Pinebook Pro
Revision as of 14:08, 3 May 2021 by Luke (talk | contribs) (→‎Pinebook Pro images)
Contents
User Guide
Introducing PineBook Pro
It's compact and slim dimensions are 329mm x 220mm x 12mm (WxDxH).
Key features include: the RK3399 SOC; USB-C for data, video-out and power-in (3A 5V); privacy switches for the microphone, BT/WiFi module, and camera; and expandable storage via NVMe (PCIe x4) with an optional adapter.
The Pinebook Pro is equipped with 4GB LPDDR4 system memory, high capacity eMMC flash storage, and 128Mb SPI boot Flash. The I/O includes: 1 x micro SD card reader (bootable), 1 x USB 2.0, 1 x USB 3.0, 1 x USB type C Host with DP 1.2 and power-in, PCIe x4 for an NVMe SSD drive (requires an optional adapter), and UART (via the headphone jack by setting an internal switch).
On first boot, it will ask for certain information such as your timezone location, keyboard layout, username, password, and hostname. Most of these should be self-explanatory. Note that the hostname it asks for should be thought of as the "codename" of your machine, and if you don't know what it's about, you can make something up (use a single word, all lower case, no punctuation; e.g. "pbpro").
Pinebook Pro images
Under 'Pinebook Pro Software Release/OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software.
elementary OS 6 (microSD and eMMC Boot)
Manjaro ARM (microSD and eMMC Boot)
Debian Desktop (microSD and eMMC Boot)
Bionic LXDE (microSD and eMMC Boot)
Bionic Mate (microSD and eMMC Boot)
Fedora (microSD and eMMC Boot)
OpenSUSE (microSD and eMMC Boot)
Q4OS (microSD and eMMC Boot)
Armbian (microSD and eMMC Boot)
NetBSD (microSD and eMMC Boot)
OpenBSD release for ARM64
Chromium (microSD and eMMC Boot)
Arch Linux ARM installer (microSD and USB boot)
Android 7.1 (microSD Boot)
Android 7.1 (eMMC)
Debian Installer for Pinebook Pro
Gentoo Script for Pinebook Pro
Kali Script for Pinebook Pro (microSD and eMMC Boot)
Keyboard
The keyboard firmware binary can be flashed from userspace using the provided open source utility. WARNING: DO NOT update the keyboard firmware before checking which keyboard IC your Pinebook Pro has. Some Pinebook Pro were delivered with a SH61F83 instead of a SH68F83. The SH61F83 can only be written 8 times, this will render the keyboard and trackpad unusable if this limit is reached when step-1 is flashed. See Reddit SH61F83 thread.
Typing special characters
µ [AltGr]+[m]
Ø, ø [AltGr]+[O], [AltGr]+[o]
ß [AltGr]+[s]
§ [AltGr]+[S]
° [AltGr]+[)]
Privacy Switches
PINE64 logo key+F11 WiFi Privacy switch NUM lock LED blinks. 2 blinks = WiFi enabled / killswitch disabled, 3 blinks = WiFi disabled / killswitch enabled. Re-enabling requires reboot (or a command line hack to bind/unbind).
PINE64 logo key+F12 Camera privacy switch CAPs lock and NUM lock LEDs blink together. 2 blinks = enabled, 3 blinks = disabled Can use tools like lsusb to detect camera's presence. If not detected, check privacy switch.
The keyboard operates on firmware independant of the operating system. It detects if one of the F10, F11 or F12 keys is pressed in combination with the Pine key for 3 seconds. Doing so disables power to the appropriate peripheral, thereby disabling it. This has the same effect as cutting off the power to each peripheral with a physical switch. This implementation is very secure, since the firmware that determines whether a peripheral gets power is not part of the Pinebook Pro’s operating system. So the power state value for each peripheral cannot be overridden or accessed from the operating system. The power state setting for each peripheral is stored across reboots inside the keyboard's firmware flash memory.
