SOPINE
Revision as of 19:26, 20 February 2023 by Fxc (talk | contribs) (Added section)
Front view of a SOPINE module
Rear view of a SOPINE module
The SOPINE A64 is a compute module powered by the same Quad-Core ARM Cortex A53 64-Bit Processor used in the PINE A64 with 2G LPDDR3 RAM memory, Power Management Unit, SPI flash and integrated MicroSD slot (for bootable OS images microSD card). The compute module features a SODIMM-DDR3 form-factor and can be paired with either the SOPINE Baseboard, the Clusterboard or a custom host PCB for industrial or other embedded applications. The SOPINE module has a 5 years LTS (Long Term Supply) status, which means that it will be supplied to 2022 at the very least. There is a one year warranty period for the SOPINE module. It is fully compatible with the PINE A64-LTS in terms of software support
Software releases
Under SOPINE Software Releases you will find a complete list of currently supported operating system images, which work with the SOPINE, as well as other related software.
Pins and GPIOs
The following articles contain further details regarding the pins:
Troubleshooting
There is a number of things that can prevent the PINE A64(+) board from booting up properly. The most common culprits of a failed boot are (to find out more click here):
  • Subpar Power Supply
  • Failed imaging of the microSD card (refer to the respective ‘imaging microSD card section)
Make sure to have the newest version of the OS image your are running. On Linux, you can update the kernel and uboot using scripts located in the following directory: /usr/local/sbin
Supported Screen Resolutions
The pine supports a number of video resolutions under Linux, however RemixOS and Android images currently only support 720p and 1080p. Linux supports a wider range of resolutions (see all resolutions supported on Linux here). If the native resolution of your monitor or TV is not compatible with the PINE A64(+) then you will be unable to get a video to work with your screen.
Troubleshooting Step by Step
  • Check your PSU and barrel cable ratings
  • Plug in Power and Ethernet into your Board
  • Check your router for SOPINE IP
  • Attempt to ssh into the SOPINE from your computer
If neither of the above mentioned scenarios fits the problem you are facing, please consult this thread (thanks to Ghost for compiling the list): http://forum.pine64.org/showthread.php?tid=680
SoC and Memory Specification
  • Based on Allwinner A64
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
Five megapixel CMOS camera module information:
Schematics and certifications
SOPINE module schematic:
SOPINE pin assignments:
PINE A64-LTS / SOPINE WiFi/BT module schematic:
PINE A64-LTS / SOPINE Stereo Audio DAC board schematic:
SOPINE (together with model "A" baseboard) certification:
PINE A64, PINE A64+, PINE A64-LTS and SOPINE related
Early version Camera module information:
LCD Touch Screen Panel information:
Lithium battery information:
Ethernet PHY information:
WiFi/BT module information:
Enclosure information:
Connector information:
Remote control button mapping:
