Quartz64 Development
Revision as of 17:01, 26 August 2021 by CounterPillow (talk | contribs) (→‎Upstreaming Status: spdif -> next)
This page documents the current status of software support for the Quartz64 single-board computer, and provides links to resources to help prospective contributors get started. Information is kept current on a best-effort basis as various patches get accepted into the kernel.
Overview
Upstreaming Status
Video Output Needs porting rockchipdrm/VOP-v2
3D Acceleration Linux Mainline Upstream Mesa panfrost
Video Decode Linux Staging Not in ffmpeg[1] hantro-vpu, using v4l2-requests Necessary device tree changes in review
Audio In review[2] rockchip-i2s-tdm Downstream: i2s i2s fix vad pdm
linux-next[3] rockchip-spdif Downstream: spdif
Linux Mainline rk817-codec As of 5.14
u-boot Waiting on ATF sources
Device Tree Basic Quartz64 Model A device tree in linux-next[4]
Gigabit Ethernet Linux Mainline rk3566-gmac As of 5.14[5]
Linux Mainline yt8511-phy As of 5.14[6]
IOMMU Linux Mainline rockchip-iommu As of 5.14[7]
GPIO linux-next[8] gpio-rockchip
pinctrl Linux Mainline
Thermal Regulation Linux Mainline rockchip-thermal As of 5.14[9]
PCIe linux-next[10] pcie-dw-rockchip
Power Management Linux Mainline rockchip-pm-domain As of 5.14[11]
Voltage Control linux-next[12] rk3568-pmu-io-voltage-domain
SPI Linux Mainline spi-rockchip As of 5.14[13]
Battery In review[14] rk817-charger In the BSP tree this is handled by rk817_battery.c and rk817_charger.c
Microphone linux-next[15] rockchip-saradc Headphone jack mic seems to connect to SARADC_VIN2_HP_HOOK, so I'm pretty sure that the dtsi and driver changes are needed for that mic to work
USB 2.0 In review[16] rockchip-usb2phy
e-Ink Needs reversing ebc-dev? See RK3566 EBC Reverse-Engineering
Current Status
The following sections give an overview over the current status of different parts of the board. Some parts are waiting on a driver to be written or ported, others only need various adjustments.
According to pgwipeout, I/O device performance is within expected ranges now.
Working
  • eMMC
  • SDMMC0 (SD cards)
  • GMAC (Gigabit Ethernet)
  • USB 2.0
  • SATA 2
  • SATA 3
  • UART
    • UART 0 (Pi-bus)
    • UART 1 (Bluetooth)
    • UART 2 (Pi-bus, debug)
  • Video Decode
    • VP8
  • Battery
Partially Working
  • PCI-Express Controller — everything but devices that need cache coherency (e.g. dGPUs) should work
  • USB 3.0 — only works with very short cables and depends on the device. This is likely due to a hardware design issue relating to the coupling capacitors needed for SATA, which shares the same lines as USB 3.0.
  • SDMMC1 (Wi-Fi) — AP6256 working, BL602 needs some work to make it flash firmware
  • I2C — works but is not yet exposed to the Pi-bus
  • GIC — needs errata published by Rockchip to get upstream to add device-specific workarounds[17]
  • Audio
    • Driver for Analog audio being upstreamed by User:CounterPillow, still in review though, but it works
    • no HDMI yet
Confirmed Broken
  • Nothing!
Needs Testing
  • GPU — need a VOP-v2 DRM driver to get display output
  • E-Paper — needs EBC driver
  • SPI
  • SPDIF — needs some soldering and device tree changes to test, User:CounterPillow has ordered the necessary components
TODO
ebc-dev Reverse Engineering and Development
The driver for the eInk panel needs to both be reverse engineered and then rewritten as C. In its current form, it is mostly an assembly dump produced by gcc with debug symbols. See RK3566 EBC Reverse-Engineering for details.
VOP2 Porting
The VOP2 portion of the rockchip-drm driver needs to be ported from the downstream kernel. This driver enables video output. Preliminary research has determined that this is a fairly big task.
Collabora has an unpolished forward port that has some issues with HDMI, it can be found here: https://gitlab.collabora.com/benjamin.gaignard/for-upstream/-/tree/5.10_for_rockchip
pgwipeout has a branch for initial vop2 work/testing, very rough around the edges and does not successfully probe yet.
Investigate MCU
The RK3566 comes with an integrated RISC-V microcontroller (MCU). It communicates with the A55 host through the Mailbox system driven by the rockchip-mailbox driver. Since this MCU would be quite useful for things such as low power standby mode, investigating how it can be turned on and have firmware flashed to it should greatly enhance the power saving features of the PineNote.
Resources
Repositories
Other
Board/SoC Documentation
Booting
Boot Order
The RK3566 boot ROM will search for a valid ID BLOCK in the following order on the support boot media:
  • SPI NOR flash
  • SPI NAND flash
  • SD-Card
  • eMMC
... if this fails, the boot ROM will initialize the USB0 port and wait for a connection from the Rockchip flash/boot tools.
Bootloader Flashing
As per pgwipeout's commit message:
  • Make a partition named uboot as partition number 1 at 8 MiB to 16 MiB
  • dd if=idblock.bin of=/dev/<mmc/sd> seek=64
  • dd if=uboot.img of=/dev/<mmc/sd>1
BSP Image Layout
