Pinebook Pro
Contents
- 1 User Guide
- 1.1 Introducing PineBook Pro
- 1.2 Software and OS Image Downloads
- 1.3 Keyboard
- 1.4 Trackpad
- 1.5 Power Supply
- 1.6 LEDs
- 1.7 Webcam
- 1.8 Microphones
- 1.9 Bluetooth and WiFi
- 1.10 LCD Panel
- 1.11 External ports list
- 1.12 Using the UART
- 1.13 Using the optional NVMe adapter
- 1.14 Caring for the PineBook Pro
- 1.15 Using the SPI flash device
- 1.16 FAQ
- 2 Software tuning guide
- 3 Troubleshooting guide
- 4 Hardware Compatibility
- 5 Technical Reference
- 6 Skinning and Case Customization
- 7 Other Resources
User Guide
It's compact and slim dimensions are 329mm x 220mm x 12mm (WxDxH).
On first boot, it will ask for certain information such as your timezone location, keyboard layout, username, password, and hostname. Most of these should be self-explanatory. Note that the hostname it asks for should be thought of as the "codename" of your machine, and if you don't know what it's about, you can make something up (use a single word, all lower case, no punctuation; e.g. "pbpro").
Pinebook Pro images
Under 'Pinebook Pro Software Release/OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
elementary OS 6 (microSD and eMMC Boot)
Manjaro ARM (microSD and eMMC Boot)
Debian Desktop (microSD and eMMC Boot)
Bionic LXDE (microSD and eMMC Boot)
Bionic Mate (microSD and eMMC Boot)
Fedora (microSD and eMMC Boot)
OpenSUSE (microSD and eMMC Boot)
Armbian (microSD and eMMC Boot)
NetBSD (microSD and eMMC Boot)
Chromium (microSD and eMMC Boot)
Arch Linux ARM installer (microSD and USB boot)
Debian Installer for Pinebook Pro
Gentoo Script for Pinebook Pro
Kali Script for Pinebook Pro (microSD and eMMC Boot)
- ayufan's Linux build repo (Includes Ubuntu 20.04 Focal Fossa and Debian Buster images. Click 'Assets' at the end of the releases text to view images)
- ayufan's Chromium OS build repo
- mrfixit2001's Linux debian desktop build repo
- SkiffOS/Buildroot build repo
Keyboard
Typing special characters
Character | Key combination/sequence |
Ä, Ö, Ü, ä, ö, ü | [AltGr]+'[' followed by [A], [O], [U], [a], [o] or [u] |
µ | [AltGr]+[m] |
Ø, ø | [AltGr]+[O], [AltGr]+[o] |
@ | [AltGr]+[q] (as on the German layout) |
ß | [AltGr]+[s] |
§ | [AltGr]+[S] |
° | [AltGr]+[)] |
Privacy Switches
Combination | Effect | Description | Notes |
PINE64 logo key+F10 | Microphone Privacy switch | CAPs lock LED blinks. 2 blinks = enabled, 3 blinks = disabled | |
PINE64 logo key+F11 | WiFi Privacy switch | NUM lock LED blinks. 2 blinks = WiFi enabled / killswitch disabled, 3 blinks = WiFi disabled / killswitch enabled. | Re-enabling requires reboot (or a command line hack to bind/unbind). |
PINE64 logo key+F12 | Camera privacy switch | CAPs lock and NUM lock LEDs blink together. 2 blinks = enabled, 3 blinks = disabled | Can use tools like lsusb to detect camera's presence. If not detected, check privacy switch.
The keyboard operates on firmware independant of the operating system. It detects if one of the F10, F11 or F12 keys is pressed in combination with the Pine key for 3 seconds. Doing so disables power to the appropriate peripheral, thereby disabling it. This has the same effect as cutting off the power to each peripheral with a physical switch. This implementation is very secure, since the firmware that determines whether a peripheral gets power is not part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots inside the keyboard's firmware flash memory.
Trackpad
The trackpad is a reasonable size, has a matte finish that that your finger can slide along easily, and two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality. Documentation for the trackpad can be found in Datasheets for Components and Peripherals. The trackpad firmware binary can be flashed from userspace using the provided open source utility (https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater). A fork with more recent changes is also available (https://github.com/jackhumbert/pinebook-pro-keyboard-updater) and may want to be considered instead while feature parity is different.
