Pinecil Cases, Stands, Supplies
The article contains information about cases, stands, 3D-models and supplies for the Pinecil.
Cases and bags
Holders and stands
3D models
Soldering supplies
  • Brass w/Rosin - Brass Wool with hard rosin in the bottom for tip cleaning. Twirl the tip in the brass wool often during soldering to keep the tip clean. Lower the temperature and dip lower into the hard rosin when you need a deeper cleaning.
  • Tip Refresher/tinner: Mechanic MCN-20 lead-solder version, or the Lead-free version (used when the tip is very dirty).
  • ESD Tweezers with case, budget set.
  • Weller Lead-Free Solder: 3-pack variety sizes for portable kits & sampling 3 common useful sizes (0.3/0.5/0.8mm).
  • NC-559-V3 from amtechdirect: Amtech flux comes in a paste or convenient syringe). Be careful, there is a lot of fake Amtech online. Amtech is made in the USA, avoid flux from Aliexpress, many reports of flux that simply does not work and appears to be fake mixtures.
  • Solder Wick, variety pack: helps to remove solder. Works best to add a lot of flux to the area and solder wick for the best removal of solder.
Go back to Pinecil article
Go back to Pinecil article.
