Mainline Hardware Decoding
Revision as of 14:14, 4 July 2023 by Paulfertser (talk | contribs) (Add a link to ready-made Fedora ffmpeg packages, and clarify requirements for mpv linkage)
This page is incomplete, you're welcome to improve it.
Mainline Hardware Decoding refers to video decoding done using hardware accelerators on the mainline Linux kernel (i.e. what sits in Linus' tree).
On most consumer-oriented SoCs, there is what is referred to as a VPU (Video Processing Unit). The VPU is responsible for power-efficient encoding and decoding of videos. Hardware-accelerated video decoding can be useful to get smoother video playback on your devices, lower power consumption, and lower CPU utilisation. Below is information regarding various hardware PINE64 uses and software that works with it.
Hardware
Here's a table of the current support for different hardware. "In review" means the patch series to enable support has been posted to the mailing lists but is undergoing review, "linux-next" means it has been accepted and staged for the next Linux merge window.
SoC
Codec
RK3328 RK3399 RK3566 RK3588
JPEG No Yes No No
MPEG-2 Yes Yes Yes No
MPEG-4 Part 2/H.263 No No No No
VP8 Yes Yes Yes No
H.264/AVC Yes Yes Yes a No
H.265/HEVC In review In review No No
VP9 Yes Yes No No
AVS2 N/A N/A N/A No
AV1 N/A N/A N/A No
Notes
  1. only Hantro, not rkvdec2, so with a maximum resolution of 1080p for now
Cedrus
In 2018, Bootlin launched a crowdfunding campaign to bring a open source Allwinner VPU driver to mainline Linux, which came to be called Cedrus. The Cedrus media driver (For Allwinner SOCs such as A64) supported by mainline Linux supports H.264 and H.265 video decoding as of Linux 5.10, and with 5.11 came VP8 decoding support and a H.264 stateless video decoder interface. For more information refer to the Sunxi wiki.
Hantro
The Hantro media driver supports Rockchip and NXP SoCs including the RK3399 used in the Pinebook Pro and RockPro64. In November 2020 it was announced that Bootlin was working on encoding support for the driver.
rkvdec
rkvdec is the video decoding hardware that's developed by Rockchip presumably in house. It's what Rockchip uses for decoding 4K H.264/AVC, VP9 and H.265/HEVC content. The driver in mainline linux for the first generation rkvdec (used in RK3328 and RK3399) supports VP9 and H.264, patches for HEVC support are also in the process of review.
RK3566, RK3568 and likely RK3588 use a second generation of rkvdec called rkvdec2. No mainline driver for this exists yet. The rkvdec instance on RK3588 additionally supports the AVS2 video codec.
rkdjpeg
rkdjpeg is Rockchip's in-house hardware accelerated JPEG decoder. It can be found on the RK3566 and RK3568 as well as the RK3588.
No mainline driver exists for it so far.
Software
GStreamer
H.264 video decoding is possible when using GStreamer built from source, or an application utilizing it such as Clapper or µPlayer. µPlayer includes a indicator of when hardware acceleration is properly working and in use.
FFmpeg
Mainline FFmpeg currently lacks the necessary patches to use the v4l2-requests based API, but a fork that can utilise it exists. Fedora users can install precompiled binaries from a dedicated repository by one of the Fedora maintainers.
To build it, use something like
git clone -b v4l2-request-n6.0 https://github.com/jernejsk/FFmpeg.git
cd FFmpeg
./configure --enable-v4l2-request --enable-libudev --enable-libdrm --enable-gnutls --prefix=/some/install/prefix/here
make -j$(nproc)
After compiling, you can install it into your specified prefix with
make install
And then modify your PATH to include the prefix's bin directory.
With the patched ffmpeg, you can utilise hardware decoding using the -hwaccel drm parameter, e.g.:
ffmpeg -hwaccel drm -i input.mp4 -f null - -benchmark
to measure how fast it decodes.
mpv
mpv v0.35 or later, used against the aforementioned FFmpeg fork (re-building isn't required when using shared ffmpeg libraries), can be used to play back videos with hardware accelerated decoding. The hardware decoder path features interop with the GPU output, saving an expensive copyback operation. You can utilise the hardware decoding with e.g.:
 mpv --hwdec=drm video
In mpv versions prior to 0.35, you can use the copyback hwdec with:
 mpv --hwdec=drm-copy video
To build an mpv against the FFmpeg in your prefix, you can run
 PKG_CONFIG_PATH="/path/to/your/ffmpeg/prefix/lib/pkgconfig:$PKG_CONFIG_PATH" meson setup build
 ninja -C build
More Resources
See Also
