Talk:PinePhone Pro
Jump to navigation
Jump to search
Notes
Comment from TL via the community chat:
"The first PinePhone Pro revision staff with AP6256, the second rev and upcoming production all use AW-CM256SM. The reason of change is simple, AP6256 severely out of stock and factory manage to have a deal with AW-CM256SM vendor on constant supply. This also means that all the upcoming PINE64 wifi/BT module switch from AP6256 to AW-CM256SM. The new RockPro64/Quartz64 Wifi/BT module also change to AW-CM256SM. The SOQuartz module using either AW-CN256SM (default) or BL602. Another correction is the PinePhone front camera is 8MPxiel OV8858".
--Fxc (talk) 20:15, 16 October 2021 (UTC)
Charger info
There is a lack of info about what chargers will work to charge the PinePhone Pro. The original PinePhone page mentions some good info in a "Charging safety" section. --Bdju (talk) 21:41, 19 February 2021 (UTC)
