PineNote Development/Apps
Revision as of 08:23, 18 January 2023 by MichiMolle (talk | contribs)
Development
Here are some resources I have found helpful in learning to develop on embedded Linux devices:
Emulator recommendation for developing and testing PineNote apps: https://github.com/michaelshiel/picom-epaper
The PineNote is a specialized device, mainly due to the eink display having unique display and refresh characteristics. Finding and configuring apps that work well sometimes requires a lot of tweaking and a lot exploring, especially for applications containing fast screen updates and animations, as well as depend on a lot of colours.
Here is a video showing the performance of a few applications.
Desktop Environments
Sway
  • WinkShell "Collected applications, configurations and scripts for using a wlroots-based compositor with an EPD (aka e-ink display). Currently supports Sway only."
Getting touch + pen working on sway
If you notice that touching the screen works, but when you use the pen the mouse coordinates are inverted, don't worry! We can fix it! Set rockchip_ebc.panel_reflection=0 on boot (see this page for more info). Add the following line to your sway config:
# This line rotates the mouse input by 180 degrees. See https://wayland.freedesktop.org/libinput/doc/1.11.3/absolute_axes.html
input "type:table_tool" calibration_matrix -1 0 1 0 -1 1
Gnome
Maximilian's Config
Note: You may need to compile a modified mutter as well.
Application support on the PineNote
Notetaking
xournal++
Works well, writing is pretty quick.
Obsidian
Works well, EInk-Theme can be found here.
Web Browsing
Firefox
Pretty good experience! Enabling GPU acceleration is helpful.
GPU Acceleration in Firefox
See 0ccam's notes here.
"Cloud"
syncthing
High contrast theme can be found here.
