User:Oogwaymaki
Revision as of 23:55, 25 June 2020 by Oogwaymaki (talk | contribs)
Summary:
After following these steps:
- You'll have a Custom UBOOT (Crust ENABLED) that allows MultiBOOT Using 3 different OS's depending on key combo of volume up / volume down or none pressing on boot - You'll be able to experiment on SD Card without Touching your EMMC - You'll learn how to take a part a PINE PHONE IMAGE (most, and put each OS On one partition
All the information here, has been discussed in the open source community on web sites. I have simply developed a process on how to do this on the pine phone.
We use utilities such as Cross Compilation, Uboot, Patches, which will be credited.
First step, make sure you have a cross compiler for your Computer, for particularly the arm device, you will need to download a few packages, I assume we're using Debian Linux (if your using another OS you can find similar commands by searching on the web or to make it simpler download a docker Debian image, and install the pre-requisites which I will list here for Debian)
You an also use vagrant/virtual box VMware or other virtualization platforms.
First please install these Dependencies:
apt-get install gcc-aarch64-linux-gnu g++-aarch64-linux-gnu build-essential autoconf libtool cmake pkg-config git python-dev swig3.0 libpcre3-dev nodejs-dev crossbuild-essential-arm64 git
The following main sources are needed:
This will download quite a few sources needed for Uboot and existing OS's available to PinePhone
https://github.com/crust-firmware/meta.git
We will also apply this patch:
https://megous.com/git/u-boot/patch/?id=0ab6225154c3d8b74f06fb3b181b52a9a64b4602
(I will attach the one I used I had to modify the above patch to work with the code.)
The crust-firmware also says you need to download the or1k compiler:
https://musl.cc/or1k-linux-musl-cross.tgz
I suggest untarring this in the /opt folder.
1. Once you have these dependency:
  1. cd /usr/src
  2. git clone https://github.com/crust-firmware/meta.git
  3. cd /usr/src/meta
Edit the following file Make file
  1. Cross compiler
CROSS_aarch64 = aarch64-linux-musl- CROSS_or1k = or1k-linux-musl-
  1. General options
DEBUG ?= 0 REPRODUCIBLE ?= 0
  1. Board selection
BOARD ?= pinebook
Example:
  1. Cross compiler
CROSS_aarch64 = /usr/bin/aarch64-linux-gnu- CROSS_or1k = /opt/or1k-linux-musl-cross/bin/or1k-linux-musl-
  1. General options
  1. Board selection
BOARD ?= pinephone
  1. make
(this should take a 10-30 mins depending on speed..I hope less than 30 mins!!)
After making apply the patch..
Sites Referenced/Inspiration:
https://www.96boards.org/documentation/iot/ https://github.com/dreemurrs-embedded/Jumpdrive https://github.com/dreemurrs-embedded/Pineloader https://www.thegeekstuff.com/2014/12/patch-command-examples/ https://stackoverflow.com/questions/9980186/how-to-create-a-patch-for-a-whole-directory-to-update-it
patch from the link above to work:
