Wifi Remote I2c
PMWF01A : Wifi Remote I2c Module
Quick Start Guide
Hardware Setup
Hardware Setup
  • Make sure that the driver for USB/UART Programming/Console Adapter (PMPROG01) is properly install and the PC is detected it as Comm Port.
  • The USB/UART Bridge is base on Silicon Lab CP2012 chipset.
  • USB/UART Programming/Console Adapter (PMPROG01) driver can be Download here
  • Connect the USB/UART Programming/Console Adapter (PMPROG01) to the Wifi Remote I2c Device.
Setting Configuration
Termite Setup Screen
Help Command
  • For windows system, you can use terminal emulator program Termite to configure the device.
  • Termite can be downloaded at http://www.compuphase.com/software_termite.htm
  • Make sure the 'Port' setting is refer to the USB/UART Programming/Console Adapter (PMPROG01)'s Comm Port.
  • Follow the setting according to the setup screen capture. (57600Baud 8-N-1)
  • Once Termite configuration is done, press 'OK' to save the setting.
  • On the Wifi Remote I2c Device, Press the configuration button to allow the device to go into configuration mode.
caption Press Config Mode button to go into configuration mode
  • Type 'help' to show the command available for configuration.
  • Type 'show' to list out current configuration.
  • To Set the PineA64 IP address in to the device, enter (we will be using IP address 192.168.0.230 as example)
  server 192.168.0.230
  • To configure the Wifi AP SSID and Password, (eg SSID=TestingWifi and Password=12345 )
  wifi TestingWifi 12345
  • The SSID and password are case sensitive. Please make sure it is input correctly.
  • Once configuration is done, type 'exit' to exit configuration mode and allow the device to reboot.
  • After reboot, the Red LED indicator will be blinking fast. Once connected to the WiFi Access Point, the LED indicator will go into slow blink.
  • The hardware configuration is done.
Setup the PineWifiServer
  • Copy PineWifiServer 16031401.gz into your PineA64 with linux on it.
  • Unzip the file using gunzip.
  • Add Execution flag on both of the file by
 chmod +x PineWifiServer
  • Start the PineWifiServer by
 ./PineWifiServer
  • Once the server is started, you will notice that the LED indicator on the Wifi Remote I2c Hardware will change from slow blinking to always on.
  • To login into the server, telnet into localhost port 10000
 telnet localhost 10000
File:Wr putty login.JPG:thumb
  • To show current connect Wifi Remote I2c type 'list' in small capital letter.
  • To see all available command, type 'help'.
  • To exit the console, type 'exit'.
  • Please take note that you are only allow one login simultaneously. The second telnet login will be rejected.
Download
