User:Arwen/Gentoo
< User:Arwen
Revision as of 18:47, 21 December 2019 by Arwen (talk | contribs) (Initial creation.)
Installing Gentoo Linux on Pinebook Pro
Here is Arwen's guide to installing Gentoo Linux on a Pinebook Pro. It's a work in progress, so Goals:
  • Gentoo Linux on ARMv8 / 64 bit
  • Initial RAM disk on "/boot"
  • OpenZFS version 7.13, or >=0.8.3
  • OpenZFS used for root pool & data pool, (but perhaps not for "/boot"
  • Allow for encrypting root pool, (which needs prompting for passphrase in InitRD)
Pre-requisits:
  • Have a bootable OS of Unix type, preferable Linux
  • There must be a place you can install Gentoo Linux, like another disk partition or MicroSD card
  • After installation, the boot process must allow you to boot off the newly installed Gentoo Linux. For example, using a MicroSD card.
Download:
Follow the normal "chroot" install.
