User:Talpa/Backup
Revision as of 23:36, 7 April 2023 by Fxc (talk | contribs) (Fxc moved page PineNote Development/Backup to User:Talpa/Backup without leaving a redirect: Copy of PineNote_Development/Flashing. Please don't draft in the main space)
Note: A backup of the content of the internal eMMC before any of the irreplaceable unique data gets messed up is mandatory.
The first 64 sectors of the eMMC and the waveform partition contains irreplaceable data unique to your PineNote and must be backed up.
Depending of your personal level of data hoarder you may want to backup more than this or even just everything (the large userdata partition is supposed to be able to be repopulated as empty space by Android)
In any case it is easier to restore/extract data from a backup than not having one if you need one.
Manually using rkdeveloptool
Dorian has some nice notes regarding the PineNote
Don't forget to install a patched U-Boo for reading beyond 32MB and to respect the 2GB limit/bug of the current rkdeveloptool as per his notes
Build rkdeveloptool:
git clone https://gitlab.com/pine64-org/quartz-bsp/rkdeveloptool.git
cd rkdeveloptool
mkdir build
cd build
cmake ..
Download mode Enter the download mode by placing the pen as pictured below. A magnet placed where the pen's cap is should also work (haven't tried). I guess the dot on the case also indicates the position of the sensor.
placing pen on the back
lsusb should now recognize the PineNote as:
2207:350a Fuzhou Rockchip Electronics Company USB download gadget
List partitions:
> rkdeveloptool list-partitions
00                16384              24575       4194304       uboot
01                24576              32767       4194304       trust
02                32768              36863       2097152       waveform
03                36864              45055       4194304       misc
04                45056              53247       4194304       dtbo
05                53248              55295       1048576       vbmeta
06                55296             137215      41943040       boot
07               137216             145407       4194304       security
08               145408             407551     134217728       recovery
09               407552            1193983     402653184       backup
10              1193984            3291135    1073741824       cache
11              3291136            3323903      16777216       metadata
12              3323904            9697279    3263168512       super
13              9697280            9730047      16777216       logo
14              9730048            9861119      67108864       device
15              9861120          241827775  118766927872       userdata
Warning: this process is very new! Proceed at your own risk.
See instructions on this artifact. It will instruct you on extracting the rootfs into an empty ext4 partition. This can be done from Linux or Android. Further instructions on building your own rootfs can be found here.
Automated backup using a script and rkdeveloptool
pinenote-backup is a python script for detecting the partitions and automating the backup of partitions or the whole disk.
It also requires a patched u-boot but automatically handles the 2GB limit by splitting up larger reads into smaller ones
Using the factory Android installation
TODO
Using a user installed Linux
A Linux installed to the cache partition should be able to easily backup everything over WiFi or to a USB stick/disk using dd.
However the user would need to backup the cache partition themself (if they want that).
And more importantly they would only be getting the backup after they started playing with the content of the eMMC.
