Quartz64 Development
Revision as of 18:15, 15 July 2022 by CounterPillow (talk | contribs) (→‎Upstreaming Status: ethernet works on model B, was just a hardware issue on my end)
This page documents the current status of software support for the Quartz64 single-board computer, and provides links to resources to help prospective contributors get started. Information is kept current on a best-effort basis as various patches get accepted into the kernel.
Overview
Upstreaming Status
Function Status Component Notes Applies To
Video Output Linux Mainline rockchipdrm/VOP2
As of 5.19-rc1[1], Also featured in Phoronix Article[2]
Needs porting rockchip-edpphy-naneng Downstream: [3] and [4] Coordinate any porting with Rockchip first
Needs porting dw-mipi-dsi-rockchip Downstream: [5]
3D Acceleration Linux Mainline Upstream Mesa panfrost As of 5.18[6]
Video Decode Linux Mainline GStreamer only, no ffmpeg[7] hantro using v4l2-requests VDPU121 handling 1080p H.263, MPEG-1, MPEG-2, VP8 and H.264. Mainline as of 5.19[8]
Needs writing rkvdec2 using v4l2-requests VDPU346 handling 4K H.265, H.264 and VP9
Needs writing rkdjpeg using v4l2-requests VDPU720 handling JPEG, User:CounterPillow is working on this
Video Encode In review[9] GStreamer only JPEG on VEPU121 Hantro-based
Needs writing ? H.264 on VEPU121 Hantro-based
Needs writing ? VP8 on VEPU121 Hantro-based
Needs writing ? H.264 on VEPU540 rkvenc-based
Needs writing ? H.265 on VEPU540 rkvenc-based
Audio Linux Mainline rockchip-i2s-tdm As of 5.16[10]
Linux Mainline rockchip-spdif As of 5.15[11]
Linux Mainline rk817-codec As of 5.14[12]. Quartz64 Model A/B
u-boot Waiting on ATF sources
Device Tree Linux Mainline Quartz64 Model A As of 5.16[13] Quartz64 Model A
Linux Mainline Quartz64 Model B As of 5.19[14] Quartz64 Model B
Linux Mainline SOQuartz As of 5.19[15] SOQuartz
Linux Mainline PineNote As of 5.18[16] PineNote
Gigabit Ethernet Linux Mainline rk3566-gmac As of 5.14[17]
Linux Mainline yt8511-phy As of 5.14[18]
IOMMU Linux Mainline rockchip-iommu As of 5.14[19]
GPIO Linux Mainline gpio-rockchip As of 5.15[20]
pinctrl Linux Mainline
Thermal Regulation Linux Mainline rockchip-thermal As of 5.14[21]
PCIe Linux Mainline pcie-dw-rockchip As of 5.15[22]
Power Management Linux Mainline rockchip-pm-domains As of 5.14[23]
Voltage Control Linux Mainline rk3568-pmu-io-voltage-domain As of 5.15[24]
SPI Linux Mainline spi-rockchip As of 5.14[25]. Necessary device tree changes in review.
Battery In review[26] rk817-charger In the BSP tree this is handled by rk817_battery.c and rk817_charger.c. Quartz64 Model A, Pinenote
Microphone Linux Mainline rockchip-saradc As of 5.15[27]. Headphone jack mic seems to connect to SARADC_VIN2_HP_HOOK, so I'm pretty sure that the dtsi and driver changes are needed for that mic to work
USB 2.0 Linux Mainline rockchip-usb2phy As of 5.17[28]
e-Ink In review (RFC)[29] rockchip-ebc A DRM driver is available here; also see RK3566 EBC Reverse-Engineering
Combo PHY Linux Mainline naneng-combphy As of 5.18[30]. Still requires DTS changes
RGA Needs fixing rockchip-rga User:CounterPillow experimentally enabled it[31] in the device tree and ran gstreamer's v4l2convert through it to test, resulting in a completely garbled output.
Fan Controller Needs porting emc2301 Previous attempts at mainlining: [32] and [33]. Latest iteration: [34] SOQuartz Blade
CIF (CSI Camera) Needs porting video_rkcif Downstream: [35]
NPU Needs writing Downstream version is a closed source SDK. Major undertaking to reimplement this as Linux does not (yet) appear to have a generic architecture for neural accelerators.
Crypto Needs porting rk-crypto v2 Downstream driver [36] doesn't include a rk3568 compatible either, but the TRM shows that it seemingly matches.
Current Status
The following sections give an overview over the current status of different parts of the board. Some parts are waiting on a driver to be written or ported, others only need various adjustments.
According to pgwipeout, I/O device performance is within expected ranges now.
Working
  • eMMC
  • SDMMC0 (SD cards)
  • GMAC (Gigabit Ethernet)
  • USB 2.0
  • SATA 2
  • SATA 3
  • UART
    • UART 0 (Pi-bus)
    • UART 1 (Bluetooth)
    • UART 2 (Pi-bus, debug)
  • Video Decode
    • VP8
  • Battery
  • GPU
  • Audio
    • Analog audio works
    • SPDIF works
    • HDMI works
  • SPI — works, user needs to modify device tree to add devices
  • I2C — works, user needs to modify device tree to add devices
Partially Working
  • PCI-Express Controller — everything but devices that need cache coherency (e.g. dGPUs) should work
    • User:CounterPillow noticed some weirdness with NVMe devices disconnecting during heavy write operations, likely down due to power draw on one of the rails as the same sustained bandwidth could be achieved with a different PCIe device with no issue.
  • SDMMC1 (Wi-Fi) — AP6256 working, BL602 needs some work to make it flash firmware
  • GIC — needs errata published by Rockchip to get upstream to add device-specific workarounds[37]
  • Video Output — only at 1920x1080p60 and nothing else, very buggy and rough around more than just the edges
Confirmed Broken
  • USB 3.0 — only works with very short cables and depends on the device. This is due to a hardware design issue relating to the coupling capacitors needed for SATA, which shares the same lines as USB 3.0.
    • Hardware design changes have been suggested to engineers, it's in their hands now.
  • Module autoloading for the Ethernet PHY. The Motorcomm PHY does not have a vendor ID written into the appropriate hardware block, so there is no canonical way to identify the device.
Needs Testing
  • E-Paper — needs EBC driver
  • Microphone Input
  • CSI — needs CIF driver
  • eDP — needs PHY driver and controller driver
  • DSI — needs driver
TODO
ebc-dev Reverse Engineering and Development
The driver for the eInk panel needs to both be reverse engineered and then rewritten as C. In its current form, it is mostly an assembly dump produced by gcc with debug symbols. See RK3566 EBC Reverse-Engineering for details.
Investigate MCU
The RK3566 comes with an integrated RISC-V microcontroller (MCU). It communicates with the A55 host through the Mailbox system driven by the rockchip-mailbox driver. Since this MCU would be quite useful for things such as low power standby mode, investigating how it can be turned on and have firmware flashed to it should greatly enhance the power saving features of the PineNote.
Mainline U-Boot Work
Currently, mainline U-Boot does not have support for the RK3566 SoC used on the Quartz64. That's why we currently use the "downstream" Rockchip U-Boot, which is based on an old version of U-Boot and contains vendor specific patches that have not undergone the same level of code review as they'd have done had they been submitted upstream.
While the lack of ATF sources means that using mainline U-Boot would still require the use of Rockchip provided binaries for the firmware, the mainline U-Boot works needs to be done eventually anyway, and even with Rockchip blobs, a more modern version of U-Boot will be much nicer to use.
Someone needs to get on the task of investigating what minimally needs to be ported to get the board booting with mainline U-Boot, port those changes, and submit them for review.
Things that need to be done
This list is non-exhaustive as we don't exactly know how much is missing
  • Do the rk3568.dtsi refactoring into rk356x.dtsi/rk3568.dtsi/rk3566.dtsi that the kernel did, probably just port the kernel dtsi files for this
  • Bring the kernel's Quartz64 DTS into the tree
  • Write a quartz64-rk3566_defconfig based on evb-rk3568_defconfig
Stretch Goals:
  • Port the Naneng Combo PHY driver to u-boot so we can SATA, USB 3 and PCIe boot
  • Look into SPI
  • Port the Motorcomm PHY driver to u-boot for networking?
