Pinebook Pro Debian Installer
Jump to navigation
Jump to search
Information
- This is an image creator and Debian installer that runs from an existing Linux OS and installs Debian Bullseye
- Installer can configure an encrypted rootfs and provides a choice of desktops, including the default Debian desktop based on Gnome 3
- Strict adoption of upstream Debian packages (with exception of kernel and bootloaders) in order to provide a clean upgrade path as Bullseye matures
- Download at: https://github.com/daniel-thompson/pinebook-pro-debian-installer/
- Pull requests welcome but for discussion and support please use the forum topic.
Features
| Feature | Status | Notes |
| Install to micro SD card | Works | Automatically expands to use all available space |
| Install to eMMC | Works | Automatically adapts for 64GB and 128GB models |
| Full disk encryption | Works | Run installer with `CRYPT=yes`. Requires kernel support and this support is missing in the original factory kernel so it it not possible to install a LUKS filesystem from the factory distro. You can make a temporary unencrypted install with this installer and then use the temporary OS to perform a full encypted install. |
| Wifi | Works | Issues have been reported with WPA2 networks [1] |
| Firefox | Works | |
| VLC | Works | |
| Fn+ keys | Work | After updating mesa to 20.0.7-1 |
Current issues
| Issue | Category | Status | Workaround | Notes |
cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2 |
Debian issue https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=857054 | If having FDE, it fails to load at boot as the firmware is not included in initramfs | Include the dptx.bin firmware in the initramfs | See https://forum.pine64.org/showthread.php?tid=8487&pid=57202#pid57202 |
Bluetooth doesn't work
bluetooth hci1: Direct firmware load for brcm/BCM4345C5.hcd failed with error -2 |
Copy those firmware https://gitlab.manjaro.org/manjaro-arm/packages/community/ap6256-firmware to /lib/firmware/brcm/. After that, Bluetooth works fine. | It seems some firmware is missing. See https://forum.pine64.org/showthread.php?tid=8731&pid=57525#pid57525 | ||
| Suspend doesn't work properly, when lid is closed, the laptops gets hot and dramatically dry the battery | Install is preconfigured to use suspend-to-idle instead. This offers some power savings compared to normal running but suspend should only be used for short periods. | # echo deep > /sys/power/mem_sleepPBP simply doesn't wake up after 'deep' sleep. | ||
| Often very slow to wake from suspend: 30-60 seconds. | Forum thread https://forum.pine64.org/showthread.php?tid=8822 | Sometimes pressing the power key helps wake it up. Set this key to not trigger sleep/shutdown in the Desktop Environment config. | ||
| Brightness keys don't work. | Add this file [2] to /etc/udev/hwdb.d/, run
sudo systemd-hwdb update sudo udevadm trigger |
