation instructions
Flashing eMMC using Jumpdrive
Detailed usage instructions
Resize file system (optional)
Many OSes already include a script, which is resizing the partition on first boot, where this step is not required.
If you flash a 4GB image distribution to your eMMC, your eMMC will only have a 3.7GB partition on it. To use the entire 14.7GB on the eMMC, run the following commands:
  1. sudo cfdisk /dev/sdX
  2. Change to [Resize] in the ncurses program, resize the 3.7GB partition to 14.7GB, and [Write]
  3. sudo resize2fs /dev/sdXY
Feedback
Frequently asked questions
Modifications and repairs
Replacing the mainboard
Alternatively, user bridadan uploaded a video tutorial of the swap procedure including camera swap and proximity sensor housing here: https://www.youtube.com/watch?v=J3AJEF7akkw.
Flashing the ANX firmware
Method 1
This method is currently not compatible with the Linux kernel 5.10.
After swapping the mainboard the ANX chip has to be flashed for full USB functionality.
Download the latest ANX firmware image on the phone:
Method 2
Booting a factory test image will automatically flash the ANX chip. See PinePhone Software Releases#Factory-loaded postmarketOS build for such an image.
Replacing the screen
  • The vibrator motor, which is part of the USB-C board assembly and glued into place, will come apart easily and be damaged if you pry it up in the wrong place. Make sure you pry from underneath the complete part, not midway on its housing. The ribbon cable attaching this to the USB-C board is small, thin, and fragile so be careful with that as well.
Spare parts not available in the Pine64 store
  • Earpiece dimensions: 12x6x2 mm. Compatible with Xiaomi Mi2 / Mi3 / Mi4, Lenovo A536 and others, see here
  • Loudspeaker dimensions: 15x11x3 mm. Compatible with Nokia N91, Lenovo A536 and others, see here
Press
Developer works
Megous
External links
