PinePhone
Revision as of 14:47, 25 November 2020 by Fxc (talk | contribs) (→‎Resize file system: Removed draft article link)
First time installation
The default PIN for the Manjaro Community Edition is 123456.
PinePhone is capable of running a multitude of different Linux mobile OSes
Rendering of the back and front of PinePhone
After unboxing remove the back panel using the notch in the corner of the back panel. Then remove the battery and peel off the clear plastic sticker below it that isolates the charging contact. Then replace the battery, see Battery for more information.
The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot, as pictured here:
Specifications
Weight: Between 180-200 grams
SIM Card: Micro-SIM
Display:
System on Chip: Allwinner A64
RAM: 2GB or 3GB LPDDR3 SDRAM
Internal Storage: 16GB or 32GB eMMC, extendable up to 2TB via microSD, supports SDHC and SDXC
Communication: G25-G
Bluetooth: 4.0, A2DP
Components
Component Model
Touchscreen Goodix GT917S
Rear camera OmniVision OV5640
Camera flash SGMICRO SGM3140
LCD Xingbangda XBD599
WiFi Realtek RTL8723CS
Bluetooth Realtek RTL8723CS
Modem Quectel EG25-G
GNSS/GPS Quectel EG25-G
Magnetometer ST LIS3MDL
Sixaxis InvenSense MPU-6050
Vibration motor Unknown model
Notification LED LED0603RGB
Power button X-Powers AXP803
Hardware revisions
  1. Project Anakin
  5. PinePhone v1.2‎ - Ubports Community Edition
  6. PinePhone v1.2a - postmarketOS Community Edition
  7. PinePhone v1.2b - Manjaro Community Edition
  9. Place the new mainboard in the chassis, hooking in on the plastic tabs on left side and pressing down firmly on opposite side, and follow the steps (7-2) in reverse.
Watch Martijn Braam's video tutorial here, https://youtu.be/5GbMoZ_zuZs
Hardware accessory
USB-C connector
Pogo pins
Interrupt SDA SCL
5V / VBUS VBAT GND
The VBUS pin is powered by USB and is 5V. The second power pin is VBAT, which connects to the battery voltage. The I2C and interrupt lines have pull-ups on the phone side. The I2C lines are pulled up to 3V3 by the phone.
Back cover
Serial console
The UART is 115200n8.
  • Tip: RX
  • Ring: TX
  • Sleeve: GND
Killswitch configuration
Detail of DIP switch
Camera
Battery
The EG25 modem and RTL8723CS WiFi/bluetooth do not work without battery power, even if you are supplying enough power to the PinePhone with USB-C.
The supplied battery is meant to be compatible with Samsung part number EB-BJ700BBC / BBE / CBE from the 2015 J7 phone.
  • The extended life aftermarket BBU does fit, although it is a tight fit.
  • There is a report that the EB-BJ700CBE isn't quite the same size, causing the back not to fit the BraveHeart Edition properly.
  1. +ve
  2. thermistor
  3. -ve
  4. not connected
If your battery is hard to remove from the phone, try loosening the screws around it. Possibly cutting up a piece of plastic and sliding it under the battery as a pull tab can work too.
Modem and carrier support
APN settings
The APN setting is required for a public Internet connection on the phone. For tested APN settings and how to apply them see PinePhone APN Settings.
Carrier support
Documents
Firmware modifications
Voice mail
Operating Systems
Software releases
Installation instructions
Flashing eMMC using Jumpdrive
Detailed usage instructions
Resize file system
If you flash a 4GB image distribution (such as phosh+debian) to your eMMC, your eMMC will only have a 3.7GB partition on it. To use the entire 14.7GB on the eMMC, run the following commands:
  1. sudo cfdisk /dev/sdX
  2. Change to [Resize] in the ncurses program, resize the 3.7GB partition to 14.7GB, and [Write]
  3. sudo resize2fs /dev/sdXY
Feedback
Frequently asked questions
Press
Developer works
Megous
External links