Trackpad
The trackpad is a reasonable size, has a matte finish that that your finger can slide along easily, and two actuating buttons. It is the only component of the Pinebook Pro held in place with strong adhesive tape. It supports multi-touch functionality. Documentation for the trackpad can be found in Datasheets for Components and Peripherals. The trackpad firmware binary can be flashed from userspace using the provided open source utility (https://github.com/ayufan-rock64/pinebook-pro-keyboard-updater). A fork with more recent changes is also available (https://github.com/jackhumbert/pinebook-pro-keyboard-updater) and may want to be considered instead while feature parity is different.
The trackpad controller is connected to the keyboard controller. All trackpad events go through the keyboard controller and it's software, then to the keyboard controller's USB port. Note that the trackpad does have separate firmware, (which has to be written through the keyboard controller).
Before you start:
WARNING: DO NOT update the trackpad firmware before checking which keyboard IC your Pinebook Pro has. Some Pinebook Pro were delivered with a SH61F83 instead of a SH68F83. The SH61F83 can only be written 8 times, this will render the keyboard and trackpad unusable if this limit is reached when step-1 is flashed. See Reddit SH61F83 thread.
Your Pinebook Pro should be either fully charged or, preferably, running off of mains. This utility will be writing chips on the keyboard and trackpad, so a loss of power during any stage of the update can result in irrecoverable damage to your trackpad or keyboard.
The scripts ought to work on all OSs available for the Pinebook Pro. Some OSs may, however, require installation of relevant dependencies. The instructions below assume a Debian desktop. Newer Pinebook Pro models that come with Manjaro will require a different command to install the proper dependencies.
There are two keyboard versions of the Pinebook Pro: ISO and ANSI. You need to know which model you have prior to running the updater. Firmware update steps for both models are listed below.
What you will need:
  • Connection to WiFi
  • An external USB keyboard & mouse (or access to the Pinebook Pro via SSH)
ISO Model
make
Step 1
sudo ./updater step-1 iso
sudo reboot
Step 2 (after reboot)
sudo ./updater step-2 iso
sudo reboot
ANSI Model
  • NOTE: Running step 1 on the ANSI keyboard model will make the keyboard and trackpad inaccessible until step 2 is ran, so an external keyboard must be connected to complete the update on this model!
make
Step 1
sudo ./updater step-1 ansi
sudo reboot
sudo ./updater step-2 ansi
sudo reboot
When done, if some of the keys produce incorrect characters, please check your OS’s language settings. For ANSI users, the default OS shipped with English UK as the default language. You can change it to English US if desired.
X-Windows & trackpad settings
Some forum members have found that an adjustment to X-Windows will allow finer motion in the trackpad. If you use the Synaptic mouse/trackpad driver, use this command to make the change live:
synclient MinSpeed=0.25
You may experiment with different settings, but 0.25 was tested as helping noticeably.
To make the change persist across reboots, change the file /etc/X11/xorg.conf similar to below:
    Section "InputClass"
        Driver "synaptics"
        MatchIsTouchpad "on"
        Option "MinSpeed" "0.25"
    EndSection
synclient TapButton1=1
synclient TapButton2=3
synclient TapButton3=2
synclient FingerLow=30
synclient PalmDetect=1
synclient VertScrollDelta=64
synclient HorizScrollDelta=64
FingerLow has the same value as 'FingerHigh' in one config (30). It is believed to help reduce mouse movement as you lift your finger, but it's unknown whether synaptic works like this. You may find this config to be comfortable for daily use.
TabButton allows to just tab the touchpad instead of physically pressing it down (to get this click noise).
The right mouse click is emulated by tapping with two fingers on the trackpad. If you feel that this is not very responsive you can try this value:
 synclient MaxTapTime=250
Power Supply
  • Input Power: 5V DC @ 3A
  • USB-C 5V, 15W PD quickcharge
LEDs
In total, there are four LEDs on the Pinebook Pro, three of which are placed in the top-left side of the keyboard, and one near the barrel port:
  1. The red LED next to the barrel port indicates charging, in three ways. First, it will illuminate steadily when either the factory power supply or a USB Type-C charger is connected to the Pinebook Pro, and the battery is getting charged. Second, if the battery is at 100%, the LED will remain turned off regardless of the connected power input; however, this is rather rarely achieved. Third, this LED will flash at 0.5 Hz if there are any problems that prevent charging, such as the battery becoming too hot.