  • Port a basic VOP2 driver to get a framebuffer from u-boot
List of Useful Resources for this Task
eDP Driver Porting
The eDP PHY driver and controller driver needs to be ported, brought into shape and submitted with proper commit attribution to the Rockchip authors.
User:CounterPillow has experimentally ported stuff, but it's currently not working.
Linux Kernel Config Options
  • CONFIG_SND_SOC_ROCKCHIP_I2S_TDM
    • for Analog and HDMI audio
  • CONFIG_SND_SOC_RK817
    • for Analog audio on the Model A
  • CONFIG_STMMAC_ETH
    • Ethernet
  • CONFIG_DWMAC_ROCKCHIP
    • Ethernet
  • CONFIG_MOTORCOMM_PHY
    • Ethernet, set this one to Y, m won't work out of the box if the generic PHY driver is y and binds first. Alternatively tell users in board-specific setup instructions to force including the motorcomm module in initramfs if you set it to m.
  • CONFIG_MMC_DW
    • MMC/SD
  • CONFIG_MMC_DW_ROCKCHIP
    • MMC/SD
  • CONFIG_MMC_SDHCI_OF_DWCMSHC
    • MMC/SD
  • CONFIG_PCIE_ROCKCHIP_DW_HOST
    • PCIe
  • CONFIG_PHY_ROCKCHIP_NANENG_COMBO_PHY
    • PHY for PCIe/SATA/USB3
  • CONFIG_DRM_PANFROST
    • GPU
  • CONFIG_SND_SOC_ROCKCHIP_SPDIF
    • SPDIF audio
  • CONFIG_ROCKCHIP_DW_HDMI
    • HDMI PHY
  • CONFIG_ROCKCHIP_VOP2
    • Video output
  • CONFIG_ARCH_ROCKCHIP
    • General SoC support
  • CONFIG_ROCKCHIP_PHY
  • CONFIG_PHY_ROCKCHIP_INNO_USB2
    • USB 2
  • CONFIG_RTC_DRV_RK808
    • Real-time Clock
  • CONFIG_COMMON_CLK_RK808
    • Real-time Clock
  • CONFIG_MFD_RK808
    • Various things relating to the RK817 chip
  • CONFIG_REGULATOR_RK808
    • Voltage regulators
  • CONFIG_ROCKCHIP_PM_DOMAINS
    • Power management domains
  • CONFIG_GPIO_ROCKCHIP
    • GPIO support
  • CONFIG_PINCTRL_ROCKCHIP
    • GPIO and general SoC support
  • CONFIG_PWM_ROCKCHIP
    • PWM support
  • CONFIG_ROCKCHIP_IOMMU
    • IOMMU support
  • CONFIG_ROCKCHIP_MBOX
    • Mailbox support (for communication with MCU)
  • CONFIG_ROCKCHIP_SARADC
    • Analog-to-digital conversion support, for e.g. microphones
  • CONFIG_ROCKCHIP_THERMAL
    • Temperature sensor and thermal throttling support
  • CONFIG_SPI_ROCKCHIP
    • SPI support
  • CONFIG_VIDEO_HANTRO_ROCKCHIP
    • Hardware video decoder support
  • CONFIG_ROCKCHIP_IODOMAIN
    • General SoC support so your I/O pins have the right voltage
  • CONFIG_COMMON_CLK_ROCKCHIP
    • Common clock support
Resources
Repositories
Other
Board/SoC Documentation
Booting
Boot Order
The RK3566 boot ROM will search for a valid ID BLOCK in the following order on the support boot media:
  • SPI NOR flash
  • SPI NAND flash
  • SD-Card
  • eMMC
... if this fails, the boot ROM will initialize the USB0 port and wait for a connection from the Rockchip flash/boot tools.
Bootloader Flashing
As per pgwipeout's commit message:
  • Make a partition named uboot as partition number 1 at 8 MiB to 16 MiB
  • dd if=idblock.bin of=/dev/<mmc/sd> seek=64
  • dd if=uboot.img of=/dev/<mmc/sd>1
BSP Image Layout