The trackpad controller is connected to the keyboard controller. All trackpad events go through the keyboard controller and it's software, then to the keyboard controller's USB port. Note that the trackpad does have separate firmware, (which has to be written through the keyboard controller).
Before you start:
Your Pinebook Pro should be either fully charged or, preferably, running off of mains. This utility will be writing chips on the keyboard and trackpad, so a loss of power during any stage of the update can result in irrecoverable damage to your trackpad or keyboard.
The scripts ought to work on all OSs available for the Pinebook Pro. Some OSs may, however, require installation of relevant dependencies. The instructions below assume a Debian desktop. Newer Pinebook Pro models that come with Manjaro will require a different command to install the proper dependencies.
There are two keyboard versions of the Pinebook Pro: ISO and ANSI. You need to know which model you have prior to running the updater. Firmware update steps for both models are listed below.
What you will need:
- Your Pinebook Pro fully charged or running off of mains power
- Connection to WiFi
- An external USB keyboard & mouse (or access to the Pinebook Pro via SSH)
ISO Model
git clone https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater cd pinebook-pro-keyboard-updater sudo apt-get install build-essential libusb-1.0-0-dev xxd make
Step 1
cd pinebook-pro-keyboard-updater sudo ./updater step-1 iso sudo reboot
Step 2 (after reboot)
cd pinebook-pro-keyboard-updater sudo ./updater step-2 iso sudo reboot
ANSI Model
- NOTE: Running step 1 on the ANSI keyboard model will make the keyboard and trackpad inaccessible until step 2 is ran, so an external keyboard must be connected to complete the update on this model!
Step 1
cd pinebook-pro-keyboard-updater sudo ./updater step-1 ansi sudo reboot
cd pinebook-pro-keyboard-updater sudo ./updater step-2 ansi sudo reboot
When done, if some of the keys produce incorrect characters, please check your OS’s language settings. For ANSI users, the default OS shipped with English UK as the default language. You can change it to English US if desired.
X-Windows & trackpad settings
Some forum members have found that an adjustment to X-Windows will allow finer motion in the trackpad. If you use the Synaptic mouse/trackpad driver, use this command to make the change live:
synclient MinSpeed=0.25
You may experiment with different settings, but 0.25 was tested as helping noticeably.
To make the change persist across reboots, change the file /etc/X11/xorg.conf
similar to below:
Section "InputClass" Identifier "touchpad catchall" Driver "synaptics" MatchIsTouchpad "on" MatchDevicePath "/dev/input/event*" Option "MinSpeed" "0.25" EndSection
The line Option "MinSpeed" "0.25"
is the change.
synclient MinSpeed=0.25 synclient TapButton1=1 synclient TapButton2=3 synclient TapButton3=2 synclient FingerLow=30 synclient PalmDetect=1 synclient VertScrollDelta=64 synclient HorizScrollDelta=64
FingerLow
has the same value as 'FingerHigh' in one config (30). It is believed to help reduce mouse movement as you lift your finger, but it's unknown whether synaptic works like this.
You may find this config to be comfortable for daily use.
TabButton
allows to just tab the touchpad instead of physically pressing it down (to get this click noise).
The right mouse click
is emulated by tapping with two fingers on the trackpad. If you feel that this is not very responsive you can try this value:
synclient MaxTapTime=250
Power Supply
- Input Power: 5V DC @ 3A
- Mechanical: 3.5mm OD / 1.35mm ID, Barrel jack
- USB-C 5V, 15W PD quickcharge
- Only use one power input at a time, barrel jack OR USB-C
LEDs
In total, there are four LEDs on the Pinebook Pro, three of which are placed in the top-left side of the keyboard, and one near the barrel port:
- The red LED next to the barrel port indicates charging, in three ways. First, it will illuminate steadily when either the factory power supply or a USB Type-C charger is connected to the Pinebook Pro, and the battery is getting charged. Second, if the battery is at 100%, the LED will remain turned off regardless of the connected power input; however, this is rather rarely achieved. Third, this LED will flash at 0.5 Hz if there are any problems that prevent charging, such as the battery becoming too hot.
