User:Fxc
Revision as of 23:41, 18 January 2023 by Fxc (talk | contribs) (fix)
Pinebook notes
Merge https://wiki.pine64.org/wiki/1080P_Pinebook_Software_Releases into https://wiki.pine64.org/wiki/Pinebook_Software_Releases
Compatibility
11.6″ Pinebook 14″ Pinebook 1080P Pinebook
PineBuds Pro suggestion
== Community projects ==
The following community projects are currently being worked on:
  • Wireless charging, bringing wireless charging to the PineBuds Pro case using the vacant contacts
  • Silicone case, a transparent silicone case, bringing an improved grip to the case
Suspicious protectionfilms24.com link spam
Software state draft
Functionality Component Status (pre-flashed)¹ Status (updated)² Notes
Bootloader U-Boot Critical bugs Some critical software bugs currently not fixed yet: A drained battery causes U-Boot to bootloop[1]; Occasionally the eMMC fails to boot[Citation]
SPI Unfinished SPI memory is currently empty in the Explorer Edition batch, a corrupted installation on the eMMC has a higher boot priority than a fresh microSD card installation, leading to a involved recovery procedure[Citation]
Operating System Stability Critical bugs WIP The pre-flashed and outdated operating system on the eMMC often gets corrupted after updating[2];
Suspend Not working Experimental Suspend only available in recent specific images[Citation]
Updates Critical bugs WIP The pre-flashed and outdated operating system on the eMMC often gets corrupted after updating[Citation]; Pacman database lock preventing updates[Citation]; Keyring bug[Citation]
Modem Stability Critical bugs The modem crashes frequently, which can lead to missed calls[Citation]
Phone WIP The modem crashes frequently, which can lead to missed calls[Citation]; bad call audio quality[Citation]; software improvements expected within multiple months and contributions are welcome.
SMS Working SMS functionality is expected to work. In certain cases the functionality might be blocked by a clogged modem[Citation] or by the provider blocking specific TANs in their network[Citation].
MMS WIP MMS functionality is integrated into the application "Spacebar", some bugs remaining and expected
Push notifications Not implemented Receiving push notifications while the phone is suspended is not implemented
Components LCD Working
Touch Working
Rear camera Not working Driver not implemented yet, camera not operational
Front camera Not working Driver not implemented yet, camera not operational
Camera flash Unknown
WiFi Working WiFi is expected to work. Note: Proprietary firmware and some remaining tasks, such as looking into "monitor mode"
Bluetooth WIP Bluetooth not necessarily working for calls yet due to missing audio routing Proprietary[Citation]; Bluetooth in general dodgy under Pulseaudio.[3] Note: Proprietary firmware
GNSS/GPS WIP aGPS to be implemented; long waiting times to get a fix; No preinstalled application
Sensors Unknown Status of "3 Axis Magnetometer", "Geo Magnetic Sensor", "Ambient light / Proximity", "Accelerometer / Gyroscope" is unknown.
Vibration motor Working
Notification LED Unknown
Buttons Working Power buttons and volume buttons are working.
Accessory compatibility Keyboard Add-on WIP The keyboard add-on compatibility is work-in-progress. Top row symbols not implemented as designed[Citation]; Keyboard hot-plugging not supported[Citation]; Battery state not exposed in the pre-flashed operating system state[Citation]; general driver bugs[Citation]
LoRa Add-on Not implemented No software support implemented
Qi Wireless Charging Add-on WIP Wireless charging with the add-on case is expected to work to some degree. Certain software and driver functionality is missing, details will follow in a bug report.[Citation]
Fingerprint Reader Add-on Not implemented No software support implemented
Software notes Waydroid Software rendering only Waydroid is an Android container used to run Android applications. Currently can only be started using software rendering [Citation]
¹ Status of the feature at the time of the last factory installation without updates
² Status of the feature with an up-to-date reference image
Chat
  • Inclusive language, Linux
Test 2
Warning:
Warning:
Warning:
Warning:
Warning: Test
Warning: Test
Warning: Test
Warning: Test
Test
Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua.
Safety
Charging and Battery
Notes:
  • Correct charger
  • High power usage in certain scenarios
  • Handling of the battery
  • (Optional: Charging keyboard and phone at the same time)
  • (Optional: Connecting a USB-C to USB-C cable from phone to keyboard)
Ubuntu Touch
Ubuntu Touch
A Mobile Version of the Ubuntu Operating System made and maintained by the UBports Community. Ubuntu touch is a mobile version of Ubuntu developed by the UBports community.
Download location UBports PinePhone project
user-id/password abc
123
What works, what does not work? Scroll down to the bottom of this page.
How to contribute and report defects? See UBports gitlab page.
Contributions See UBports website for how to donate.
Installation
Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortis nisl ut aliquip ex ea commodo consequat.
Notes
Description
Author Test
License CC0
SVG location Test
Licenses template
Test:
CC some rights reserved.svg
Cc-by new white.svg
This file is licensed under the Creative Commons Attribution 3.0 Unported license.
Collapsible test
