Where to Report Bugs
Reporting bugs is a great way to contribute and to help bringing order at managing and solving issues.
Overview
Issues should only be reported in the correct bug trackers, not in the community chats. The following list is a selection of common bug trackers.
PinePhone and PinePhone Pro
Issues with the PinePhone and the PinePhone Pro can be reported on the following bug trackers (selection).
Operating Systems and Distributions
User Interfaces
Bootloaders and Firmwares
Hardware Issues
The page PinePhone Hardware Issues can be used to track known problems with the hardware (and how to fix them). If you're not exactly sure how to describe the issue, try the discussion tab for that page, or other community resources.
Accessories
TBD
PineTime
PineTab