- The power indicator LED, above the keyboard, supports three different colours: green, amber and red. It is also capable of flashing to indicate eMMC activity. In the default Debian with MATE build, green LED means power and red means suspend (amber is unused).
- The green NumLock LED, above the keyboard.
- The green CapsLock LED, above the keyboard.
The NumLock and CapsLock LEDs serve their usual purposes on a keyboard, but they also have a secondary function. When the privacy switches get activated they blink to confirm that the switch has been activated.
Webcam
- Streaming video resolutions supported, (un-compressed):
- 320 x 240
- 640 x 480
- 800 x 600
- 1280 x 720
- 1600 x 1200
- Still frame resolutions supported:
- 160 x 120
- 176 x 144
- 320 x 240
- 352 x 288
- 640 x 480
- 800 x 600
- 1280 x 720
- 1600 x 1200
- Some people test with the application Cheese
WIP
Microphones
Microphones not working?
If pavucontrol input doesn't show microphone activity try the Pinebook_Pro#Privacy_Switches; once that is set to on do the below; if that still hasn't fixed it you may want to check that the microphone connector is plugged in (see the Pinebook_Pro#Technical_Reference).
run alsamixer from the command line > hit F6 and select the es8316 > hit F4 to get to the capture screen > select the bar labeled ADC > > increase the gain to 0dB > change the audio profile in pavucontrol to another with input Additionally: you may want to modify ADC PGA to get the levels to where you want them
Bluetooth and WiFi
Hardware Overview
Issues
Wi-Fi Capabilities
Be aware that Linux userspace utilities, such as iw
, may report inaccurate information about the capabilities of wireless devices. Parameter values derived from vendor datasheets, or direct testing, should be preferred to the outputs of hardware-querying tools.
Bluetooth Capabilities
Disabling Bluetooth
#disable bluetooth once sudo rfkill block bluetooth && #confirm rfkill
#disable bluetooth on boot** sudo systemctl enable rfkill-block@bluetooth
LCD Panel
- Model: BOE NV140FHM-N49
- 14.0" (35.56cm) diagonal size
- 1920x1080 resolution
- 60hz refresh rate
- IPS
- 1000:1 contrast
- 250nt brightness
- 63% sRGB coverage
- 6 bit colour
- 30 pin eDP connection
External ports list
- Left side
- Barrel jack for power, (with LED)
- USB 3, Type A
- USB 3, Type C
- Right side
- USB 2, Type A
- Standard headset jack
- MicroSD card slot
Using the UART
$ lsusb
screen /dev/ttyUSB0 1500000
Installing the adapter
This is the link to the PBPro accessories in the store: [[1]]
$ sudo nvme id-ctrl /dev/nvme0 NVME Identify Controller: ... ps 0 : mp:9.00W operational enlat:0 exlat:0 rrt:0 rrl:0 rwt:0 rwl:0 idle_power:- active_power:- ps 1 : mp:4.60W operational enlat:0 exlat:0 rrt:1 rrl:1 rwt:1 rwl:1 idle_power:- active_power:- ps 2 : mp:3.80W operational enlat:0 exlat:0 rrt:2 rrl:2 rwt:2 rwl:2 idle_power:- active_power:- ps 3 : mp:0.0450W non-operational enlat:2000 exlat:2000 rrt:3 rrl:3 rwt:3 rwl:3 idle_power:- active_power:- ps 4 : mp:0.0040W non-operational enlat:6000 exlat:8000 rrt:4 rrl:4 rwt:4 rwl:4 idle_power:- active_power:- $ sudo nvme get-feature /dev/nvme0 -f 2 get-feature:0x2 (Power Management), Current value:00000000 $ sudo nvme set-feature /dev/nvme0 -f 2 -v 2 -s set-feature:02 (Power Management), value:0x000002
Using as data drive
Using as OS root drive
- MicroSD
- eMMC
- NVMe
It is also possible to initially boot off an eMMC or SD card, then transfer to a root file system on the NVMe. Currently, it is necessary to have the U-Boot code on an eMMC or SD card. (A forum member posted here about using a modified version of U-Boot with NVMe drivers, that uses /boot
and /
off the NVMe drive. So this may change in the future.)
Please see Bootable Storage.
