User:Arwen/repartition
< User:Arwen
Revision as of 00:29, 23 January 2020 by Arwen (talk | contribs) (Initial creation.)
Repartitioning your Pinebook Pro
There are multiple reasons to desire a different file system layout.
Make a backup
Backup your existing OS and data. Multiple times if it's important data.
Read about recovery options
Worse case, you may have to open up your Pinebook Pro and perform a boot with
Understand the risks
If you perform the steps wrong, you could end up with an un-bootable laptop. Even using a SD card may not help. If the eMMC thinks it's good enough to boot, it may not try the SD card.
Using a MicroSD card
This example shows using a SD card as temporary boot location.