  2. The power indicator LED, above the keyboard, supports three different colours: green, amber and red. It is also capable of flashing to indicate eMMC activity. In the default Debian with MATE build, green LED means power and red means suspend (amber is unused).
  3. The green NumLock LED, above the keyboard.
  4. The green CapsLock LED, above the keyboard.
The NumLock and CapsLock LEDs serve their usual purposes on a keyboard, but they also have a secondary function. When the privacy switches get activated they blink to confirm that the switch has been activated.
Webcam
    • 320 x 240
    • 640 x 480
    • 800 x 600
    • 1280 x 720
    • 1600 x 1200
    • 160 x 120
    • 176 x 144
    • 320 x 240
    • 352 x 288
    • 640 x 480
    • 800 x 600
    • 1280 x 720
    • 1600 x 1200
WIP
Microphones
Microphones not working?
If pavucontrol input doesn't show microphone activity try the Pinebook_Pro#Privacy_Switches; once that is set to on do the below; if that still hasn't fixed it you may want to check that the microphone connector is plugged in (see the Pinebook_Pro#Technical_Reference).
run alsamixer from the command line > hit F6 and select the es8316 > hit F4 to get to the capture screen > select the bar labeled ADC >
> increase the gain to 0dB > change the audio profile in pavucontrol to another with input
Additionally:
you may want to modify ADC PGA to get the levels to where you want them
Bluetooth and WiFi
Hardware Overview
Issues
Wi-Fi Capabilities
Bluetooth Capabilities
Disabling Bluetooth
#disable bluetooth once
#confirm
rfkill
#disable bluetooth on boot**
LCD Panel
  • Model: BOE NV140FHM-N49
  • 14.0" (35.56 cm) diagonal size
  • 1920x1080 resolution
  • 60 Hz refresh rate
  • IPS technology
  • 1000:1 contrast
  • 250 nit brightness
  • 63% sRGB coverage
  • 6-bit color
  • 30-pin eDP connection
External ports list
  • Left side
    • USB 3, Type A
    • USB 3, Type C
  • Right side
    • USB 2, Type A
    • Standard headset jack
    • MicroSD card slot
Using the UART
With the UART switch in the ON position, console is relayed via the audiojack and the laptop's sound is turned OFF. Please ensure that you are using a 3.3 V interface (such as the CH340, FTDI-232R, or PL2303, which are sold in both 3.3 V and 5 V variants) to avoid damage to the CPU. Older version of the serial console cable sold by Pine64 uses wrong voltage level and should not be used; see this forum thread for further information. Recent version of the same cable uses the right voltage level.
Insert the USB plug of the cable into an open USB port on the machine which will monitor, ensuring that the audio jack of the serial cable is be fully inserted into the Pinebook Pro audio port. Run the following in a terminal:
$ lsusb
screen /dev/ttyUSB0 1500000
Please see a separate section that describes reported issues with the NVMe drives in PineBook Pro.
Installing the adapter
This is the link to the PBPro accessories in the store: [[1]]
NVME Identify Controller:
Using as data drive
Using as OS root drive
  • MicroSD
  • eMMC
  • NVMe
Please see Bootable Storage.
Caring for the PineBook Pro
Bypass Cables
Using the SPI flash device
See Pinebook_Pro_SPI
  • You need the kernel built with SPI flash device support, which will supply a device similar to:
    /dev/mtd0
  • The Linux package below, will need to be available:
    mtd-utils
  • You can then use this program from the package to write the SPI device:
    flashcp <filename> /dev/mtd0
The procedures described above are a lot less risky than attaching an external SPI flasher and do not require any additional hardware.
At present, April 19th, 2020, there is no good bootloader image to flash into the SPI flash device. This is expected to change, as there are people working on issue.
FAQ
Software tuning guide
Customizing the Pinebook Pro's default Manjaro KDE system
Watching DRM content (Netflix, etc.)