Bypass Cables
- 14″ Pinebook Lithium Battery Pack Removal Guide
- 14″ Pinebook LCD Panel Screen Removal Guide
- 14″ Pinebook eMMC Module Removal Guide
See Pinebook_Pro_SPI
- You need the kernel built with SPI flash device support, which will supply a device similar to:
/dev/mtd0
- The Linux package below, will need to be available:
mtd-utils
- You can then use this program from the package to write the SPI device:
flashcp <filename> /dev/mtd0
The procedures described above are a lot less risky than attaching an external SPI flasher and do not require any additional hardware.
At present, April 19th, 2020, there is no good bootloader image to flash into the SPI flash device. This is expected to change, as there are people working on issue.
FAQ
Customizing the Pinebook Pro's default Manjaro KDE system
Watching DRM content (Netflix, etc.)
Most paid online streaming services use Widevine DRM to make their content more difficult to pirate. Widevine is not directly supported on Manjaro KDE, however it is still possible to watch DRM content via the "chromium-docker" package which downloads a 32-bit ARM container and installs Chromium with Widevine inside of that. While not space-efficient, or efficient in general, it's the recommended solution for watching this content on your Pinebook Pro. You can install this package with:
sudo pacman -Sy chromium-docker
Checking GPU capabilities
To see what versions of OpenGL and OpenGL ES are supported by the Pinebook Pro, what driver is in use, and what version of the driver is loaded, install the "mesa-demos" package with:
sudo pacman -Sy mesa-demos
And then run:
glxinfo | grep OpenGL
This will give detailed information about your graphics card and driver, useful for debugging.
Better GPU compatibility and performance
For better graphics performance, you may install the "mesa-git" package, built and supplied in the Manjaro ARM repos. This lets you bring in the latest features, optimizations, and bugfixes for the graphics driver used by the Pinebook Pro. Installation is as simple as:
pacman -Sy mesa-git
Then you may reboot to load the newer driver.
With Mesa 20.2 there is no longer much reason to use this over the standard mesa package, and applications may occasionally break with mesa-git.
Reporting bugs to the Mesa project will help make sure any problems are quickly fixed.
OpenGL 3.3 support
By default, with the current state of the Panfrost GPU driver, the Pinebook Pro supports OpenGL 2.1 and OpenGL ES 3.0. If you want to use OpenGL 3.3, you need to set the system-wide environment variable, open the /etc/environment file with:
kate /etc/environment
And then at the bottom of the file, on a new line, add:
PAN_MESA_DEBUG="gl3"
Then save the file, entering your password when prompted, and reboot the system. When you check your GPU capabilities, it should report OpenGL 3.3 and applications that rely on it should function properly. Note that GL 3.3 support is incomplete and some rendering features do not work yet, notably geometry shaders.
Customizing the Pinebook Pro's previously-default Debian system
Here are some hints on what you can do to customize the Pinebook Pro's previous factory image (aka mrfixit2001 debian build)
- Reboot (this is just to ensure all background processes belong to the user are not running... there are other ways to achieve this but this way is easy)
- Once the machine reboots press Alt-Ctrl-F1 to bring up a text terminal
- Login as root (login: root, password: root)
- Set a strong password for the root user using the following command and it's prompts:
# passwd (and follow prompts)
- Rename the rock user to your prefered username (replace myself with whatever you like):
- Rename the rock group to match your preferred username:
# groupmod -n myself rock
- Put your name in the account, (replace "John A Doe" with your name):
# chfn -f "John A Doe" myself
- Set a strong password for the normal user:
# passwd myself
- Log out of the text terminal:
# logout
- Press Alt-Ctrl-F7 to go back to the login screen and then login as the normal user
- Open text terminal to fix login error: "Configured directory for incoming files does not exist";
$ blueman-services
Changing the default hostname
> sudo hostnamectl Static hostname: Debian-Desktop Icon name: computer Machine ID: dccbddccbdccbdccbdccbdccbdccbccb Boot ID: ea99ea99ea99ea99ea99ea99ea99ea99 Operating System: Debian GNU/Linux 9 (stretch) Kernel: Linux 4.4.210 Architecture: arm64
Then you should backup and edit your /etc/hosts
entry's name;
> sudo cp -p /etc/hosts /etc/hosts.`date +%Y%m%d` > sudo vi /etc/hosts 127.0.0.1 localhost 127.0.0.1 My_Hostname ::1 localhost ip6-localhost ip6-loopback fe00::0 ip6-localnet ff00::0 ip6-mcastprefix ff02::1 ip6-allnodes ff02::2 ip6-allrouters 127.0.1.1 linaro-alip
Perform the following steps:
- On the tool bar, hover over the Chromium icon
- Using the right mouse button, select Properties
- In the Command: line section, add
--password-store=basic
before the%U
- Use the x Close button to save the change
- Install ImageMagick which will do the conversion
- Create a 1920 x 1080 picture. For the best results, use a PNG image (It supports lossless compression).
