User:Valenoern/Pine64 Screws
< User:Valenoern
Revision as of 00:35, 9 April 2023 by Valenoern (talk | contribs) (Nylon screw picture)
The screws section on the ROCKPRo64 page was about to get unexpectedly long, so I have decided to create another page to contain only notes on screws.
ROCKPro64
Correct measurements
Unknown. M2.5 was too narrow
Nylon screws
Nylon screw compared with original metal screw
I recently found out there are plastic screws available in a clear white colour, so I immediately had to see how these would look on the ROCKPro64.
I was not able to find screws which would be both the right length and the right thread diameter, at least so far. The ones I tried which were closest to the measurements I'd taken were not wide enough and simply fell through the hole.
However, given the right diameter I might actually recommend these.