Most paid online streaming services use Widevine DRM to make their content more difficult to pirate. Widevine is not directly supported on Manjaro KDE, however it is still possible to watch DRM content via the "chromium-docker" package which downloads a 32-bit ARM container and installs Chromium with Widevine inside of that. While not space-efficient, or efficient in general, it's the recommended solution for watching this content on your Pinebook Pro. You can install this package with:
sudo pacman -Sy chromium-docker
Checking GPU capabilities
To see what versions of OpenGL and OpenGL ES are supported by the Pinebook Pro, what driver is in use, and what version of the driver is loaded, install the "mesa-demos" package with:
sudo pacman -Sy mesa-demos
And then run:
glxinfo | grep OpenGL
This will give detailed information about your graphics card and driver, useful for debugging.
Better GPU compatibility and performance
For better graphics performance, you may install the "mesa-git" package, built and supplied in the Manjaro ARM repos. This lets you bring in the latest features, optimizations, and bugfixes for the graphics driver used by the Pinebook Pro. Installation is as simple as:
pacman -Sy mesa-git
Then you may reboot to load the newer driver.
With Mesa 20.2 there is no longer much reason to use this over the standard mesa package, and applications may occasionally break with mesa-git.
Reporting bugs to the Mesa project will help make sure any problems are quickly fixed.
OpenGL 3.3 support
By default, with the current state of the Panfrost GPU driver, the Pinebook Pro supports OpenGL 2.1 and OpenGL ES 3.0. If you want to use OpenGL 3.3, you need to set the system-wide environment variable, open the /etc/environment file with:
kate /etc/environment
And then at the bottom of the file, on a new line, add:
PAN_MESA_DEBUG="gl3"
Then save the file, entering your password when prompted, and reboot the system. When you check your GPU capabilities, it should report OpenGL 3.3 and applications that rely on it should function properly. Note that GL 3.3 support is incomplete and some rendering features do not work yet, notably geometry shaders.
Install Anbox on Pinebook Pro Manjaro 20.10
Youtube video on installing Anbox on Pienbook Pro Manjaro Build 20.10 by LivingLinux
Customizing the Pinebook Pro's previously-default Debian system
Here are some hints on what you can do to customize the Pinebook Pro's previous factory image (aka mrfixit2001 debian build)
# passwd (and follow prompts)
# groupmod -n myself rock
# chfn -f "John A Doe" myself
# passwd myself
# logout
$ blueman-services
Changing the default hostname
> sudo hostnamectl
         Icon name: computer
            Kernel: Linux 4.4.210
      Architecture: arm64
> sudo vi /etc/hosts
127.0.0.1	localhost
127.0.0.1	My_Hostname
fe00::0		ip6-localnet
ff00::0		ip6-mcastprefix
ff02::1		ip6-allnodes
ff02::2		ip6-allrouters
127.0.1.1       linaro-alip
Perform the following steps:
Watching Amazon Prime videos with Chromium
When you create a new user, it will be necessary to launch the Chromium browswer with a specific user agent like below;
chromium-browser --user-agent="Mozilla/5.0 (X11; CrOS armv7l 6946.63.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.121 Safari/537.36"
There may be more tweaks needed.
By default, most Linux distros have a boot screen with a picture. To see all the boot time messages, use one of the following;
Default Debian
vi /etc/default/u-boot
u-boot-update
Manjaro
cp -p /boot/extlinux/extlinux.conf /boot/extlinux/extlinux.conf.`date +%Y%m%d`
chmod a-w /boot/extlinux/extlinux.conf.`date +%Y%m%d`
vi /boot/extlinux/extlinux.conf
Change console=ttyS2,1500000 to console=tty1
Remove the bootsplash.bootfile option and it's parameter.
You can add verbose logging by appending ignore_loglevel to the line where boot splash was.
Improving readability
Some people find that a 14" LCD screen with 1080p, (1920 x 1080), has text and icons a bit too small. There are things you can do to make the screen easier to use and read.
  • Increase the font size
  • Use a font with more pronounced features
  • Increase the various window manager sizes (e.g. increase the height of the tool bar)
  • Change the color scheme to be easier on the eyes. Higher contrast can help usability.
