User talk:Fxc
Revision as of 02:23, 29 April 2021 by Mikehenson (talk | contribs)
Redundant template subpages
Hello!
Could you, please, delete two redundant template subpages, Template:TOC right/doc and Template:TOC right/styles.css? My intention was to separate the CSS code and provide documentation, as it's the case on Wikipedia, but that ended up as requiring too much work. The "all-in-one, no documentation" version of the TOC right template should be good for now.
Any help would be appreciated. -- Dsimic (talk) 04:08, 8 April 2021 (UTC)
Done. Make sure the page is still usable on small screens such as the PinePhone and on big screens. I highly recommend to move the channel list back to the left. I've also added a documentation draft to the template. --Fxc (talk) 14:42, 9 April 2021 (UTC)
Thank you very much! I had a look at the main page on a narrow screen size, and it looks rather fine. In my opinion, placing the TOC on the left and below the lead section makes the whole page longer than necessary, which is actually detrimental to the navigation on the page. There isn't too much contents on the main page, which makes having a TOC actually rather redundant; some kind of a compromise was to move the TOC to the right side. Also, I've added some documentation to the template, and I've eliminated the redundant vertical whitespace that the template inserted at the top of the main page. -- Dsimic (talk) 16:46, 10 April 2021 (UTC)
Can you please explain why you keep removing my additions to PinePhone_Carrier_Support -- Mike 02:22:09 29 April 2021 (UTC)
