Wifi Remote I2c
Quick Start Guide
Hardware Setup
  • Make sure that the driver for USB/UART Programming/Console Adapter (PMPROG01) is properly install and the PC is detected it as Comm Port.
  • USB/UART Programming/Console Adapter (PMPROG01) driver can be Download here
  • Connect the USB/UART Programming/Console Adapter (PMPROG01) to the Wifi Remote I2c Device.
Setting Configuration
  • For windows system, you can use terminal emulator program Termite to configure the device.
  • Termite can be downloaded at http://www.compuphase.com/software_termite.htm
  • Make sure the 'Port' setting is refer to the USB/UART Programming/Console Adapter (PMPROG01)'s Comm Port.
  • Follow the setting accordingly
Network Layout
File:Wifi remote i2c topology.png
Download
