Template:Hint
Revision as of 09:05, 22 September 2021 by RainSlide (talk | contribs) (Add content to Usage and Example)
This page is a template. Check out all pages using this template.
For more information, read Template:Template.
A hint box for showing helpful hints.
Usage
{{Hint|hint content}}
Example
{{Hint|This is an hint.}}
This is an hint.
For a more flexible usage, it doesn't start with "Hint:" by default, you may add it manually with '''Hint:''':
{{Hint|'''Hint:''' This is another hint.}}
Hint: This is another hint.
Technical notes
The boxes use
This template uses class .template-box and .template-hint. In the future, if the TemplateStyles Extension is installed on this MediaWiki instance, one may move the embedded inline styles to Template Style files.
See also
