PhoenixCard
How to Create MicroSD Card Android Image for Pine A64
What do I need ?
 - The PhoenixCard software from Allwinner.
 - You can download it here
 - A firmware image (.img files)
 - A SD-Card (best Class 10 with 8GB or more SD-Card) - backup everything first, the Card will be formatted!
 - An external SD-Card Reader
 - A Windows PC
Step to create the SD-Card
 - Extract the PhonixCard-xx.rar file in to a blank directory.
 - Navigate into the directory where you installed PhonixCard and start PhoenixCard.exe.
 - Click "DiskCheck" and choose the drive with your SD-Card
 - Click "Img File" and choose the file you want
 - Write Mode must be set to "Startup"
 - Press "Burn"
 - Wait until the burning process is finished (you will se he progress in the progressbar and the notification window)
Booting Up the SD-Card
 - Insert the SD-Card into the Pine A64 and Power-up
 - On the first time boot-up, it might take up to 5 minute for the system to get ready
 - On the sub-sequence boot-up, it will only take about 40 to 60 second for the system to get ready
Related Reference
 Easily Create an Android Bootable SD Card for Allwinner A80 Devices with PhoenixCard Tool
 Boot from SD-Card or flash a ROM with PhonixCard
 How to upgrade tablet pc with Micro SD Card Tutorial
 PhoenixCard Tutorial YouTube Video
