User:Mikeb/PinePhone Software Tweaks
Revision as of 18:26, 18 April 2023 by Fxc (talk | contribs) (Fxc moved page PinePhone Software Tweaks to User:Mikeb/PinePhone Software Tweaks without leaving a redirect: Please improve it in your userspace, this is not article quality. NM used in which distribution and why distribution-specific!? Strange init scripts instead of proper configurations etc.)
Linux
Network
Randomized MAC-addresses
If your PinePhone's Linux distribution uses a NetworkManager for connectivity, for the anonymity purposes it is possible to randomize the WiFi MAC address for each re-connection. Open the /etc/NetworkManager/NetworkManager.conf file with a text editor (you may need the sudo rights) - and under the existing configuration like:
[main]
dhcp=internal
add the following lines:
[device]
wifi.scan-rand-mac-address=yes
[connection]
wifi.cloned-mac-address=random
Autostart control
If your PinePhone's Linux distribution uses a NetworkManager for connectivity, it memorizes the last used "Enable/Disable" settings in a /var/lib/NetworkManager/NetworkManager.state file:
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
- and it follows them during the next boot. For security reasons, you may want to set up your PinePhone so that WiFi and Modem connections are always disabled on each boot - regardless of the last used settings! - and these connections could be manually enabled by you in Settings after boot when there's a need. To set up this, add the following lines to the NetworkManager init script just before the launch of a NetworkManager itself:
sed "s/^WirelessEnabled=true/WirelessEnabled=false/" -i /var/lib/NetworkManager/NetworkManager.state && sync
sed "s/^WWANEnabled=true/WWANEnabled=false/" -i /var/lib/NetworkManager/NetworkManager.state && sync
In example, if your PinePhone's Linux distro (i.e. postmarketOS) uses OpenRC as an init manager, open /etc/init.d/networkmanager init script and add the following section after depend() section:
start_pre() {
BSD
Android
