Pinecil Cases, Stands, Supplies
Revision as of 00:03, 16 February 2023 by River (talk | contribs) (Created page with " === Cases/Bags === * [https://a.co/d/hjFRpzK EVA Shockproof Case] * [https://www.aliexpress.com/item/1005002553816919.html Zippered Case] * [https://a.co/d/i6QoxKl Aluminum hard case w/foam] (check size before ordering if multiple listed). * [https://a.co/d/gAYy8fG Aluminum poker case w/foam] * Soft Bag [https://a.co/d/48PjOwZ Molle IFAK/EDC]: look for bags that can fully open like a sandwich when unzipped which allows tools to be easily seen and retrieved. Bags that o...")
Cases/Bags
Holder/Stands
3D Print
Supplies
  • Brass Wool with hard rosin in the bottom for tip cleaning: Brass w/Rosin
  • Tip Refresher/tinner for when the tip is very dirty: Mechanic brand MCN-20 lead-solder version, and Lead-free version.
  • Budget Tweezers Set: Tweezers ESD with case
  • Weller no-lead solder, 3-pack variety sizes for portable kits & sampling 3 common useful sizes: Lead-Free 3-pack (0.3/0.5/0.8mm).
  • Syringe Flux: Amtech NC-559-V3 from amtechdirect (comes in paste or convenient syringe). Be careful, there is a lot of fake Amtech online. Amtech is made in the USA, avoid any flux from Aliexpress, many reports of flux that simply does not work and appears to be fake from Aliexpress.
  • Solder Wick for removing solder: Solder Wick, variety pack (add a lot of flux to the area & solder wick works better).
