User:Oogwaymaki
Revision as of 22:45, 25 June 2020 by Oogwaymaki (talk | contribs) (MultiBoot and setting up Multiple OS's on the sd card without touching the EMMC Operating system.)
All the information here, has been discussed in the open source community on web sites. I have simply developed a process on how to do this on the pine phone.
We use utilities such as Cross Compilation, Uboot, Patches, which will be credited.
First step, make sure you have a cross compiler for your Computer, for particularly the arm device, you will need to download a few packages, I assume were using Debian Linux (if your using another OS you can find similar commands by searching on the web or to make it simpler download a docker Debian image, and install the pre-requisites which I will list here for Debian)
First please install these Dependencies:
sudo apt-get install gcc-aarch64-linux-gnu g++-aarch64-linux-gnu
Sites Referenced:
https://www.96boards.org/documentation/iot/
