ROCKPro64
Revision as of 19:22, 29 July 2021 by Kreyren0 (talk | contribs) (Optimization for dyslectics and people who hate reading LIKE ME who rather spent 4 days of their life trying to figure out how to fix the board to make it boot ^-^)
The ROCKPro64 is the most powerful Single Board Computer released by Pine64. It is powered by a Rockchip RK3399 Hexa-Core (dual ARM Cortex A72 and quad ARM Cortex A53) 64-Bit Processor with a MALI T-860 Quad-Core GPU.
Key features include a PCIe x4 open ended slot, the use of LPDDR4 RAM, and industry standard heatsink mounting holes.
The ROCKPro64 is equipped with 2GB or 4GB LPDDR4 system memory, and 128Mb SPI boot Flash. There is also an optional eMMC module (up to 128GB) and microSD slot for booting. The board is equipped with 1x USB 3.0 type C Host with DP 1.2, 1x USB 3.0 type A Host, 2x USB 2.0 Host, Gigabit Ethernet, PI-2 GPIO Bus, MiPi DSI interface, eDP interface, touch Panel interface, stereo MiPi CSI interface, as well as many other device interfaces such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals. Many different Operating Systems (OS) are freely available from the open source community, such as Android, Linux (Ubuntu, Debian, Arch), and BSD.
Board Layout
A hi-res picture of v2.1 front
A hi-res picture of v2.1 rear
Main Chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM 1 (18)
  • LPDDR4 SDRAM 2 (3)
  • SPI NOR flash memory (17)
  • ES8316 Sound Codec (on rear of board)
  • The heatsink mounting holes around the RK3399 are 59 mm apart
Switches
The Power button (11, SW3): is the same as on your mobile phone - press and release after about 1 second to power on. Press and hold for about 3 seconds to power off.
The Reset button (10, SW901): perfoms a reset.
The Recover button (28, SW900): used to enter maskrom mode.
Connectors, Sockets and Headers
Diagram Schematic
designator
Silkscreen
label
Number
of pins
Description
2 U39 PI-2-bus 40 Pi-2 bus
4 J8 +FAN- 2 PWM controlled fan header
5 J10 SPDIF 3 SPDIF header
6 U6 +RTC- 2 RTC battery backup header
7 U31 Wifi-BT 16 SDIO WIFI/BT module-MIMO 2
8 USB3 9 USB-3 and USB Type C
9 USB1 2×4 Dual USB-2
12 IR1 IR 3 infrared receiver socket
13 J16 Headphone+mic 4 Headphone + mic 3.5mm jack
- CON16 GND PWR RST GND 4 Power & reset, unpopulated header near Headphone jack
14 U29 EMMC 34 eMMC connector
14* J13 13 TF-card, a.k.a. microSD (* under 14 on the bottom side)
15 U30 14 SDIO WIFI/BT module-MIMO 1
16 SW4 2 Jumper to #Disable eMMC
19 J15 PCI 64 PCI-express X4 socket
20 J21 DSI 30 DSI
21 J22 EDP 30 LCD EDP
22 CON1 TP 6 touch panel connector
23 CON15 4 DC out for SATA disk cable (direct connect from DC-IN)
24 J11 DC-IN 2 Power input, positive tip; 12V/3A (minimum) recommended
25 U32 8 RJ45
26 J14 19 HDMI
27 J17 MIPI CAM 32 MIPI-1
29 J19 MIPI CAM 32 MIPI-2
30 J18 CIF 26 CIF
LEDs
A red LED behind the reset button is DIY - it is lit for example if the board is in OTG mode with an Ayufan image, or if an Android image is in standby mode.
Jumpers
Disable eMMC
µSD eMMC SW4 boot
0 0 0 X
0 0 1 X
0 1 0 M
0 1 1 X
1 0 0 S
1 0 1 S
1 1 0 M
1 1 1 S
Disable SPI (while booting)
There is a second possibility to jumper your ROCKPro64: If you mess-up your SPI and are unable to boot, jumpering pins 23 (CLK) and 25 pin (GND) on the PI-2-bus header will disable the SPI as a boot device. (This was taken from the IRC logs, 09 August 2018 @ 17:23) You have to remove the jumper 2 seconds after having started your RP64 (before the white LED turns ON) otherwise the SPI will be missing and you won't be able to flash it. Ayufan images contain (at the moment) only one script for the SPI and the RP64, it's "rockpro64_reset_spi_flash". Other SPI scripts are dedicated to the R64 (as it is written on the name) and it will mess-up your RP64 SPI if you use them.
Getting Started
This section gives important information to get the board up and running.
Software and OS Image Builds
In the 'ROCKPro64 Software Release' page you will find a complete list of currently supported Operating System images that work with the ROCKPro64 as well as other related software. The Software Release page has links to download the images as well as high level instructions to load each image.
The page includes many OS images and descriptions. A short summary:
Armbian (microSD and eMMC Boot)
Debian (microSD and eMMC Boot)
DietPi (microSD and eMMC Boot)
Open Media Vault (microSD and eMMC Boot)
LibreELEC for KODI (microSD and eMMC Boot)
Slackware (microSD and eMMC Boot)
NextCloudPi (microSD and eMMC Boot)
Manjaro ARM (microSD and eMMC Boot)
OpenWrt (microSD and eMMC Boot)
More Advanced Linux Bits
Some Linux tips are given below.
How to Update Your Linux
For Debian/Ubuntu images entering the following commands at a terminal prompt
sudo apt-get update
sudo apt-get upgrade
will keep your installation up to date. To update Ayufan images to the next release (when available) use the following command
sudo apt-get dist-upgrade
If you are happy to update your system to pre-releases of Ayufan images then modify /etc/apt/sources.list.d/ayufan-rock64.list as per the comment in that file.
The kernel in Ayufan releases is under active development and, if you wish to install a later version, then it is best to use a package manager. In synaptic (for example), if you search for package names linux-image-4.4 you should see your currently installed version(s) as well as any more recent ones. Similarly if you wish to install the mainline kernel then searching for linux-image-4.18 will show you what is available. At the time of writing (August 2018) there are significant features missing from the mainline kernel for aarch64 processors (e.g. HDMI sound).
Useful Scripts
Video Playback
Ayufan has some old documentation on video playback here. For your ROCKPro64 the install should be
sudo apt-get install ffmpeg mpv libmali-rk-midgard-t86x-r14p0-gbm
(These modules are included in the Ayufan deskop releases.) At which stage rkmpv myvideo.mp4 will play a fullscreen, hardware assisted, version of your video. rkmpv is at /usr/local/bin/rkmpv
Swapping Kernel Versions
extlinux is in use on Ayufan images (at least) which enables some switching between installed kernel versions - intro documentation is here. In particular after you install any additional kernels, you can edit your /boot/extlinux/extlinux.conf file to specify which of the kernels you have installed to use for the next boot.
From Ayufan version 0.7.11 the script /usr/local/sbin/change-default-kernel.sh does a nice little menu swap for you if you run it as root (sudo).
Using an NVMe Disk as rootfs
This section gives some hints for advanced users.
Setup a Serial Console (UART)
Warning: Do not connect RxD (pin 10) until the U-Boot SPL is running (see RK3399 boot sequence) or the SPL will not start
The early adopters (and late-comers who fiddle excessively with their boards or don't want to use a keyboard and monitor) have a need to monitor the low-level boot behaviour: this is done with a serial console. The console is a 3.3v serial port using pins 8 (TxD from RK3399) and 10 (RxD to RK3399) of U39 (the PI-2 bus), with pin 6 as a convenient ground, running at 1500000,N,8,1 (1.5Mbps).
There is a great, detailed description how to get this working specifically on the ROCKPro64 here.
Booting from USB or PXE
Boot sequence
The RockPro64 boot sequence has been documented here by sigmaris.
OTG Mode
You can boot your ROCKPro64 into OTG mode with the use of the Recover button (see switch 28 above.) Note there are 2 OTG ports on your ROCKPro64: the type-C USB 3 socket is definitely one. From the schematic it appears the USB 3 (type A) socket is the other, but this has yet to be confirmed.
The method is to power off the board. Then push and hold the Recover button and push and release the Power button.
  • If you have an Ayufan bootable image in either the SDcard or eMMC then there are 4 OTG modes described here including Android fastboot, RockUSB and MaskROM modes. Releasing the Recover button as soon as the white LED lights counts as 1 blink. Keeping it pressed you will get 2 blinks of the white LED etc. Once the board enters OTG mode the red LED will be lit. In mode 1 the boot and linux-root partitions of the card with the Ayufan image (partitions 6 & 7 of a linux installation) are made available as devices. In all cases the USB device made available at the host has device ID 18d1:d00d.
  • If you do not have an Ayufan image in either the SDcard or the eMMC, then neither white nor red LEDs will light, but the board will enter MaskROM mode where the USB device made available at the host has device ID 2207:330c.
NVMe Drives
SATA Drives
ExplainingComputers did a YouTube ROCKPro64 PCIe SATA card review and tests using a Ubuntu console and OpenMediaVault.
Wi-Fi & Bluetooth Module
If you have bought the Wi-Fi and Bluetooth module from the Pine store then instructions for connecting it can be found on the accessories page here. Please note that the 0.7.9 Ayufan's linux releases (August 2018) have deliberately DISABLED support for this module in the search for stability. It can be tested and used with the Android image.
It can also be used on Manjaro by installing ap6256-firmware and wireless-regdb packages.
7" LCD Touch Screen
Note at present (August 2018) this screen is only supported by the Android image.
Warning: When using the touchscreen ensure the cables are properly connected and tightened down and that you do not let the metal backplane touch the SBC
RTC Battery Backup
The Pine store has a couple of options for RTC battery backups: a AAA version here or a CR-2032 version here. Instructions for plugging in either of them are also on the Accessories page
Acrylic Open Enclosure
Assembly instructions for the acrylic enclosure from the Pine store are also on the Accessories page
NAS case
The Exploded View Installation Diagram for the NAS case from the Pine store.
Detailed NAS Case overview and assembly instructions can be found here.
Hardware Compatibility
Hardware Compatibility Page
Please contribute to the hardware compatibility page, which lists hardware which has been tested with the rockpro64, whether successful or not.
Limitations
PCIe card issue and/or asynchronous external abort on flash read/write
Older firmware overwrites actively used memory
Some people get system freeze when:
  • use SATA disk with ROCKPro64 PCIe card. (maybe on newer PCIe card ASM1062 vs ASM1061)
  • or do read or write 4GB to the flash. (not using PCIe)
If you connect the serial console you will see a Linux kernel oops: (a)synchronous external abort.
Both issues are in fact the same software BUG. There is no hardware problem. Currently most OS do use uboot with a rockpro blob FW which use memory that Linux kernel is not aware of. People are currently fixing this BUG, but it may take some time. In the mean time, you can fix it manually.
The latest u-boot can boot the rockpro64 without any blobs from rockchip. Install first arm-none-eabi-gcc and aarch64-linux-gnu-gcc compiler, then run the following commands:
git clone https://github.com/ARM-software/arm-trusted-firmware.git atf
make -C atf CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 bl31
git clone https://gitlab.denx.de/u-boot/u-boot.git u-boot
cd u-boot/
git checkout v2020.01-rc5
make rockpro64-rk3399_defconfig
BL31=../atf/build/rk3399/release/bl31/bl31.elf make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu-
Which gives you idbloader.img and u-boot.itb. Copy them to the rockpro64, and run the following: (Or put your SD card into your PC)
sudo dd if=idbloader.img of=/dev/mmcblk0 seek=64
sudo dd if=u-boot.itb of=/dev/mmcblk0 seek=16384
sync
PCIe Controller Hardware Error Handling Bug
There is an issue with the rk3399 pcie controller that is currently unmitigated:
The rk3399 pcie controller throws either a synchronous abort or a SError when a pcie device sends an unknown message.
The error type is determined by which cpu cluster handles the message.
Virtualization
The PCIe controller on the rk3399 is not behind an IOMMU. This means it is not possible to safely pass through PCIe devices to a virtual machine.
Board Features
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72:
    • DSP & SIMD extensions
    • VFPv4 floating point
  • Cortex-A53:
GPU Architecture
  • The highest performance GPUs built on Arm Mali’s famous Midgard architecture, the Mali-T860 GPU is designed for complex graphics use cases and provides stunning visuals for UHD content.
  • Frequency: 650MHz
  • Throughput: 1300Mtri/s, 10.4Gpix/s
  • OpenGL® ES 1.1, 1.2, 2.0, 3.1, 3.2, Vulkan 1.0*, OpenCL™ 1.1, 1.2, DirectX® 11 FL11_1, RenderScript™.
Display
  • Dual VOP: one supports resolutions up to 4096x2160 and AFBC; the other supports resolutions up to 2560x1600
  • eDP 1.3 (4 lanes with 10.8Gbps) to support displays, with PSR
Video
  • 4K HDR @ 30fps
  • VP9, up to 4Kx2K @ 60fps
Audio
  • 3.5mm Phone Jack
  • 3-pin S/PDIF header
  • Audio via Digital Video port
Camera
  • Dual MIPI CSI,dual ISP, maximum input resolution of 13M pixels
Network
  • 10/100/1000Mbps Ethernet - Capable of pushing 941 MBit/s in iperf3
  • Wi-Fi 802.11 ac/a/b/g/n with Bluetooth 4.01 (old version with 2x2) / Bluetooth 5 (new version with 1x1) (optional)
Storage
  • 1 USB3.0 Host port
  • 2 USB2.0 Dedicated Host ports
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
GPIO Pins
Assigned To Pin Nr. Pin Nr. Assigned To
3.3 V 1 2 5 V
GPIO1_C4 (I2C8_SDA) 3 4 5 V
GPIO1_C5 (I2C8_SCL) 5 6 GND
GPIO4_D0 (CPU_GPCLK) 7 8 GPIO4_C4 (UART2_TX)
GND 9 10 GPIO4_C3 (UART2_RX)
GPIO1_C6 11 12 GPIO3_D0 (I2S0_CLK)
GPIO1_C2 13 14 GND
GPIO1_A1 15 16 GPIO1_A4
3.3 V 17 18 GPIO4_C5 [SPDIF]
[UART4_TX] GPIO1_B0 (SPI1_TXD) 19 20 GND
[UART4_RX] GPIO1_A7 (SPI1_RXD) 21 22 GPIO4_D1
GPIO1_B1 (SPI1_CLK) 23 24 GPIO1_B2 (SPI1_CSN0)
GND 25 26 GPIO1_B5
GPIO1_B3 (I2C4_SDA) 27 28 GPIO1_B4 (I2C4_SCL)
GPIO4_D3 29 30 GND
GPIO4_D4 31 32 GPIO3_D4 (I2S0_SDI1SDO3)
GPIO3_D5 (I2S0_SDI2SDO2) 33 34 GND
GPIO3_D2 (I2S0_LRCKTX) 35 36 GPIO3_D6 (I2S0_SDI3SDO1)
GPIO3_D1 (I2S0_LRCKRX) 37 38 GPIO3_D3 (I2S0_SDI0)
GND 39 40 GPIO3_D7 (I2S0_SDO0)
Linux /dev/gpiochip Assignments
On Linux, using the new /dev/gpiochip API, the n in GPIOn_XX appears to correlate to the number of the /dev/gpiochipn, and the XX to the definition RK_PXX of lines in include/dt-bindings/pinctrl/rockchip.h of the Linux kernel source. Having these named in the dts would be nice.
You can use libgpiod to drive them, and test them with the included tools (gpioinfo, gpioset, ...)
For example, gpioset 4 25=1 (run as root) would turn pin 22 on. Do beware that poking the wrong GPIO pin can lock up your system.
This conversion table is also available as a C header file.
Pin Nr. Chip Line
3 1 20
5 1 21
7 4 24
8 4 20
10 4 19
11 1 22
12 3 24
13 1 18
15 1 1
16 1 4
18 4 21
19 1 8
21 1 7
22 4 25
23 1 9
24 1 10
26 1 13
27 1 11
28 1 12
29 4 27
31 4 28
32 3 28
33 3 29
35 3 26
36 3 30
37 3 25
38 3 27
40 3 31
Working Features
Feature/Option Android Android Version Linux Linux Version Test/Verify Steps Notes Product Link
Pine64 LCD Touchscreen (Screen/Touch) Yes/Yes No/No Maybe this will help get this working? https://github.com/avafinger/pine64-touchscreen https://pine64.com/?product=7-lcd-touch-screen-panel
ROCKPro64 2×2 MIMO Dual Band WIFI 802.11AC / BLUETOOTH 4.2 MODULE (old)
ROCKPro64 1x1 Dual Band WIFI 802.11AC / BLUETOOTH 5.0 MODULE (new)
Yes/Yes No/No In 0.7.9 Ayufan linux releases this is deliberately disabled for stability reasons. https://store.pine64.org/product/rockpro64-1x1-dual-band-wifi-802-11acbluetooth-5-0-module
USB OTG use this script: https://github.com/ayufan-rock64/linux-package/blob/master/root-rockpro64/usr/local/sbin/rockpro64_enable_otg.sh then configure ip on usb0: ifconfig usb0 169.169.222.222 and run iperf, you should likely see about 200-300MB/s https://wiki.pine64.org/index.php/ROCKPro64_Main_Page#OTG_mode
USB Mass Storage USB2/USB3 Yes/yes Yes/Yes
Dedicated Fan Power (pwm1) Yes You might want to use ATS. https://github.com/tuxd3v/ats
GPIO pins (raw or via RPI python scripts) Check out what Frank Mankel has done. https://forum.frank-mankel.org/topic/292/rockpro64-rp64-gpio/2
MIPI CSI Camera 1 and 2
eDP
HDMI Audio Yes 7.1.2 Yes 4.4.132-1083 - 4.4.138-1100 Stopped working in 4.4.154.1105. Ayufan is looking into it.
3.5mm Audio/Mic
USB-C Host
Display via USB-C Yes 7.x and 8.x eDP via USB-C per tillim. No sound on Android 7.x. Sound does work on Android 8.x
ROCKPro64 PLAYBOX ENCLOSURE N/A N/A N/A Ventilation does not exist, thus requires manual changes to add venting. Case should be modified to account power adapter not being centered in cut holes. Opening the case once close without modifying it first is near impossible without special tools. Graphene heatsink is included and does well for Linux but not Android. https://pine64.com/?product=rockpro64-playbox-enclosure
ROCKPro64 30mm Tall Profile Heatsink N/A N/A N/A https://store.pine64.org/?product=rockpro64-heatsink
ROCKPro64 20mm Mid Profile Heatsink N/A N/A N/A https://pine64.com/?product=rockpro64-20mm-mid-profile-heatsink
Fan For ROCKPro64 20mm Mid Profile Heatsink N/A N/A N/A You might want to use fanctl to control the fan while keeping your CPU cool https://github.com/tuxd3v/fanctl https://pine64.com/?product=fan-for-rockpro64-20mm-mid-profile-heatsink
HDMI output 4K@60Hz
PCIe 2.1
Real Time Clock (RTC) battery backup https://store.pine64.org/?product=rtc-backup-battery-cr-battery
Boot from USB/PXE
RockChip themselves have tables of supported features at 4.4 and mainline kernel versions in their wiki here.
  • Certifications:
    • Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary. However, PINE64 still submit the SBC for FCC, CE, and ROHS certification and obtain the certificates to proof that SBC board is capable on passing the testing. Please note a final commercial product needs to performs its owns testing and obtains its owns certificates.
    • ROCKPro64 FCC Certificate
    • ROCKPro64 CE Certificate
    • ROCK64 RoHS Report
Useful Articles and Blog Posts
The NAS Case for the ROCKPro64
Please follow this this link for detailed instructions on how to assemble the ROCKPro64 NAS Case.
The NAS Case instructions also contains detailed information about:
  • what the NAS Case ships with
  • What additional things you need to purchase for your NAS Case
  • What optional things you can consider purchasing for your NAS build
  • What OS Image we recommend you use for your NAS build
  • IO accessibility after installing the ROCKPro64 into the NAS Case
  • NAS Case Exploded View
  • NAS Case Drawing
Other Resources