  • Change the window manager's decorations (e.g. use larger icons)
  • Use a workspace manager, with one application per workspace
  • When at home or office, use an external monitor
  • Change the X-Windows DPI
However, do not change the resolution of the LCD screen, otherwise you may end up with a blank / black screen. If that happens, see this troubleshooting section for the fix:
Blank screen after changing builtin LCD resolution
Chromium tweaks
Flags
--disable-low-res-tiling \
--num-raster-threads=6 \
--profiler-timing=0 \
--test-type \
--ignore-gpu-blacklist \
--use-gl=egl \
--enable-pinch \
--flag-switches-begin \
--enable-gpu-rasterization \
--enable-oop-rasterization \
--flag-switches-end
Note that in some cases, this may also decrease performance substantially, as observed when using these flags on the Manjaro KDE desktop. Feel free to experiment to find what is smoothest for you personally.
gVim has performance issue
It appears that using GTK3 can cause very slow scrolling, while Vim in a terminal window works fine.
Simply revert back to using GTK2, (how to do so is somewhat Linux distro-specific).
Another solution may be to run gVim with
GDK_RENDERING=image
environment variable set. It seems that this improves the performance by reverting back to software-only rendering.
Kernel options
CONFIG_PHY_ROCKCHIP_PCIE=m
Hardware video decoding
Older systems, such as the previously-default Debian desktop, use the Rockchip-supplied kernel module rk-vcodec. To check, something like this can be used:
$ lsmod | grep rk-vcodec
    or
CONFIG_RK_VCODEC=y
Newer systems may use a different option as in the configuration below:
CONFIG_VIDEO_HANTRO=m
Troubleshooting guide
Do not to panic if something goes wrong or in an unexpected way. Instead, stop and consider carefully how to undo something, or how to redo it. This particularly applies when flashing a new operating system, or flashing new firmware to the keyboard or touchpad. If everything fails, consider reporting the issue on the forums, with as many relevant details as available.
Please, have a look at the Pinebook Pro Troubleshooting Guide, which details a number of issues you may encounter.
Hardware/Accessory Compatibility
Please contribute to the hardware/accessory compatibility page, which lists the status of hardware tested with the Pinebook Pro. Available hardware categories include the following:
Technical Reference
Disassembly and Reassembly
There are a few mandatory precautions to be taken:
  • Do not open the laptop by lifting the lid while the Pinebook Pro bottom cover is removed - this can cause structural damage to the hinges and/or other plastic components of the chassis such as the IO port cut-outs.
  • When removing the back cover plate, *do not, under any circumstances, slide your fingertips between the metal shell and the plastic frame!* The back cover plate edges are sharp, and when combined with the pressure and movement generated from, specifically, attempting to slide the tips of your fingers along the bottom edge of the plate along the lid-hinge, they *will* slice open the tips of your fingers like a knife.
  • When removing the back cover plate, use care to avoid damaging the speakers. They are stuck to the back cover with double-sided tape, and the thin wires are very delicate.
PinebookPro external screws (this particular unit has suffered damage on screw (4)L)
When disassembling the laptop make sure that it is powered off and folded closed. To remove the bottom cover of the Pinebook Pro, first remove the ten (10) Phillips head screws that hold the bottom section of the laptop in place. There are four (4) short screws along the front edge, and six (6) long screws along the 3 remaining sides. Remove the cover from the back where the hinges are situated by lifting it up and away from the rest of the chassis. The aluminum case is held on only by screws. There are no plastic snaps, and the shell should pull away without any effort. If you experience any resistance at all stop and ensure all ten (10) screws are accounted for.
During reassembly, make sure that the back-screw standoffs are in place and seated correctly. Before replacing the aluminum back-plate, ensure that the speakers are properly seated by pressing gently on the hard plastic edge of the speaker module. Slide the bottom section into place so it meets the front lip of the keyboard section. Secure the front section (where the trackpad is located) in place using the short screws in the front left and right corners. Then proceed to pop in the bottom panel into place. Secure the bottom section (where hinges are located) by screwing in the left and right corners. Then screw in the remaining screws and run your finger though the rim on the chassis to make sure its fitted correctly. Note that the front uses the remaining 4 short screws.
The screws are small and should only be finger tight. Too much force will strip the threads. If after installing screws the back cover plate has not seated properly on one side (which may be caused by the aforementioned misseating of the speakers), open the display and hold the base on either side of the keyboard and gently flex the base with both hands in opposing directions. Once the side pops further in, then recheck the screws on that side. If it does not pop back in, re-open the machine and check for misseated components.
A basic 3D model to print replacement standoffs for the back cover screws is available on Thingiverse, until the official drawings or 3D models are made available.
Internal Layout
Main chips
  • RK3399 system-on-chip (1)
  • LPDDR4 SDRAM (21)
  • SPI NOR flash memory (29)
  • eMMC flash memory (26)
  • WiFi/BT module (27)
Key Internal Parts
Number Type Descriptor
2 Socket PCIe x4 slot for optional NVMe adapter
3 Socket Speakers socket
4 Socket Trackpad socket
5 Component Left speaker
6 Connector Power bridge connector
7 Socket Keyboard Socket
10 Socket Power bridge socket
11 Socket Battery socket
12 Component Trackpad
13 Component Battery
14 Component Right speaker
15 Socket MicroSD card slot
17 Socket USB 2.0 Type A
20 Component microphone
21 Component LPDDR4 RAM
23 Socket Microphone socket
25 Antenna BT/WiFI antenna
30 Socket eDP LCD socket
32 Socket USB 3.0 Type A
33 Socket USB 3.0 Type C
Smallboard detailed picture
Bootable Storage
Boot sequence details
RK3399 boot sequence
Boot devices
At this time, the Pinebook Pro ships with a Manjaro + KDE build with uboot on the eMMC. Its boot order is: SD, USB, then eMMC.
(An update has been pushed for the older Debian + MATE build that improves compatibility with booting other OSs from an SD card. In order to update, fully charge the battery, establish an internet connection, click the update icon in the toolbar, and then reboot your Pinebook Pro. Please see this log for details.)
eMMC information
If the eMMC module is enabled after boot from an SD card, you can detect this change with the following commands as user "root";
echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
Case Dimensions and Data
  • Weight: 1.26Kg
  • Screws
    • Philips head type screws
    • M2 flat head machine screws (measurements in mm)
    • 4 x Small screws (used along the front edge): Head - 3.44, Thread Diameter - 1.97, Thread Length - 2.1, Overall length - 3.05
    • 6 x Large screws: Head - 3.44, Thread Diameter - 1.97, Thread Length - 4.41, Overall Length - 5.85
  • Rubber Feet
    • 18mm diameter
    • 3mm height
    • Dome shaped
SoC and Memory Specification
  • Based on Rockchip RK3399
  • Cortex-A72 (big cluster):
    • Cortex-M0 CPU
    • Architecture: Armv6-M
    • 32 bit only
GPU Architecture
  • Frequency 650MHz
    • OpenCL™ 1.1, 1.2
    • DirectX® 11 FL11_1
    • RenderScript™
  • RAM Memory:
    • LPDDR4
    • 800MHz, (limited by RK3399)
  • Storage Memory:
    • Bootable
  • SPI flash:
    • Pinebook Pro SPI
    • 128Mbit / 16MByte
    • 1 bit interface
Video out
  • USB-C Alt mode DP
Expansion Ports
  • MicroSD card:
    • Bootable
  • USB ports:
Additional hardware
Battery
Display
Lid closed magnet
There is a magnet to detect when the laptop lid is closed, so action can be taken like sleep. This meets up with the Hall sensor on the daughter / small board to detect lid closed.
  • The magnet is located on the LCD panel right side, around 1.5 inches up measure from bottom edge.
Webcam
Audio
  • Built-in microphone
  • Built-in stereo speakers:
    • Oval in design
    • 3 mm high x 20 mm x 30 mm
Network
  • WiFi:
    • 802.11 b/g/n/ac
    • Dual band: 2.4Ghz & 5Ghz
    • Single antenna
  • Bluetooth 5.0
Optional NVMe adapter
  • PCIe 2.0, 5 GT/s per lane
  • Four PCIe lanes, which can not be bifurcated, but can be used with one- or two-lane NVMe cards
  • Power: 2.5 W continuous, 8.25 W peak momentary
Versions
Other Resources