- From the directory in which your new image is stored run the following commands
- Convert your image to the bootsplash raw format using imagemagick convert.
- Create a backup copy of your current splash screen
- Copy your new splash screen into place
- Set the correct permissions on the splash.fb file
- If you do not want to see kernel console text messages, make sure you don't have Plymouth installed
Watching Amazon Prime videos with Chromium
When you create a new user, it will be necessary to launch the Chromium browswer with a specific user agent like below;
chromium-browser --user-agent="Mozilla/5.0 (X11; CrOS armv7l 6946.63.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.121 Safari/537.36"
There may be more tweaks needed.
By default, most Linux distros have a boot screen with a picture. To see all the boot time messages, use one of the following;
Default Debian
- Backup and edit the U-Boot configuration file:
cp -p /etc/default/u-boot /etc/default/u-boot.`date +%Y%m%d` chmod a-w /etc/default/u-boot.`date +%Y%m%d` vi /etc/default/u-boot
- Update the U-Boot configuration:
u-boot-update
- Test and verify you get what you think you should be seeing.
Manjaro
cp -p /boot/extlinux/extlinux.conf /boot/extlinux/extlinux.conf.`date +%Y%m%d` chmod a-w /boot/extlinux/extlinux.conf.`date +%Y%m%d` vi /boot/extlinux/extlinux.conf
Change console=ttyS2,1500000 to console=tty1
Remove the bootsplash.bootfile option and it's parameter.
You can add verbose logging by appending ignore_loglevel to the line where boot splash was.
Improving readability
Some people find that a 14" LCD screen with 1080p, (1920 x 1080), has text and icons a bit too small. There are things you can do to make the screen easier to use and read.
- Increase the font size
- Use a font with more pronounced features
- Increase the various window manager sizes (e.g. increase the height of the tool bar)
- Change the color scheme to be easier on the eyes. Higher contrast can help usability.
- Change the window manager's decorations (e.g. use larger icons)
- Use a workspace manager, with one application per workspace
- When at home or office, use an external monitor
- Change the X-Windows DPI
However, do not change the resolution of the LCD screen, otherwise you may end up with a blank / black screen. If that happens, see this troubleshooting section for the fix:
Blank screen after changing builtin LCD resolution
Chromium tweaks
Flags
--disable-low-res-tiling \ --num-raster-threads=6 \ --profiler-timing=0 \ --disable-composited-antialiasing \ --test-type \ --show-component-extension-options \ --ignore-gpu-blacklist \ --use-gl=egl \ --ppapi-flash-path=/usr/lib/chromium-browser/pepper/libpepflashplayer.so \ --ppapi-flash-version=32.0.0.255 \ --enable-pinch \ --flag-switches-begin \ --enable-gpu-rasterization \ --enable-oop-rasterization \ --flag-switches-end
Note that in some cases, this may also decrease performance substantially, as observed when using these flags on the Manjaro KDE desktop. Feel free to experiment to find what is smoothest for you personally.
gVim has performance issue
It appears that using GTK3 can cause very slow scrolling, while Vim in a terminal window works fine.
Simply revert back to using GTK2, (how to do so is somewhat Linux distro-specific).
Another solution may be to run gVim with
GDK_RENDERING=image
environment variable set. It seems that this improves the performance by reverting back to software-only rendering.
