U-Boot
Revision as of 22:06, 20 October 2020 by Aberts10 (talk | contribs)
This page is incomplete, you're welcome to improve it.
It is helpful to have a debugging serial cable for this.
Warning: This is purely U-boot build instructions at this time! You will not have crust for your Pinephone should you follow this guide.
Building uboot manually
Prerequisites
These instructions are written with a host Arch Linux desktop system in mind.
This guide will be especially useful if you are looking to overclock the ram on your Pinephone following the information found here.
You must have these packages installed: dtc swig bc aarch64-linux-gnu-gcc
If you are using a different system such as Ubuntu, there are plenty of cross compilation instructions available online with which you can grab the needed package names from, and then proceed to follow these instructions.
Compilation
This guide is written with the Pinephone in mind. On other devices you will need to set a different platform variable and use different uboot sources.
First, You need to compile ATF (Arm Trusted Firmware):
 git clone https://github.com/crust-firmware/arm-trusted-firmware/
 cd arm-trusted-firmware
 CROSS_COMPILE=aarch64-linux-gnu-
 export CROSS_COMPILE
 export ARCH=arm64
 make PLAT=sun50i_a64 bl31
 cp build/sun50i_a64/release/bl31.bin ../u-boot/
 cd ..
After ATF is compiled clone u-boot and copy the bl31.bin file into the u-boot directly.
git clone https://gitlab.com/pine64-org/u-boot.git
cd ..
Note that you can append -j# to the end of make all in the proceeding instructions. Replacing the hashtag with the number of threads in your computer's CPU which you want to use for compiling, will make it go faster and use more of your processor.
 cd u-boot/
 git checkout crust
 export BL31=bl31.bin
 export ARCH=arm64
 make distclean
 make pinephone_defconfig
 make all
Uboot installation
Once successfully compiled you can proceed to flash the device
Warning: Replace [CHANGE THIS] with the location of your SD card
sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/[CHANGE THIS] bs=1024 seek=8
Pboot multi-bootloader
External Links
Sunxi Uboot Wiki
