SOEDGE Baseboard
Revision as of 23:43, 8 April 2023 by Fxc (talk | contribs) (→‎Schematics and certifications: fix)
The SOEDGE Baseboard
The SOEDGE Baseboard is a baseboard that hosts the SOEDGE compute module and turns it into a full single board computer. Makers can use this baseboard as reference to develop their own PCBs and for software development during early stages for custom hardware or PCB development.
Specifications
  • Gigabit Ethernet
  • HD Digital Video Out
  • 2x USB 3.0 Host
  • Euler Bus
  • Expansion Bus
  • PI-2 Bus
  • PCIe 4X open-ended header
  • Touch Panel Port (TP)
  • Display Serial Interface (DSI) Port
  • IR R/X Port
  • Real Time Clock Port (RTC)
  • Lithium Battery Port
  • SMOS Sensor Interface Port
  • Optional AC WiFi + BT 5.0 module expansion module
  • Headphone Jack
  • 5.5″ Barrel Power (12V 3A/5A) Port
Features
Network
  • 10/100/1000Mbps Ethernet
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • PCIe 2x open ended slot
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5OD/2.1ID Barrel DC Jack connector
SOEDGE Model "A" Baseboard schematics and PCB board resources:
SOEDGE module together with the baseboard certification:
  • Disclaimer: Please note that SOEDGE module is not a "final" product and in general certification is not necessary. However, SOEDGE module still submits the mpdel A baseboard for FCC, CE, and ROHS certifications and obtain the certificates to prove that can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
  • Not yet available
Ethernet PHY information:
