U-Boot
Revision as of 02:35, 15 February 2021 by Aberts10 (talk | contribs)
This page is incomplete, you're welcome to improve it.
It is helpful to have a debugging serial cable for this.
Warning: This is purely U-boot build instructions at this time! You will not have crust for your Pinephone should you follow this guide.
Building uboot manually
Prerequisites
These instructions are written with a host Arch Linux desktop system in mind.
This guide will be especially useful if you are looking to overclock the ram on your Pinephone following the information found here.
You must have these packages installed: dtc swig bc aarch64-linux-gnu-gcc
If you are using a different system such as Ubuntu, there are plenty of cross compilation instructions available online with which you can grab the needed package names from, and then proceed to follow these instructions.
Compilation
This guide is written with the Pinephone in mind. On other devices you will need to set a different platform variable and likely use a different uboot source with patches oriented towards your device.
Note by default these instructions utilize all of your computers cores to compile thanks to the -j and $(nproc) parameters. If you wish to only use one core to compile, or change the number of cores used for example to only two cores, then you can either completely remove the -j$(nproc) parameter from the make commands, or just take off $(nproc) and add the number of threads you want used in it's place: -j4
First, You need to compile ATF (Arm Trusted Firmware):
 git clone https://github.com/crust-firmware/arm-trusted-firmware/
 cd arm-trusted-firmware
 CROSS_COMPILE=aarch64-linux-gnu-
 export CROSS_COMPILE
 export ARCH=arm64
 make PLAT=sun50i_a64 -j$(nproc) bl31
 cd ..
After ATF is compiled clone u-boot and copy the bl31.bin file into the u-boot directly.
git clone https://gitlab.com/pine64-org/u-boot.git
cp build/sun50i_a64/release/bl31.bin ../u-boot/
cd ..
git clone https://github.com/crust-firmware/crust
cd crust
export CROSS_COMPILE=or1k-linux-musl-
make pinephone_defconfig
make -j$(nproc) scp
cp /build/scp/scp.bin ../u-boot/
If you do not wish to have crust in your uboot build, then you can skip exporting SCP
 cd u-boot/
 git checkout crust
 export BL31=bl31.bin
 export ARCH=arm64
 export SCP=scp.bin
 make distclean
 make all -j$(nproc)
Uboot installation
Once successfully compiled you can proceed to flash the device
Warning: Replace [CHANGE THIS] with the location of your SD card
sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/[CHANGE THIS] bs=1024 seek=8
If you are compiling uboot in order to overclock your DRAM you can check if it was successful by reading the values of /sys/kernel/debug/clk/clk_summary
Pboot multi-bootloader
One of the smallest and fastest pinephone bootloaders, it was developed by Ondrej Jirman with the ability of booting multiple distros on the pinephone in mind.
More information can be found here
External Links
Sunxi Uboot Wiki
Uboot build instructions