Kernel options
$ zgrep -i rockchip_pcie /proc/config.gz # CONFIG_ROCKCHIP_PCIE_DMA_OBJ is not set CONFIG_PHY_ROCKCHIP_PCIE=m
If it's listed as =m
, then it's a module. You can see if the module is loaded with;
$ lsmod | grep -i rockchip_pcie phy_rockchip_pcie 16384 0
Hardware video decoding
Older systems, such as the previously-default Debian desktop, use the Rockchip-supplied kernel module rk-vcodec
. To check, something like this can be used:
$ lsmod | grep rk-vcodec or $ zgrep RK_VCODEC /proc/config.gz CONFIG_RK_VCODEC=y
Newer systems may use a different option as in the configuration below:
$ zgrep HANTRO /proc/config.gz CONFIG_VIDEO_HANTRO=m CONFIG_VIDEO_HANTRO_ROCKCHIP=y
Do not to panic if something goes wrong or in an unexpected way. Instead, stop and consider carefully how to undo something, or how to redo it. This particularly applies when flashing a new operating system, or flashing new firmware to the keyboard or touchpad. If everything fails, consider reporting the issue on the forums, with as many relevant details as available.
Please, have a look at the Pinebook Pro Troubleshooting Guide, which details a number of issues you may encounter.
Please contribute to the hardware compatibility page, which lists the status of hardware tested with the Pinebook Pro. Available hardware categories include the following:
Please note that many users have reported issues with NVMe SSD drives, including random Linux lockups and crashes. Some of these issues are related to the RK3399's errata that disables Gen2 (5 GT/s) speed for the PCI Express link used by the NVMe SSD, reducing it down to Gen1 speed (2.5 GT/s). However, as of December 17, 2020, Linux distributions that use mainline Linux kernel still configure the PCI Express link to run at Gen2 speed, which requires manual reconfiguration to Gen1 speed in case system instability is experienced. See also this related discussion.
Technical Reference
Disassembly and Reassembly
There are a few mandatory precautions to be taken:
- Do not open the laptop by lifting the lid while the Pinebook Pro bottom cover is removed - this can cause structural damage to the hinges and/or other plastic components of the chassis such as the IO port cut-outs.
- When removing the back cover plate, use care if sliding fingertips between back cover plate and palm rest assembly. The back cover plate edges are sharp.
- When removing the back cover plate, use care to avoid damaging the speakers. They are stuck to the back cover with double-sided tape, and the thin wires are very delicate.
The screws are small and should only be finger tight. Too much force will strip the threads. If after installing screws the back cover plate has not seated properly on one side, open the display and hold the base on either side of the keyboard and gently flex the base with both hands in opposing directions. Once the side pops further in, then recheck the screws on that side. If it does not pop back in, just let it be.
A basic 3D model to print replacement standoffs for the back cover screws is available on Thingiverse, until the official drawings or 3D models are made available.
Internal Layout
Main chips
- RK3399 system-on-chip (1)
- LPDDR4 SDRAM (21)
- SPI NOR flash memory (29)
- eMMC flash memory (26)
- WiFi/BT module (27)
Key Internal Parts
Number | Type | Descriptor |
1 | Component | RK3399 System-On-Chip |
2 | Socket | PCIe 4X socket for optional NVMe adapter |
3 | Socket | Speakers socket |
4 | Socket | Trackpad socket |
5 | Component | Left speaker |
6 | Connector | Power bridge connector |
7 | Socket | Keyboard Socket |
8 | Component | Optional NVMe SSD adapter |
9 | Switch | UART/Audio switch - outputs UART via headphone jack |
10 | Socket | Power bridge socket |
11 | Socket | Battery socket |
12 | Component | Trackpad |
13 | Component | Battery |
14 | Component | Right speaker |
15 | Socket | MicroSD card slot |
16 | Socket | Headphone / UART jack |
17 | Socket | USB 2.0 Type A |
18 | Socket | Daughterboard-to-mainboard ribbon cable socket |
19 | Cable | Daughterboard-to-mainboard ribbon cable |
20 | Component | microphone |
21 | Component | LPDDR4 RAM |
22 | Socket | Mainboard-to-daughterboard ribbon cable socket |
23 | Socket | Microphone socket |
24 | Switch | Switch to hardware disable eMMC |
25 | Antenna | BT/WiFI antenna |
26 | Component | eMMC flash memory module |
27 | Component | BT/WiFi module chip |
28 | Buttons | Reset and recovery buttons |
29 | Component | SPI flash storage |
30 | Socket | eDP LCD socket |
31 | Socket | Power in barrel socket |
32 | Socket | USB 3.0 Type A |
33 | Socket | USB 3.0 Type C |
Smallboard detailed picture
Bootable Storage
Boot sequence details
RK3399 boot sequence
Boot devices
At this time, the Pinebook Pro ships with a Manjaro + KDE build with uboot on the eMMC. Its boot order is: SD, USB, then eMMC.
