Quartz64 Building U-Boot
Revision as of 08:58, 31 August 2023 by CounterPillow (talk | contribs) (Create a guide on how to compile mainline U-Boot for Quartz64/SOQuartz)
This article guides you through compiling U-Boot for a Quartz64 or SOQuartz device.
Prerequisites
You will need either an x86 machine with an aarch64 cross-compiler installed, or an existing aarch64 system. You will also need the device tree compiler dtc, python3 (including setuptools and pyelftools), swig, GNU make and git.
On an x86_64 Arch Linux system, you can install the required dependencies with:
pacman -S --needed base-devel aarch64-linux-gnu-gcc aarch64-linux-gnu-binutils git dtc python-setuptools swig python-pyelftools
Fetching The Repositories
Use git to clone the mainline U-Boot repository into the directory u-boot:
git clone https://source.denx.de/u-boot/u-boot.git
You can use git checkout tagname to check out a specific git tag (release), you can list all of them with git tag -l (but do keep in mind we only have device support since v2023.10).
Then, also use git to clone the rockchip firmware binaries repository into the directory rkbin:
git clone https://github.com/rockchip-linux/rkbin.git
Setting Up Your Environment
Next, we need to set two environment variables: ROCKCHIP_TPL for the DRAM init binary, and BL31 for the ARM Trusted Firmware binary.
cd u-boot
export ROCKCHIP_TPL="$(ls ../rkbin/bin/rk35/rk3566_ddr_1056MHz_v*.bin | sort | tail -n1)"
export BL31="$(ls ../rkbin/bin/rk35/rk3568_bl31_v*.elf | sort | tail -n1)"
Configuring U-Boot
First, we need to use the right default config for our device. Please choose defconfig from the following table depending on your device:
Board defconfig
Quartz64 Model A quartz64-a-rk3566_defconfig
Quartz64 Model B quartz64-b-rk3566_defconfig
SOQuartz on Model A soquartz-model-a-rk3566_defconfig
SOQuartz on Blade soquartz-blade-rk3566_defconfig
SOQuartz on CM4 I/O Board soquartz-cm4-rk3566_defconfig
In the u-boot directory with your environment variables set, run:
make CROSS_COMPILE=aarch64-linux-gnu- defconfig
with defconfig being the value from the previous table.
Building U-Boot
In the u-boot directory, after configuring, and with your environment variables set, run:
make CROSS_COMPILE=aarch64-linux-gnu- -j$(nproc)
This will output a u-boot-rockchip.bin, which is your freshly built SPL+U-Boot combined image.
