User talk:AntonMadness
manjaro-arm-installer now runs on the PineBook Pro?
Hey AntonMadness, I've seen that you've edited the PBP Software releases page with the following hint regarding the manajaro-arm-installer: "The script can also be run from SD to install an image to the eMMC". Do you know how to acclompish this? Unfortunately I've only found information saying, that the installer only runs on x86-machines. But if it runs on SD, may it also even run from USB? Also, how exactly do I run the script from SD - do you mean I run it from an SD-based OS? Could you maybe give a source or something, which gives me more information? :) JtR (talk) 07:57, 1 July 2020 (UTC)
Hey JtR. Sorry, just found this talk page. No idea how it's supposed to work. I'm a bit new to wiki edits etc. It's been a long time since I've done that procedure. What I remember is putting a Manjaro Image on the SD card, insert it in the PBP, running the script to install to the on boar emmc. But it's too long ago to be sure and my PBP is still running fine (maybe some day I'll screw the pooch again with some dd ^^ ).