(An update has been pushed for the older Debian + MATE build that improves compatibility with booting other OSs from an SD card. In order to update, fully charge the battery, establish an internet connection, click the update icon in the toolbar, and then reboot your Pinebook Pro. Please see this log for details.)
eMMC information
- mmcblk1boot0 - eMMC standard boot0 partition, may be 4MB
- mmcblk1boot1 - eMMC standard boot1 partition, may be 4MB
- mmcblk1rpmb - eMMC standard secure data partition, may be 16MB
- mmcblk1 - This block contains the user areas
If the eMMC module is enabled after boot from an SD card, you can detect this change with the following commands as user "root";
echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/bind
Case Dimensions and Data
- Dimensions: 329mm x 220mm x 12mm (WxDxH)
- Weight: 1.26Kg
- Screws
- Philips head type screws
- M2 flat head machine screws (measurements in mm)
- 4 x Small screws (used along the front edge): Head - 3.44, Thread Diameter - 1.97, Thread Length - 2.1, Overall length - 3.05
- 6 x Large screws: Head - 3.44, Thread Diameter - 1.97, Thread Length - 4.41, Overall Length - 5.85
- Rubber Feet
- 18mm diameter
- 3mm height
- Dome shaped
SoC and Memory Specification
- Based on Rockchip RK3399
- big.LITTLE architecture: Dual Cortex-A72 + Quad Cortex-A53, 64-bit CPU
- Full implementation of the ARM architecture v8-A instruction set (both AArch64 and AArch32)
- ARM Neon Advanced SIMD (single instruction, multiple data) support for accelerated media and signal processing computation
- ARMv8 Cryptography Extensions
- VFPv4 floating point unit supporting single and double-precision operations
- Hardware virtualization support
- TrustZone technology support
- Full CoreSight debug solution
- One isolated voltage domain to support DVFS
- Cortex-A72 (big cluster):
- Dual-core Cortex-A72 up to 2.0GHz CPU
- Superscalar, variable-length, out-of-order pipeline
- L1 cache 48KB Icache and 32KB Dcache for each A72
- L2 cache 1024KB for big cluster
- Cortex-A53 (little cluster):
- Quad-core Cortex-A53 up to 1.5GHz CPU
- In-order pipeline with symmetric dual-issue of most instructions
- L1 cache 32KB Icache and 32KB Dcache for each A53
- L2 cache 512KB for little cluster
- Cortex-M0 (control processors):
- Cortex-M0 CPU
- Two Cortex-M0 cooperate with the central processors
- Architecture: Armv6-M
- Thumb/Thumb2 instruction set
- 32 bit only
GPU Architecture
- ARM Mali-T860MP4 Quad-core GPU
- The highest performance GPUs built on Arm Mali’s famous Midgard architecture, the Mali-T860 GPU is designed for complex graphics use cases and provide stunning visuals for UHD content.
- Frequency 650MHz
- Throughput 1300Mtri/s, 10.4Gpix/s
- Graphic interface standards:
- OpenGL® ES 1.1, 1.2, 2.0, 3.0, 3.1, 3.2. (Panfrost has initial support of 3.0 beginning 2020/02/27)
- Vulkan 1.0, using the Mali binary blob. (Panfrost does not support Vulkan as of 2020/06/24)
- OpenCL™ 1.1, 1.2
- DirectX® 11 FL11_1
- RenderScript™
- RAM Memory:
- LPDDR4
- 800MHz, (limited by RK3399)
- Dual memory channels on the CPU, each 32 bits wide
- Quad memory channels on the RAM chip, each 16 bits wide, 2 bonded together for each CPU channel
- 4GB as a single 366 pin mobile RAM chip
- Storage Memory:
- 64GB eMMC module, can be upgraded to an 128GB eMMC module. (The initial PINE64 community build version shipped with a 128GB eMMC.)
