PineNote Development/Apps
Revision as of 20:49, 12 January 2023 by Fxc (talk | contribs) (+cat)
Development
Here are some resources I have found helpful in learning to develop on embedded Linux devices:
Emulator recommendation for developing and testing PineNote apps: https://github.com/michaelshiel/picom-epaper
App support on PineNote
The PineNote is a specialized device. Finding and configuring apps that work well will require a lot of tweaking and a lot exploring. Here is a video showing the performance of a few applications.
Desktop Environments
Sway
0cc4m's config
Getting touch + pen working on sway
If you notice that touching the screen works, but when you use the pen the mouse coordinates are inverted, don't worry! We can fix it! Set rockchip_ebc.panel_reflection=0 on boot (see this page for more info). Add the following line to your sway config:
# This line rotates the mouse input by 180 degrees. See https://wayland.freedesktop.org/libinput/doc/1.11.3/absolute_axes.html
input "type:table_tool" calibration_matrix -1 0 1 0 -1 1
Gnome
Maximilian's Config
Note: You may need to compile a modified mutter as well.
Notetaking
xournal++
Works well, writing is pretty quick.
Web Browsing
Firefox
Pretty good experience! Enabling GPU acceleration is helpful.
GPU Acceleration in Firefox
See 0ccam's notes here.
