Pinecil Cases, Stands, Supplies
The article contains information about cases, holders/stands, 3D-models, and supplies for the Pinecil soldering iron. This is a small set of examples based on the many questions asked every week in the live pinecil chat channel. There may be better althernatives depending on your part of the world, but this gives an idea of some possible options.
Cases and bags
Holders and stands
3D models
Pictures
3D Models:
Soldering supplies
  • Brass w/Rosin - Brass Wool with hard rosin in the bottom for tip cleaning. Twirl the tip in the brass wool often during soldering to keep the tip clean. Lower the temperature and dip lower into the hard rosin when you need a deeper cleaning.
  • Tip Refresher/tinner: Mechanic MCN-20 lead-solder version, or the Lead-free version (use when the tip is very dirty and solder is not sticking to it).
  • ESD Tweezers with case, budget set.
  • Weller Lead-Free Solder, 3 pack: variety of sizes for portable kits & sampling three common useful sizes (0.3,0.5,0.8).
  • Amtech flux NC-559-V3 from amtechdirect comes in a paste or syringe). There is a lot of fake Amtech online. Amtech is made in the USA and sold by 2 different companies. Avoid one from Aliexpress, many reports of flux that simply does not work and appears to be fake mixtures.
  • Relife RL-422-IM Halogen-free.
  • Solder Wick, variety pack: helps remove solder. Works best to first add a lot of flux to the area and solder wick for the best removal of solder.
Go back to Pinecil article
Go back to Pinecil article.