- eMMC version 5.1, HS400, 8 bit on RK3399 side
- Bootable
- SPI flash:
- Pinebook Pro SPI
- 128Mbit / 16MByte
- 1 bit interface
- Bootable, (first boot device, ahead of eMMC & SD card)
- U-Boot images can be made to work, but as of 2020/06/24 there is no standardized image available.
Video out
- USB-C Alt mode DP
- Up to 3840x2160 p60, dependant on adapter, (2 lanes verses 4 lanes)
Expansion Ports
- MicroSD card:
- Bootable
- Supports SD, SDHC and SDXC cards, up to 512GB tested. SDXC standard says 2TB is the maximum.
- Version SD3.0, (MMC 4.5), up to 50MB/s
- SD card Application Performance Class 1 (A1), (or better), recommended by some users, for better IOPS
- USB ports:
- 1 x USB 2.0 Type-A Host Port, bootable
- 1 x USB 3.0 Type-A Host Port, 5Gbps, is not bootable
- 1 x USB 3.0 Type-C OTG Port, 5Gbps, (includes laptop charging function), is not bootable
- Note that high power USB devices may not work reliably on a PBP. Or they may draw enough power to drain the battery even when the PBP is plugged into A.C. One alternative is externally powered USB devices.
- Headphone jack switchable to UART console mux circuit
Additional hardware
Battery
- Lithium Polymer Battery (10,000 mAH)
Display
- 14.0" 1920x1080 IPS LCD panel
Lid closed magnet
There is a magnet to detect when the laptop lid is closed, so action can be taken like sleep. This meets up with the Hall sensor on the daughter / small board to detect lid closed.
- The magnet is located on the LCD panel right side, around 1.5 inches up measure from bottom edge.
Webcam
- Internal USB attached Webcam
Audio
- 3.5mm stereo earphone/microphone plug
- Built-in microphone
- Built-in stereo speakers:
- Oval in design
- 3 mm high x 20 mm x 30 mm
Network
- WiFi:
- 802.11 b/g/n/ac
- Dual band: 2.4Ghz & 5Ghz
- Single antenna
- Bluetooth 5.0
Optional NVMe adapter
- PCIe 2.x, 5GT/s per lane
- 4 PCIe lanes, can not be bifurcated, (however, can be used with 1 or 2 lane NVMe cards)
- M keyed, though M+B keyed devices will work too
- Maximum length for M.2 card is 80mm (M.2 2280). The following sizes will also work: 2230, 2242, 2260
- Power: 2.5W continuous, 8.25W peak momentary
- Does not support SATA M.2 cards
- Does not support USB M.2 cards
- Pinebook Pro Main Board Schematic And Silkscreen:
- Pinebook Pro Daughter Board Schematic:
- Optional Pinebook Pro NVMe Adapter Schematic:
- Serial Console Earphone Jack Pinout:
- Pinebook Pro Case:
- Pinebook Pro Certifications:
- Rockchip RK3399 SoC information:
- LPDDR4 SDRAM (366-pin BGA):
- eMMC information:
- SPI NOR Flash information:
- Wireless and Bluetooth information:
- Audio codec:
- LCD panel:
- USB-related information:
- Internal USB 2.0 hub: GL850G USB Hub Datasheet
- USB Type-C Controller: ON Semiconductor FUSB302 Datasheet
- Touchpad information:
- Keyboard information:
- Sinowealth SH68F83 Datasheet
- US ANSI: XK-HS002 MB27716023
- Full HD camera sensor:
- Battery-related information:
- Battery charging IC: Texas Instruments BQ24171 Datasheet
- Battery monitoring IC: Cellwise CW2015 Datasheet
- 10000mAH Lithium Battery Specification
- Power path device:
- NVMe adapter:
Versions
- Template files for creating custom skins. Each includes template layers for art placement, and CUT lines.
Other Resources
- Pinebook Pro Forum
- ROCKPro64 Forum
- Matrix Channel (no login required to read)
- IRC Server: irc.pine64.org Channel: PineBook
- Discord Channel
- Rockchip Linux GitHub Repo
- Rockchip Open Source Wiki
- Freepascal and Lazarus IDE on Pinebook Pro
