Yuzuki Avaota-A1
The Yuzuki Avaota-A1
The Yuzuki Avaota-A1 is an ARM64 based Single Board Computer powered by Allwinner A527 Octa-Core ARM Cortex-A55 64-Bit CPU @2.0GHz, ARM Mali G56 GPU and RISC-V XuanTie E906 CPU@200MHz. It provides onboard eMMC, MicroSD Card slot, PCI-e, Pi-2 Bus, USB 3.0, and many other peripheral interfaces for makers to integrate with sensors and other devices.
Software releases
The releases are still in beta state and are only fit for development purposes.
OpenWrt Image Build
Armbian Mainline Linux OS Image Build
Avaota OS Legacy Linux Image Build
Android 13 Image Build
  • Note: "eng" build enable root and log for development or hacking purpose, "user" build disable root and log as release version
  • Direct Download Eng build from pine64.org (1.25GB, MD5 6692b8cd14aeccfed4bbdc148f607135)
  • Direct Download User build from pine64.org (1.22GB, MD5 cc0227464c7a451b582aba1f3b1944ae)
Android 13 SDK
  • Direct Download from pine64.org (62.28GB, MD5 f565ff9d0f712ca9c8131c69011379cf)
Resources and Articles
SoC and Memory Specification
  • Quad-core ARM Cortex-A55 at 2.0 GHz
  • Integrated 64KB L2 instruction cache and 128KB L2 data cache per cluster
  • 1MB unified system L3 cache
GPU Architecture
  • Mali-G57 Valhall GPU@850MHz
  • Supports Vulkan 1.1
  • Supports OpenCL 1.1, 1.2, 2.0 Full Profile
  • Supports Renderscript
  • L2 Cache Configurable 64KB – 512KB
    • 64KB-128KB for 1-Core
    • 128KB-256KB for 2-Core
    • 256KB for 3-Core
    • 1x256KB-2x256KB for 4-Core
    • 2x256KB-2x512KB for 5-Core and 6-Core configurations
  • Supports 3400 Mpix/s fill rate when at 850MHz clock frequency
  • Supports 243.2 GLOP/s when at 850MHz clock frequency for peak single precision (FP32) performance
  • LPDDR4 RAM Memory Variants: 2GB and 4GB.
Board Features
Video
  • H.264/AVC Base/Main/High/High10 profile @ level 5.1; up to 4K×2K @ 30fps
  • H.265/HEVC Main/Main10 profile @ level 5.1 High-tier; up to 4K×2K @ 60fps
Audio
  • 3.5mm audio Jack
Network
  • Dual 10/100/1000Mbps Ethernet
  • 2.4GHz/5Ghz MIMO WiFi 802.11 b/g/n/ac with Bluetooth 5.2
Storage
  • on-board 128Mbit (16MByte) XSPI NOR flash memory - bootable
  • microSD - bootable, supports SDHC and SDXC and storage up to 256GB
  • eMMC - bootable on-board 16GB or 32GB
Expansion Ports
  • 2×20 pins "Pi2" GPIO Header
  • 4 lane MiPi DSI port for LCD panel
  • 4 lane MiPi CSI port for camera module
  • 1× USB3.0 OTG port
  • 1× USB2.0 Host port
  • 1× USB2.0 OTG port
  • 1× CAN port
Input Power: DC 12V @ 3A 5.5mmOD/2.1mmID center-positive Barrel DC Jack connector
Schematic:
Board map of connectors with schematic v1.1 identifiers:
Certifications:
  • Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary. However, PINE64 still submits the SBC for FCC, CE, and ROHS certifications and obtain the certificates to prove that the SBC board can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
  • Not yet available
Allwinner A527 SoC information:
X-Power PMU information:
LPDDR4 (200 Balls) SDRAM:
eMMC information:
Ethernet related info:
WiFi/BT module info:
