Quartz64 Installing Debian
It is possible to install Debian onto eMMC of the Quartz64 from the pgewipout quartz64_ci imaged to a Micro SDcard, or vice versa.
This might be useful if you don't have an eMMC to USB adapter or if the board is inside a case which doesn't allow eMMC removal.
Download artifacts merge-job:archive from https://gitlab.com/pgwipeout/quartz64_ci/-/pipelines
Unpack zip file
Image to a Micro SDcard present in your PC as /dev/sdX:-
sudo -i; xzcat images/rk3566-quartz64-a.dtb.img.xz > /dev/sdX
sudo sync
Boot quartz64-a from microSD card
At boot menu select 1 (Buildroot-recovery)
parted -s /dev/mmcblk1 mklabel gpt
parted -s /dev/mmcblk1 mkpart loader 64s 8MiB
parted -s /dev/mmcblk1 mkpart uboot 8MiB 16MiB
parted -s /dev/mmcblk1 mkpart env 16MiB 32MiB
parted -s /dev/mmcblk1 mkpart efi fat32 32MiB 544MiB
parted -s /dev/mmcblk1 set 4 boot on
parted -s /dev/mmcblk1 mkpart root ext4 544MiB 100%
dd if=/dev/mmcblk0p1 of=/dev/mmcblk1p1
dd if=/dev/mmcblk0p2 of=/dev/mmcblk1p2
dd if=/dev/mmcblk0p3 of=/dev/mmcblk1p3
mkdosfs -F 32 -n "efi" /dev/mmcblk1p4
mke2fs -L "rootfs" /dev/mmcblk1p5
sync
reboot
At boot menu select 2 (Debian-Installer)
choose manual partitioning
set partition #5 of mmcbkl1 to be /, format to ext4 and complete the installation
reboot (installer will do this anyway)
mkdir /mnt/mmcblk0p5
mkdir /mnt/mmcblk1p4
mkdir /mnt/mmcblk1p5
mount /dev/mmcblk0p5 /mnt/mmcblk0p5
mount /dev/mmcblk1p4 /mnt/mmcblk1p4
mount /dev/mmcblk1p5 /mnt/mmcblk1p5
cp -a /mnt/mmcblk0p5/dtbs /mnt/mmcblk1p4/
cp /mnt/mmcblk0p5/vmlinuz /mnt/mmcblk1p4/
mkdir /mnt/mmcblk1p4/extlinux
touch /mnt/mmcblk1p4/extlinux/extlinux.conf
echo 'label Debian on eMMC' >> /mnt/mmcblk1p4/extlinux/extlinux.conf
echo 'linux /vmlinuz' >> /mnt/mmcblk1p4/extlinux/extlinux.conf
echo 'fdt /dtbs/rockchip/rk3566-quartz64-a.dtb' >> /mnt/mmcblk1p4/extlinux/extlinux.conf
echo 'append earlycon=uart8250,mmio32,0xfe660000 console=ttyS2,1500000n8 root=/dev/mmcblk1p5 rootwait' >> /mnt/mmcblk1p4/extlinux/extlinux.conf
cp /mnt/mmcblk0p5/kernel-modules.tar.gz /mnt/mmcblk1p5/root/
The following lines (upto adding the boot partition to fstab) are optional. Debian will boot just fine if the boot partition isn't in fstab and you may prefer to manually mount it when you want to change the kernel:-
blkid /dev/mmcblk1p4
The output will show the UUID of your boot partition:-
/dev/mmcblk1p4: LABEL_FATBOOT="efi" LABEL="efi" UUID="5985-9C7B" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="efi" PARTUUID="93226dfa-53af-4400-8aab-239ff7900dd0"
echo 'UUID=UUID_from_above /boot vfat defaults 0 1' >> /mnt/mmcblk1p5/etc/fstab
chroot /mnt/mmcblk1p5
dpkg -l |grep image
To show which kernel images Debian has installed:-
ii linux-base 4.6 all Linux image base package
ii linux-image-4.19.0-18-arm64 4.19.208-1 arm64 Linux 4.19 for 64-bit ARMv8 machines (signed)
ii linux-image-arm64 4.19+105+deb10u13 arm64 Linux for 64-bit ARMv8 machines (meta-package)
Uninstall them:-
dpkg -P linux-image-4.19.0-18-arm64 linux-image-arm64
cd /root
tar -xzvf kernel-modules.tar.gz
mv lib/modules /lib/
exit
halt
Remove MicroSD card and boot into eMMC.
