PineTime
Revision as of 12:29, 19 April 2023 by Ayke (talk | contribs) (→‎Reducing power consumption: SPI flash deep power down)
The PineTime
The PineTime is a free and open source smartwatch capable of running custom-built open operating systems. Some of the notable features include a heart rate monitor, a week-long battery, and a capacitive touch IPS display that is legible in direct sunlight. It is a fully community driven side-project which anyone can contribute to, allowing you to keep control of your device.
Getting started
Read these first!
The frequently asked question can be found in the article PineTime FAQ.
Default OS
The current default operating system on the PineTime is called InfiniTime, you can find more information about the firmware on its GitHub page. First devkits shipped with a proprietary custom firmware.
You can find a list of available firmware and other software here: PineTime Development
Companion Apps
PineTime/InfiniTime needs a companion app to e.g. upload a firmware, get notifications from a phone, or just get the date/time. Here are some companion apps:
  • Gadgetbridge (Android >= 4.4) - Companion mobile app, supports updating firmware/bootloader, send notifications, etc.
  • Amazfish (SailfishOS and Linux) - Companion mobile and desktop app, supports updating firmware/bootloader, send notifications, etc.
  • Siglo (Linux) - Companion desktop app.
  • PinetimeFlasher (Windows) - Companion desktop app, only supports flashing firmware.
  • nRFConnect (iOS) - Only supports flashing firmware. The app is closed source and versions after 4.24.3 don't work for the PineTime anymore
  • InfiniLink (iOS) - Companion mobile app in development. Supports updating firmware/bootloader, setting date and time, Apple Music controls, and battery and heart rate data.
  • itd (Linux)
Specifications
  • Dimensions: 37.5 x 40 x 11mm
  • Weight: 38 grams
  • IP Rating: IP67 (waterproof to 1 meter (sealed edition!))
  • Display:
    • Size: 1.3 inches (33mm) diagonal
    • Type: IPS capacitive touchscreen, RGB 65K colors
    • Display Controller: ST7789
    • Resolution: 240x240 pixels
  • System on Chip: Nordic Semiconductor nRF52832
  • Flash: 512KB with additional 4MB SPI NOR
  • RAM: 64KB
  • Bluetooth: 5.0 (including Bluetooth Low Energy)
  • Sensors: Accelerometer, Heart rate sensor
  • Feedback: Vibration motor
  • Battery: 170-180mAh 3.8V LiPo
Community
Forum
Chat
Developers and coding:
Development efforts
To read more about development on the PineTime, the projects available and more technical details, check out PineTime Development
Useful articles and blog posts
Hardware
Display
PineTime pin ST7789 pin
LCD_SCK (P0.02) SPI clock
LCD_SDI (P0.03) SPI MOSI
LCD_RS (P0.18) Command/Data pin (CD)
LCD_CS (P0.25) Chip select
Notes:
  • LCD_BACKLIGHT_* is used to enable the backlight. Set at least one to low to see anything on the screen.
References:
Adafruit ST7789 driver in cpp
Battery measurement
Button
The button on the side of the PineTime is disabled by default. To enable it, drive the button out pin (P0.15) high.
While enabled, the button in pin (P0.13) will be high when the button is pressed, and low when it is not pressed.
Note that the button consumes around 34µA when P0.15 is left high. To reduce current consumption, set it to low most of the time and only set it to high shortly before reading it. The button needs a short time to give good outputs though, setting P0.15 high at least four times in a row seems to result in enough delay that P0.13 has a stable output.
Touch panel
Pins
  • P0.10 : Reset
  • P0.06 : I²C SDA
  • P0.07 : I²C SCL
I²C
  • Device address : 0x15
NOTE: The controller go to sleep when no event is detected. In sleep mode, the controller does not communicate on the I²C bus (it appears disconnected). So, for the communication to work, you need to tap on the screen so that the chip wakes-up.
NOTE: The I²C bus, also known as TWI bus has known issues, make sure to write your TWI driver with timeouts.
Touch events
Touch information is available from the 63 first registers of the controller. Remember: the device is in sleep mode when no touch event is detected. It means that you can read the register only when the touch controller detected an event. You can use the Interrupt pin to detect such event in the software.
0 ?
1 GestureID : (Gesture code ,
0x00: no gesture,
0x01: Slide down,
0x02: Slide up,
0x03: Slide left,
0x04: Slide right,
0x05: Single click,
0x0B: Double click,
0x0C: Long press)
2 ? Number of touch points
4 X (LSB) coordinate
6 Y (LSB) coordinate
7 Pressure (?)
8 Miscellaneous (?)
NOTES
Registers
Register Address Description
HYN_REG_INT_CNT 0x8F
HYN_REG_FLOW_WORK_CNT 0x91
HYN_REG_CHIP_ID 0xA3
HYN_REG_CHIP_ID2 0x9F
HYN_REG_POWER_MODE 0xA5 0x03 = SLEEP (reset the touchpanel using the reset pin before using this register : pin_low, delay 5ms, pin_high, delay 50ms then write 3 to register 0xA5)
HYN_REG_FW_VER 0xA6
HYN_REG_VENDOR_ID 0xA8
HYN_REG_LCD_BUSY_NUM 0xAB
HYN_REG_FACE_DEC_MODE_EN 0xB0
HYN_REG_GLOVE_MODE_EN 0xC0
HYN_REG_COVER_MODE_EN 0xC1
HYN_REG_CHARGER_MODE_EN 0x8B
HYN_REG_GESTURE_EN 0xD0
Accelerometer
The on board accelerometer in devices shipped before July 2021 is a Bosch BMA421, connected to the I2C bus. Devices shipped after July 2021 use a Bosch BMA425 accelerometer.
Pins
  • P0.06 : I²C SDA
  • P0.07 : I²C SCL
  • P0.08 : Interrupt
I2C Device address : 0x18
The PineTime appears to be able to sleep with a current consumption of only 66µA.
To investigate current consumption, it's a good idea to disable everything possible to get the lowest current consumption possible, and then re-enable things one by one. Here is one way to get a baseline current consumption of 0.17mA (163µA according to my multimeter), as measured from the 3.3V pin with the battery disconnected:
  • Enable the DC/DC regulator. This doesn't affect the current consumption while sleeping, but almost halves the runtime current consumption.
  • Use the low-frequency (32.768kHz) oscillator.
  • Leave all pins in their default state, except for P0.05 (SPI CS) and P0.25 (LCD CS) which should be configured as an output and set to high.
  • Put the SPI flash in deep power-down mode by setting flash CS low, writing the byte 0xb9 on the SPI bus, and setting flash CS high again. It seems necessary to set the flash CS high before setting it to low.
  • Sleep in a loop, using WFE or WFI (if you're using the Nordic SoftDevice, call sd_app_evt_wait instead).
Here are some current consumption statistics (current consumed in addition to the baseline power), roughly ordered from large to small:
Source Current Notes
SWD 3.05mA Power cycle the chip after programming to avoid this, it can hide other inefficiencies.
LCD 5.61mA Set the LCD to sleep mode when not used, using SLPIN.
Backlight high 12.27mA
Backlight mid 5.51mA
Backlight low 1.83mA
ADC left enabled 1.3mA Stopping SAADC brings the current back to the baseline. It seems that it doesn't need to be disabled entirely.
Edge triggered pin interrupts 0-0.47mA? It appears that under some configurations, edge triggered interrupts result in a large power drain. One way to avoid this is by using the pin sense mechanism.
BUTTON_OUT left high 0.04mA See Button for how to avoid this.
SPI flash sleep mode 0.014mA Put it in deep power down mode to avoid this.
SPI, I2C (negligible) SPI and I2C appear to consume very little power when idle, around 1µA or less.
Accessory
The following accessory is compatible with the PineTime.
Watch band
The PineTime uses a standard 20mm watch band / strap. There is a thread in the forum discussing this.
Due to the watches design. Retention for the spring bars are recessed into the watch. Not all 20mm bands / straps work. This is especially the case for Nato style bands / straps being too thick.
Known working bands:
Cases
There are no cases for PineTime yet, but some cases for Fitbit are suitable for it. Cases for Fitbit have one microphone hole, which is unnecessary for the PineTime, but otherwise they fit perfectly.
The community designed the following cases:
Datasheets, Schematics and Certifications
Schematics
Note: The part number for the SPI FLASH in the schematic diagram is not correct, the PineTime features a larger external FLASH device, see below.
Chip Datasheets
NORDIC nRF52832 information:
ARMv7-M information:
Component Datasheets
PMU (Power Management Unit) information:
SPI Flash information:
LCD Panel:
Touchpad information:
Sensor:
Certificates
Manuals
