User:RemDogKap/SandBox/First Setup
< User:RemDogKap‎ | SandBox
Revision as of 16:03, 8 June 2023 by RemDogKap (talk | contribs) (minor formatting)
The Star64 is a 64 bit, 4 core Single Board Computer.
Prerequisites
Flashing the image
There are currently two working distributions of Linux compatible with the Star64, Pocky and Armbian. Both distributions use the same kernel[???].The Pocky distribution is built using Yocto which is an open source project used to create Linux distributions for embedded devices. The Pocky distribution currently has some GPU support and is further developed than Armbian. Both distributions use the deb package manager. The Armbian distribution is based on Debian/Ubuntu with changes to make it lightweight and compatible with ARM/RISC-V development boards.
More information about support for features can be accessed here.
Pocky Install
Linux
First, if not already installed, install bzip2 and wget.
$ sudo apt update && sudo apt install bzip2 wget
Second, download a compressed disk image (.wic.bz2) from here (source code available here) using wget. There are three types of images, one command line only and two desktop environments.
  • star64-image-minimal - A command line only image
  • star64-image-weston - A Weston/Wayland "Demo" image.
  • star64-image-plasma- A Plasma Based Image.
$ wget  https://pine64.my-ho.st:8443/${Name of Image File}
Where ${Name of Image File} is the name of your chosen image file. Example:
$ wget https://pine64.my-ho.st:8443/star64-image-minimal-star64-1.2.wic.bz2
Next, decompress the file using bzip2.
$ bzip2 -d ${Path to Image File}
Where ${Path to Image File} is the path to your image file. Example:
$ bzip2 -d star64-image-minimal-star64-1.2.wic.bz2
Windows
Armbian Install
SD Card
eMMC Flash
[Not sure if eMMC flash is any different, I (Rem) do not have experience using it]
Using SD Card
[As mbuggle said in Discord #Star64 on 2023-06-05 1:10 AM CDT (Message ID: 1115160713439223859) it seems like it may be possible to use an SD Card to first boot, use the SSD to transfer the disk image to the eMMC, remove the SD Card and boot from eMMC]
Using eMMC to USB Adapter
