User talk:AntonMadness
Revision as of 07:58, 1 July 2020 by JtR (talk | contribs)
manjaro-arm-installer now runs on the PineBook Pro?
Hey AntonMadness, I've seen that you've edited the PBP Software releases page with the following hint regarding the manajaro-arm-installer: "The script can also be run from SD to install an image to the eMMC". Do you know how to acclompish this? Unfortunately I've only found information saying, that the installer only runs on x86-machines. But if it runs on SD, may it also even run from USB? Also, how exactly do I run the script from SD - do you mean I run it from an SD-based OS? Could you maybe give a source or something, which gives me more information? :) JtR (talk) 07:57, 1 July 2020 (UTC)
