SOPINE Baseboard
(Redirected from SOPine Baseboard)
Jump to navigation
Jump to search
The SOPINE Baseboard Model A is a baseboard that hosts the SOPINE A64 Compute Module and turns it into a full single board computer. Makers can use this baseboard as reference to develop their own PCBs and for software development during early stages for custom hardware or PCB development.
Specifications
- Gigabit Ethernet
- eMMC module slot
- HD Digital Video Out
- 2x USB 2.0 Host
- Euler bus
- Expansion bus
- PI-2 bus
- Touch Panel Port (TP)
- Display Serial Interface (DSI) port
- IR R/X port
- Real Time Clock port (RTC)
- Lithium battery port
- SMOS sensor interface port
- Optional 802.11GBN + BT 4.0 module expansion module
- Headphone jack
- 3.5mm Barrel Power (5V 3A) port
Schematics and certifications
SOPINE Model "A" Baseboard schematic and PCB board resources:
- SOPINE model "A" Baseboard is an hardware open source project but is not "OSH" compliant
- SOPINE Model "A" Baseboard Schematic capture Rev B DSN source file
- SOPINE Model "A" Baseboard Schematic Rev B PDF file
- SOPINE Model "A" Baseboard PCB Job source file
- SOPINE Model "A" Baseboard PCB Gerber file
- SOPINE Model "A" Baseboard PCB Layout PDF file
SOPINE (together with model "A" baseboard) certification:
- SOPINE with model "A" baseboard FCC Certificate
- SOPINE with model "A" baseboard CE Certificate
- SOPINE with model "A" baseboard RoHS Certificate
Ethernet PHY information:
