User:RainSlide/CSS Boxes
< User:RainSlide
Revision as of 04:28, 27 September 2021 by RainSlide (talk | contribs) (→‎float: left: modify desc)
This page is mainly for showing why Template:Hint, Template:Note and Template:Warning uses display: table to archive compatibility for both adaptive width and floating sibling(s).
If a set of style is not compatible with adaptive width, it span to its full width even when it don't need to.
If a set of style is not compatible with floating sibling(s), the element may still work well with some short content in it; in another word, it may still looks fine when its content width + margin + padding + border is lower than the "remaining width" lefted by the floating sibling(s). So we have to use Lorem ipsum (as well as a floating box, for sure) to test it.
Ideally, you may just set the widths to fixed values, and pretend nothing happens and CSS is awesome. However, the content container of MediaWiki got adaptive width, and maybe you are maintaining a MediaWiki Template, with only inline styles.
CSS
is
Awesome
Table
display: table
This is a floating box.
No problem for adaptive width.
No problem for floating siblings.
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
This is a wikitable
No padding when it's in another table, however.
display: table-cell
Table cells are not blocky! Without this sentence, they are in the same row by now.
Table cells have no margin.
display: table-caption
No adaptive width.
It's hiding.
There can only be one table caption per table, or, per anything.
display: table-row
No problem for adaptive width?
No problem for floating siblings?
Table rows have no margin, padding or border.
Other table display values works like table rows, or won't even display its contents.
A new block formatting context
See guide Block formatting context on MDN.
float: left
Will everything go right with float set to left?
It falls off from its floating siblings.
No, something falls down.
display: inline-block
But inline blocks are inline.
It also falls off from its floating siblings.
display: flow-root
No adaptive width.
This is the end of part one. Part two will feature contain: content, width: max-content, box-sizing: border-box; max-width: 100%, display: flex, display: grid, and more, if I ever got time to work on the part two.
